Results 1 to 12 of 12
    Veteran Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT, 2005 Jetta Wagon TDI 5MT, 2006 CBR1000RR
    Plano, TX
    Welp! Stripped a motor mount bracket bolt hole in the body. What now?
    Finished up the oil cooler reseal and installed the alternator and the subframe, and while snugging up the bolts that secure the lower motor mount/swaybar bracket to the body, I got a nice "pop," and then the bolt was loose again. When I pulled it out, it had all the threads of the hole on it.
    The reason for my post is that I want to make sure there is no reason I shouldn't heli coil that hole. It's not the hole for the main subframe bolt, but one of the smaller M10 bolts forward of the main bolt. Has anyone done this and lived to tell about it?
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    Seems like a good way to fix it. My only concern would be how thick the metal it's going into is.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Apr 18 2007
    ny
    Helicoil is ok, but I would prefer using a timesert.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Sep 11 2009
    NE
    I would just go one up M12 and done. Just upping the bolt will be much better than doing the same (chasing with M12 or whateve M10 timesert will require) and using insert with the same little bolt. Here you can up-size the threads without ill effect, unlike some other places like heads.
    My car has quite a few places where bolts are larger than stock
    Apr 22 2010
    Plano, TX
    Gumby, your concern is mine as well; on my TT, the bolts that secure the engine mounts screw into holes that are barely thicker than sheet metal; if I drilled them out 2mm bigger, there wouldn't be any material left to thread. I don't know if the subframe and supporting bolts are that way or not. Does anyone know for sure?
    Apr 22 2010
    Plano, TX
    Also, for reference, the bolt is N-906-630-01, M10 x 70 sw18 (not sure what SW indicates). I know it's an M10, and I do not know the thread pitch. Anyone know off hand so I can order the proper helicoil kit?
    Veteran Member Three Rings Hambone101's Avatar
    Apr 21 2009
    1967 Mercury Cougar
    Clearwater, FL
    Why not take the bolt to a hardware store and check the pitch there? More than likely it's going to be either a 1.25" or 1.5" pitch.
    redneck truck - Everybody quieted down when the guy up in the back of the theater asked his date for a Come flavored slurpee.
    Apr 18 2007
    ny
    If you take it to Home Depot they have a thread guide you can use.
    SOLD
    Greg
    C5UNION
    Sep 06 2008
    Bellingham, WA
    So if metal thickness is a concern, how about drilling it out, and using a nutsert?
    -Matt-
    Apr 22 2010
    Plano, TX
    Time Sert installed, problem solved. Huge thanks to the dealer tech that gives me shop supplies and lets me borrow his tools.
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    Quote Originally Posted by redneck truck View Post
    SW is the socket size needed to drive the bolt.
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Apr 22 2010
    Plano, TX
    Wow, that's good to know. Certainly nice when you're shopping for OE hardware for a one-off job.
