Results 1 to 29 of 29
    Veteran Member Three Rings audipcanugo's Avatar
    Oct 19 2005
    2009 Audi A4 Premium - Sport package
    Baton Rouge, LA
    Coilover Installation DIY?
    I have H&R Street Performance coilovers and SPC UCA's on the way. I'm tempted to try and tackle the install with a friend.
    Anyone know of a good writeup for a first timer?
    B8 A4 Meteor Grey - Sport Package
    | H&R Coilovers | VMR V702 - 19x9.5 | 255/35/19 | Votex |
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    I vaguely recall somewhere in the "Show your suspension" thread several folks posting their DIY installs - not much help, as it a loooong thread.
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Senior Member Two Rings AudiHockey's Avatar
    Jun 18 2012
    Huntington Beach, CA
    2009 Audi A4 2.0t Quattro
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Here's some more info specific to the H&R coilovers
    http://www.audizine.com/forum/showth...stall-Question
    Established Member Two Rings lostkeyz's Avatar
    May 20 2013
    San Diego
    Can anybody tell me if we can re use all of the original hardware to install the coilovers? ECS Tuning instructions says the factory manual tells them to replace the bolts and nuts because they are TTY (stretched) bolts. Just wanted to know if I can reuse them without any issues.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    2013 Audi A4 2.0 TFSI quattro Manual Sedan "never owned an automatic, man tran all day everyday"
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by lostkeyz View Post
    You can reuse all your hardware, H&R will give you new nuts for the struts and shocks pistons, just make sure to apply a generous amount of anti-seize on the control arm pinch bolt to make sure it doesn't seize itself to the uprights a few years from now. Also make sure you get a strut housing spreader it is a required tool that makes the job sooooooo much easier. The rears suck btw, i compressed the spring on the car then had a helper push down on the lower control arm and pried the spring out from the top.
    http://www.ecstuning.com/Audi-B8_A4-.../Tools/ES3894/
    Aug 11 2012
    Beaufort, SC
    Thread jacking a little, but I have the H&R Coils (same as OP) sitting in my house and the darn thing didn't come with installation instructions. I see a few H&R spring installs and various other brand Coils but no H&R specific info on our cars. I figured I'll watch a video on youtbe to get the gist of it but The question of the bumpstop.... Does it have to be cut down and, if so, how much? I know that the shorter springs could cause for a bumpy ride if the bumpstop is suppose to be modified yet isn't.
    P.S. Sorry OP, just didn't feel like starting a new thread for information that you may find helpful in your install as well
    Jan 09 2010
    St. Louis
    Quote Originally Posted by Mod.Kill.Yut. View Post
    Front:
    - Re-use the factory washer between the top of the shock rod and the factory rubber mount
    - Don't re-use the factory bump-stop, H&R already has a plastic gaiter in place (no bump-stop needed here)
    - Apply a liberal coating of the Boeing oil on the threaded section of the shock body
    - 1.25" of exposed threads (measuring down from bottom of the large/top collar) yielded about 25.75" GTF on my sedan. (Can be adjusted later with wheel in place, once front is jacked/lifted to take the load off of the suspension)
    - My coils seem to be binding a bit on tight turns (low speed, hi-load), recommend applying a grease or film lubricant to at least the top few coils to help prevent any binding. This will become part of your regular maintenance from now on and can be done from the topside, if you remove the black plastic covers on the shock towers and spray down at the coils, or from underneath if you're up on jack stands or ramps etc.
    Rear:
    - Re-use the factory bump stop, no trimming required
    - Re-use the factory black plastic rock guard, zip-tie in place to prevent it from rotating (there's an alignment hole to put the zip-tie through)
    - Don't re-use the factory lower rubber spring isolator, the H&R perch goes in its place
    - To raise/lower, hold collar in place with spanner wrench and rotate the perch from underneath, using an Allen key/socket (weight off of wheels, suspension unloaded)
    - 1.00" of exposed threads (measuring down from bottom of the collar) yielded about 26" GTF on my sedan
    Aug 11 2012
    Beaufort, SC
    Quote Originally Posted by jbradle7 View Post
    Front:
    Rear:
    You, my friend, are a gentleman and a scholar!
    Jan 09 2010
    St. Louis
    Semper Fi!
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    If i need to replace the pinch bolt, what is the part number or if it is a generic bolt, what size and length??
