Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 192
  1. #121
    Registered User Four Rings
    Jun 25 2016
    DMV
    Quote Originally Posted by Jessekin View Post
    So I got the AFS cables from Kufatec... And I'm not sure what to do with them. The have exposed cables branching off of them. Anyone have any knowledge of the swap for Q5's with AFS? I bought AFS headlights, and I feel that I shouldn't of, after getting more info from the description from KUFATEC's website.
    Yikes, yeah not sure what those are for. PM Spijun, he knows all about this stuff.
  2. #122
    Established Member Two Rings VRvento's Avatar
    Feb 22 2010
    Costa Mesa OC CA
    FYI: my US model year 2012 has the right side (passenger) holes in the engine bay for the FL support bracket, saved some headache there
    2014 SQ5
  3. #123
    Feb 22 2010
    Costa Mesa OC CA
    got my 2012 facelifted w/ ecodes a couple days ago, also figured with the bumper off to add a RS mesh grille and paint the crash beam black.
    Thanks to this thread and thanks to blasterman for the harness extension!
    2014 SQ5
  4. #124
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    1990 Ferrari Testarossa
    Warsaw, Poland
    Looking great !
    2021 Audi R8
    2012 Porsche Cayenne
    2010 Audi S5 - facelifted F & R (sold)
    2010 Audi Q5 2.0TDI facelifted F & R (sold)
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
  5. #125
    Jun 25 2016
    DMV
    nicely done!!
  6. #126
    Nov 14 2010
    1999 Porsche Carrera 996 & 1990 16v 2.0T VW Corrado
    Bayamon, PR USA
    Hi Blasterman. Do you still making the Q5 facelift taillights harness (Mine is a 2012 Q5)? If yes, please PM me how much!
  7. #127
    Jan 06 2017
    Hi Guys,
    For coding the retro fit. Please buy obd eleven, it is one click. Rest of the stuff is in this blog. finiished my today and now waiting my device, it is in shipping.....
    1) You need Kuftec non-afs adapter for this retro fit. no need for AFS ones.
    let me know if you need any help.
  8. #128
    Jun 29 2015
    SF Bay Area, CA
    Quote Originally Posted by PPCorrado View Post
    just ordered mine. speedy response. cant wait to get them!
  9. #129
    Feb 22 2017
    Uk
    Hello. I did the same thing to my 2011 q5...but i tried to code my headlights and the mechanic told me i need a new control module.. Can you please tell me exacly how you made them work....what coding you did ....
    Thanks very much
  10. #130
    Feb 22 2017
    Uk
    Can anyone point me to the right topic please...can find anything about how to code the ecu to work proprely with this headlights. Thanks very much in advance.
  11. #131
    Feb 22 2010
    Costa Mesa OC CA
    This link helped with vagcom to fine tune the drls, but the main thing is to turn the prefacelift 7% duty cycle to the post facelift 28% duty cycle to avoid any errors.
    Also make sure that when headlights are on the drls are set to 100% duty cycle
    http://www.audiworld.com/forums/q5-s...14-q5-2855281/
    2014 SQ5
  12. #132
    Feb 22 2017
    Uk
    Tx for info.. I `ll try to do that. Cheers
  13. #133
    Jan 06 2017
    Coding
    Hi,
    I did my coding with OBD eleven. It is really nice tool and they have one click retrofit app for q5.
    https://obdeleven.com/
    If you dont about coding then this is your best bet.
    let me know if you need more help.
  14. #134
    Mar 15 2017
    Chicago
    Hi everyone, hope to find you doing well. I have just purchased an Audi Q5 2010. I wanted to do the headlight conversion however, I am unsure here to get the wire harness. Does anyone know where I can purchase the wiring I need for the conversion, and apart from that, I only need a bracket and some coding done correct?
    Thank you!
  15. #135
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    Quote Originally Posted by Crazybuba View Post
    Thank you!
    go to kufatec to get the wire harness. also follow up to the beginning of the thread. everything is listed for the conversion. i did the conversion for my 2011 Q5
  16. #136
    Apr 26 2017
    Sydney
    Hi All,
    Bumping this thread, i now own a 2009 halogen lights. the lights themselves is gone as the light distorted and spreading everywhere. so looks like im in the hunt, it make it worst if that im from australia (RHD) so hopefully be sourcing from ebay (US) seems to have plenty of used facelift lights.
    the question is that would the support bracket is compatible international?
    any tips from ppl upgrading from halogen to give their tips>?
