Results 1 to 9 of 9
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Can't resolve vehicle speed sensor implausible signal (P0501)
    A few months ago I started getting a P0501 (vehicle speed sensor implausible signal) code. At first the code would show up in VCDS but with no corresponding CEL and the speedometer still worked. A month ago the CEL started to come on but the speedometer still worked. As of two weeks ago the speedometer would only work intermittently along with the code and CEL.
    I started by replacing the speed sensor itself with no change in the symptoms.
    Today I replaced the magnetic ring inside the transmission and the problem is still unresolved. Still getting P0501, still have a CEL, speedometer still works intermittently. The magnetic ring I pulled off my car did not appear to be damaged. I've searched and searched and everyone points to the magnetic ring being the culprit.
    I would greatly appreciate any advice on where to start poking around next. Gotta be the wiring??
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    iirc, vss goes to cluster and cluster kicks it out to the ecu. If cluster is hoaky, could mess with the ecu signal.
    Been a while since I looked at the diagrams though.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 24 2010
    Paramus,NJ USA
    If you replaced the sensor with the correct part and are still having and issue.Check the connector and the pins inside make sure you have a good contact.Other than that your gonna have to maybe take a look at wiring possibly trace wires and make sure you dont have a broken wire anywhere.
    Ziddy Autowerks
    Senior Member Two Rings hanzy's Avatar
    Feb 19 2013
    NE
    Have you scanned the cluster for DTC's?
    Might not hurt to take a look at some of the MVB in the cluster, see if anything looks out of place.
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    When the Speedometer stops working does your fuel gauge move erratically too?
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    VSS signal goes to the cruise control unit before it goes to anything else. That might be where your issue is at.
    May 18 2010
    I've scanned the cluster, no codes. No codes on any of the other modules. Fuel gauge seems to be working correctly.
    The magnetic ring I ordered was 012-409-182-C. The one I pulled off the car was 012-409-182-A. The only difference I noticed was in the lack of a plastic locating notch on the replacement piece. It ended up locking into place with one of the side clips. ECS also says the C version supersedes the A version.
    Mike, my CC hasn't worked since I bought the car. I did a hardware check and it all works so my problem is electronic. I'll start with the CC unit and see what I find. Thanks for the suggestion. Time to dive back into the wiring diagrams.
    01 S4 2.7T: Stock
    May 18 2010
    Since I won't have access to the garage for a few more days I decided to trace the VSS circuit in preparation.
    From the VSS the signal passes through a brown/red wire into the instrument cluster through pin 23 on the blue connector. After going through the cluster processor/speedometer it passes out through a white/blue wire on pin 6 of the yellow cluster plug into pin 20 of the ECU. Since my car was made before 8/97, the same signal from pin 6 on the yellow cluster plug goes to the cruise control module, pin 9.
    Since my cluster doesn't seem to be receiving the signal I'm going to start with the wiring from the VSS to the cluster and see if there are any problems. Then I'll dig into the CC module.
    01 S4 2.7T: Stock
    May 18 2010
    Oh glorious day!!! I do believe I found the source of my speedometer woes.
    I started by checking continuity of the wire going from the VSS to the cluster, all was well. Next step was to check the connections within the cluster to see if the signal was passing from the blue plug to the yellow plug. I pulled out the cluster.
    All looks fine and dandy...
    Wait a minute..whats that?!?
    Cheeky bastard!! :D Could that possibly be the pin for the VSS? Yes it is, T26/6, blue/white wire that goes out to the CC module and ECU.
    Now, is it merely a coincidence that the green paint you see there is right next to my bent pin? That green paint is from when the pick n pull when I pulled the cluster. The only thing I can imagine is that the paint pen slightly bent that pin. All was well for a number of months until the last time I pulled the cluster when I did my big rewire. It must have got shoved over when I plugged in the yellow plug last time.
    I bent it back into place and made sure it was as straight as could be with a magnifying glass.
    What I can't figure out is what pin it was shorted to. It was touching the opposite pin, #22. However I couldn't see pin 22 in the wiring diagram for the cluster processor. The wire is brown, so maybe it's just a ground.
    I haven't driven the car yet since I've got the bumper off for realignment while I replace the fog light hardware. Tomorrow I'll give it a run and hope for the best. I cleared the vehicle speed signal implausible code tonight for hopefully the last time.
    So after months of having the CEL on and a speedometer that worked 1% of the time, $100 in parts, at least 15 hours of diagnosis/labor, the fix took 5 minutes...
    01 S4 2.7T: Stock