    Sent from my ASUS Transformer Pad TF300T using Tapatalk
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Jul 16 2008
    Finland
    Quote Originally Posted by wxsgt View Post
    Don't take out the pinch bolt unless it's absolutely necessary for say, replacing upper control arms. Undo the inside ends of the upper control arms and you can get the strut assembly out.
    Pin bolt = N 10491802
    Washer = N 10406105
    Lock nut = N 10272302
    The pinch bolt can be replaced by an M10x110 DIN931 partially threaded bolt grade 8.8 or 10.9.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    One of the references said ti take it out. Ill need to look more, my first time doing something of this magnitude
    Sent from my Samsung Galaxy S4
    Jul 16 2008
    Finland
    That reference is wrong. It's so much easier to undo the bolts of the top shock mount from the engine bay, drop the strut assembly a little and then undo the inside ends of the upper control arms. The only reason to remove the pinch bolt is to change the upper control arms or to change the knuckle.
    The guy who wrote the DIY for VWortex got the front right. He didn't remove the pinch bolt. However, it's not necessary to drop the subframe in the rear if you have good spring compressors. I used 1 compressor to compress the stock spring enough for it to come out. The new, shorter spring will be much easier to install.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    how long should this take about??
    Jul 16 2008
    Finland
    The first time I did springs and shocks in a B8 it took me about 6 hours with a buddy. Once you know how everything goes and what to remove, I don't think it should take more than 3-4 hours.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    It took me 8 hours with the wife. Could have been quicker but I wont go into it lol. Now that im lowered I see the headlights fall significantly shorter. Is there anyway to adjust this?
    Jul 16 2008
    Finland
    You can adjust the headlights as you would normal halogen lights, just make sure they're in the levelled position when adjusting. The adjustment screws are located on top of the headlight housing.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Thanks and the auto adjustment wont mess with this?
    Jul 16 2008
    Finland
    Nope, as long as your car is level when you do the manual adjustment. If not, you can cycle the lights to the levelled position with VCDS and then do the adjustment.
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Ok thanks again!
    Aug 11 2012
    Beaufort, SC
    I may have to adjust the headlights as well. I just finished installing my coiloversi. They haven't even settled yet
    Aug 11 2012
    Beaufort, SC
    Semper Fi!
    Big thanks to you bud, the tips and ride height suggestion were perfect! Semper Fi!
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    hello there,
    I have bought the coil overs from SOLO WERKS. I have never installed coilovers. I am not familiar with the installation. I have been reading the different posts and I havent seen anybody mentioning if they bought new bushings and new mounts? My friend pointed it out to me, saying that i would have squeaky noise if i dont get new ones. What would you guys recommend? if i have to buy those, where do i get them?
    thank you for your help
    Jan 14 2014
    my two feet
    Tampa, FL
    i love your setup! could you tell me what is your set up for your wheels? those rims are really nice!!!
    Established Member Two Rings hookahmaster's Avatar
    Jun 18 2013
    mk7.5 gti, 19' GLI, 12' veloster
    DFW Texas
    Any help on adjusting height? I have Vogtlands, they charge $160 each time to adjust height at my shop I don't have any power tools, but i was wondering if it was possible on a quattro for me to make height adjustments myself? I heard it's extremely complicated on the quattro's, any help would be greatly appreciated. I just got wheels and would like to be able to do some adjustments to the height myself until I find the perfect ride height.
    2013 B8.5 Audi a4 Quattro 6spd M/T. (totaled)
    mods-EC test pipe, AWE single exit exhaust, USP downpipe, Revo stage 2 flash, Vogtland coilovers, AG 590, stage 2 Southbend clutch, ECS flywheel, roof rack, k&n intake.
    current: 2019 VW GTI mk7.5
    downpipe, APR stage 2 tune 2/ pops and bangs, stage 3 southbend clutch and lightweight flywheel, APR turbo inlet pipe, ECS turbo muffler delete, ECS dogbone insert, afe enclosed cold air intake. (KW coils)
    Aug 11 2012
    Beaufort, SC
    Quote Originally Posted by Vinhouw View Post
    It's in my sig bud
    Aug 11 2012
    Beaufort, SC
    Quote Originally Posted by hookahmaster View Post
    Not sure about Voglandts, but the H&R come with the adjusting tool (spanner wrenches) you can adjust them simply by jacking the car up taking off the tires
    Apr 14 2014
    California
    What kind of wheels do you have?
