Originally Posted by
westwest888
I think there is more variability in engine output than we account for on this forum. 1 standard deviation could be 10%.
This is why dyno tuning would be better than everyone taking a canned tune from their favorite vendor. The tune the vendor sells you is perfect for the engine they tested it on. It's safe for your engine but doesn't squeeze every HP out of it.
Dyno tuning only serves one purpose, it allows a calibrator to make changes in a semi-controlled environment with the car stationary on one place.
Since this is a controlled environment, only a few variables are present. Why do you feel that every horsepower needs to be squeezed out of a motor? Nobody uses all of the power they have on tap the majority of the time.
It takes much more than just a dyno to confirm calibration changes, this is where a proving ground comes into play. The vehicle needs to be placed into real world load situations, on a variety of environments (temperature, humidity, air density, fuel changes).
If you strap a car to a dyno, and make calibration changes to squeeze every last bit of horsepower out of it, you will most certainly encounter catastrophic failure if the engine is presented in an environment to which it cannot adapt to.