  17. #137
    Jun 25 2016
    DMV
    Quote Originally Posted by mannersQ5 View Post
    Hi All,
    Support bracket should be the same but if you source used lights from the USA they will all be LHD. Best shot is to get them from the U.K. Or Japan I think.
  18. #138
    Veteran Member Three Rings base14's Avatar
    Jun 01 2017
    OR
    Completed front and rear conversion thanks to this thread, so thanks OP for putting this together!
    Some thoughts: The pre-FL headlight LEDs are dimmed to 9% with low beams on, and need VAGCOM modification to increase the brightness to FL levels (28%) otherwise they won't turn on AFAIK. Now looking at my converted FL tails, it seems like the DRL (which I turned on) are rather dim. I haven't been able to compare side by side with an actual 2013+ Q5, but do you guys think a similar lower LED output for the pre-LED tails carries over to the FL tails?
    I used the Carista app to modify my settings, so adjusting the tail light brightness isn't an option for the app. Maybe some of the VCDS folks can chime in on what theirs are set at...
    2018 A6 3.0t P+ Competition Package| 034 Stage 1 ECU+TCU (his)
    2015 Q5 3.0t P+ S-line | EPL Stage I (hers)
    (SOLD)2013 allroad Prestige | APR Stage II | E85
    (SOLD)2010 Q5 P+ | OEM+ Build Thread
  19. #139
    Jun 01 2017
    OR
    Just to follow up on this, they indeed ARE less bright than the actual Facelift cars. Looked at them side by side next to a 2014 Q5 and the retrofits LED ring were not as bright. I just need to find someone with VCDS in the Portland area to see if I can configure these to be true OEM brightness.
  20. #140
    Apr 17 2018
    Edmonton Alberta Canada
    This is a really old thread but does anyone know if the ballasts and bulbs from the 2009 headlight assembly are transferable to the 2013 housing? The generic ballasts i'm finding on ebay appear to work for both so one would assume...just wondering if anyone out there knows for sure? Much cheaper to find the FL headlights without...
  21. #141
    Jun 01 2017
    OR
    Ballasts and head light bulbs are the same between pre-FL and FL. I believe there are small variations in the turn signal bulbs, but that’s minor details. A word of caution though, our ballasts seem to fade in light output over time. I used a newer ballast from my preFL lights, replaced by the original owner before I purchased the car, to put into my FL lights and the light output was noticeably brighter and bluer. My FL set only came with one ballast but it swapped right over from my old preFL set.
  22. #142
    Feb 18 2004
    Warsaw, Poland
    Quote Originally Posted by base14 View Post
    Maybe that was the HID bulb which was degrading over time, not the ballast ?
    2021 Audi R8
  23. #143
    Jun 01 2017
    OR
    Quote Originally Posted by Elberoth View Post
    That was my thought too, but I had bought 2 new Osram CBI HID bulbs and replaced them a couple months before swapping the headlight housing. The side with the newer ballast was still about 20% brighter and the cutoff line was slightly blue as opposed to the white/yellow cutoff from the older ballast.
  24. #144
    Apr 17 2018
    Thanks for that. Does that apply only to the xenon ballast? What about the LED DRL control module (i.e. 8R0941475B)? The OEM Valeo lights I'm looking at don't appear to have it. Would that be something else I would have to source as it doesn't appear to be on the preFL or at least looks quite different (hard to tell as I have not ripped anything apart yet)?
  25. #145
    Jun 01 2017
    OR
    The led drls are separate ballasts, usually on the inside of the unit. Mine came with my headlights fortunately. You’re gonna have to source those and I’m not sure if they’re the same preFL and FL.
  26. #146
    Junior Member One Ring Audi Q5's Avatar
    Dec 15 2016
    Hungary
    Hello Pls HELP ME !!!!!!
    I have Audi Q5 11.2008 with bixenon adaptiv headlight this is my problem:
    01042 , 02234 , 01539 vcds code . The AFS modul (7L6 941 329A) is new .What can i do
  27. #147
    Active Member One Ring PhillipAtwood's Avatar
    May 26 2018
    97 A6 Avant in blk
    Baltimore MD
    Hello Elberoth, I’ve been following your posts and thank you so much for the vivid detail!
