Results 1 to 16 of 16
    Active Member Two Rings Adam5860's Avatar
    Mar 26 2012
    Earth
    Anchor Motor Mounts
    Anyone have any experience with Anchor Motor Mounts? Are they any good?
    2008 A4 S-Line Quattro (Tiptronic)
    APR Stage 2 (stock/91/93); 034Motorsport HFC; 034Motorsport Turbo Inlet Pipe; 034Motorsport Street Density Motor Mounts
    Mar 26 2012
    Earth
    No one?
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    I'm familiar with Anchor brand mounts for domestics. Summit Racing sells them. Usually very cheap, all rubber mounts. Hold up ok.
    I have no experience with them in our cars.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Mar 26 2012
    Earth
    The reason I ask, is I have the 034 Motorsport Street Density's in now and although it buckles the engine down there's a little to much vibration for my liking. Rather than dishing out ~$300 of money I don't have at the moment for OEM mounts (seeing how I just spend ~$240 on the 034Motorsport Mounts) I figure I'd throw the Anchor mounts in for a fraction of the price.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Adam5860 View Post
    Are they seated correctly? Did you install... run... re-tighten? I have the 034's street density and although there is slightly more vibration it's nothing that one can actually feel.
    034Motorsport Motor Mount Set (Street Density, Set of 2)
    Established Member Two Rings shawn0223's Avatar
    Jul 05 2010
    02 E-320, 1998 corolla
    Mansfield, tx
    Quote Originally Posted by Hugh@EuropaParts View Post
    X2^^
    ive heard that letting it idle before tightening everything down is the way to go so that everything settles in before you lock it down.
    Shawn
    2006 A4 3.2Q 6MT||19" RS4 Reps||Yellow Koni Coilovers||RS4 Rear Swaybar||Interior LEDs||Fly's LED DRLs||License Plate LEDs||6000k HID Fogs||ECS Tuning Snub Mount & RS4 Grill||RNS-E Aux Mod ||42DD Catch Can||
    Mar 26 2012
    Earth
    Yes they're seated correctly, I think the fact that its a tiptronic lends itself to a little more vibration than a 6spd would experience with the mounts. When I went to re-tighten them the bottom bolt snapped off the mount . Which really makes me mad because they've only been in for 6 days. I ordered the parts from Europaparts.com so whats the policy on returns and exchanges? That bolt shouldn't have snapped off like that, especially on an item I just bought less than a week ago.
    Aug 22 2010
    Piscataway, NJ
    Unfortunately install errors are not valid for replacement. I have customers with both tip and 6mt and there is no difference in vibration. I've also never had an issue with a bolt snapping off if installed correctly.
    Jul 19 2011
    Northern Minneapolis, MN
    I'd get a hold of 034 with proof of purchase to see if they would do a manufacturers warranty. That sucks though!
    Mar 26 2012
    Earth
    The install for motor mounts isn't exactly brain surgery. I removed the snub mount, jacked up the engine, took out the old mounts, making marks where the little nub on the old mounts sat in the mounting brackets, installed the new mounts , lowered the engine, let the engine run for a few minutes, and then tightened everything up. Vibrations were still there, went under to make sure everything was tightened up and bolt snaps off. Not a happy camper.
    Aug 22 2010
    Piscataway, NJ
    Did you over torque? We have sold literally hundreds of these mounts and haven't had a single install issue.
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    I had a stud snap off my brand new 034 mounts also. Hand tight with a 1/4 drive ratchet. Broke before it even started to get tight. That was about 3 months ago. Can't prove it wasn't install error so I ordered another one.
    Mar 26 2012
    Earth
    Good news, I contacted 034 Motorsport and they are going to send me a new motor mount free of charge to replace the broken one. Two thumbs up for 034 Motorsport !!!!
    Jun 27 2011
    So when you do this, you HAVE to re-adjust the snub mount after a week or so. The vibrations come from the snub mount, not the engine mounts. If those are torqued and aligned properly, they CANNOT cause much vibration by themselves (unless they're 034 Billet Aluminum solid mounts ). What happens when you install new mounts is the engine ends up being raised a bunch compared to the old saggy mounts This in turn changes the location of the snub mount on the retaining cup and when the snub rests on the mount at idle it introduces a lot of vibration.
    Don't believe me? Loosed the snub retainer and start the engine. There SHOULD be zero vibration.
    What you need to do is drive with the new mounts for a good week, get them "broken in" so to speak and let them reach their nominal resting height.
    Get the car nice and warm, with A/C on high. Loosen the snub retainer and on as level a surface as you can. Tighten down the sub retainer making sure the snub itself doesn't actually touch any part of the snub retainer. Then you should have little to no vibration.
    Also with a tiptronic, you will always have vibration in gear. In P or N, the engine should be smooth.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 22 2010
    Piscataway, NJ
    True... Once I installed my motor mounts and dropped the engine back I noticed I had to re-adjust the snub mount bracket.
    Jul 19 2011
    That's some good thinking! I'll have to try that when I do mine whenever they go (almost 100k!). I was looking at the BFI ones, I like the design. Anyone here tried them or had experience?
