My coil pack wires are brittle and dying, I ordered a replacement from USPMotorsports
I wanted to make this post to not only draw conclusions to my own questions but also to help others in the future that may come across a similar situation and have the same questions as me.
http://www.uspmotorsports.com/Coil-P...placement.html
I'll start off with the harness I purchased, it come pre-assembled but it seems they use a generic one for all 1.8t motors, be in in an A4 or a Jetta.
USP has a link to a DIY for install on a Mk4 but I think ours may be slightly different. If I'm not mistaken there is one plug on the harness which we do not use.
link found here : http://www.squarewave.com/army/andre...b.97-04-02.pdf
I'm very keen on re-pinning the harness as I feel this provides a better connection than cutting and splicing.
The new harness even comes with numbers attached to each wire so you know which pin to replace in the main connector.
My main issue is. Which plugs are needed, and which ones should lay dormant?
Here is a picture of the harness I got.
I'm sorry I cut it up before I took the picture so the extra wire is laying outside the harness opposed to inside.
The VW DIY says to cut out the "speed sensor" at breakout point A
Then it says to cut wires 2 & 3 from the side B.
ultimately leaving your harness looking like this.
What I am confused about. Is, now what do I do with the big plug and the brown wire.
I have a feeling I have to just cut off the big plug too and the brown wire is ground. can anyone confirm this?
as the plugs I have in the bag are as follows
and then when you reference it to the bentley ewg's it shows 5 wires go into the main loom
I also found this 034 link for reference too,http://www.034motorsport.com/docs/1....structions.pdf
it shows the each coil has a vc ground, 12v power, trigger wire, and other ground (4 wires per plug)...
assuming each coil pack has a shared valve cover ground, constant 12v, switched 12v and other ground with 4 independent
trigger wires. that would explain the wires I am left with.
Its
Wires in the main bag
trigger 103
trigger 102
trigger 94
trigger 95
constant power+ 121
Extra brown - GROUND
Extra plug (purp/black)
Attach (solder) to the old pin 121 you removed & replaced. or other good switched 12v
like this ^