    I have a 2011 Q5 w halogen stock lights. I have the FL lights but have struggled to find an example of a halogen to factory xenon FL conversion. Do you have any input for me? Thanks in advance!!
  28. #148
    Feb 18 2004
    Warsaw, Poland
    Quote Originally Posted by PhillipAtwood View Post
    It seems you want to do two conversions in one big step:
    - halogen to xenon
    - pre-FL xenon to post-FL xenon
    I have no idea if that has been done before. There is a special cable set from Kufatec for halogen to xenon conversion:
    https://www.kufatec.de/shop/en/audi/...di-q5?info=929
    It should work with FL xenons as well.
    2021 Audi R8
  29. #149
    May 26 2018
    97 A6 Avant in blk
    Baltimore MD
    Exactly...I’m hoping that it works. I ordered the Kufatec harness and it should arrive in a day or so. I was also trying to see if someone with an A4 with halogen pre-facelift did a factory xenon post facelift swap. Do you think I will run into any trouble?
  30. #150
    Feb 18 2004
    Warsaw, Poland
    No idea ... you may be the first one going that route. Please keep us posted.
    2021 Audi R8
  31. #151
    May 22 2018
    Hong Kong
    Dear all,
    I am headache on upgrade to Q5 facelift headlight....
    [THE DAILY RUNNING LIGHT is failure to ON in all condition]
    I have bought 8R0941006D (Right headlamp) from UK and 8R0941006A (Left headlamp) from Japan.
    I have bought DRL module (Try both 4G0907697D and 4G0907397R) and LED bulb module (8R0941475, change to other set already)
    I got the adapter cable from CHINA, have bought from 3 different dealers (From China too)............. All fail !!
    TRY ODIS and VCSD to decode, DRL FAIL to on too !!
    Do all of you think it is still adapter cable problem? Or any possible reason?
  32. #152
    Apr 02 2018
    Muskegon, MI
    I will admit the taillights do look a lot better! But the older headlights to me are more unique.
  33. #153
    Oct 10 2016
    Montreal , Quebec Canada
    hey can you please let me know where you got you're grill ? thank you
    Btw beautiful car !
  34. #154
    May 22 2018
    Hong Kong
    Dear all,
    Do anyone has 14PIN out of the adapter cable?
    My car is Audi Q5, UK version
    Thanks
  35. #155
    Jan 03 2016
    Houston, TX
    Can someone help? I'm going from 2011 Halogen -> Facelift w/ LED's.
    I was hoping on using OBDeleven to do a simple one click coding but OBDeleven says my vehicle is not supported (I'm guessing due to the halogen)
    What changes do I need to make in OBDevleven advanced mode?
    This is the harness I will be using
  36. #156
    Established Member Two Rings pjekar's Avatar
    Jul 17 2017
    2018 S7 Prestige
    Staten Island, NY
    Hi,
    So i got Q5 2011 3.2 - can someone point me to where can I get a 2013 rears and anything else required to do a swap?
  37. #157
    Feb 18 2004
    Warsaw, Poland
    Quote Originally Posted by tck721 View Post
    Dear all,
    Thanks
    Try Kufatec.
    - - - Updated - - -
    Quote Originally Posted by pjekar View Post
    Hi,
    ebay or a dealer.
    2021 Audi R8
  38. #158
    Feb 18 2004
    Warsaw, Poland
    Quote Originally Posted by still in school View Post
    Make sure those extensions have rubber gromets (seals) around the cables entering the socket. I do not see them on this picture. Without the seals, you will get a short in wet conditions.
    2021 Audi R8
  39. #159
    Jul 17 2017
    2018 S7 Prestige
    Staten Island, NY
    I understand that ebay is where I can find it etc. I was hoping for maybe a link to items, because I simply don’t even know if my car has halogen or led (original not changed from the date of purchase). I know I am asking a lot but can someone give me a list of parts required, with links preferrably?
  40. #160
    Feb 18 2004
    Warsaw, Poland
    Post a pic of both front and back of your car.
    2021 Audi R8
