Results 1 to 7 of 7
    Mar 07 2013
    Pittsburgh, PA
    How to Remove and Replace Coolant Tank
    Has anyone done this before? Would apprecaite some assistance before I accidently break something. Thanks!
    Dec 07 2009
    East Coast
    Almost exactly same process as on 1.8T: Drain, flush, disconect hoses to remove old tank, install new tank, connect hoses, fill in new coolant, burp air out
    http://www.audizine.com/forum/showth...-8T-DIY-(PICS)
    Forget the B8, keep the V8!
    Veteran Member Four Rings troyguitar's Avatar
    Feb 03 2013
    2004 Z06
    PA
    No need to drain or flush if you're just replacing the plastic expansion tank. It's at the top of the system, you can replace it without putting any air into the system.
    Get replacement tank and hose clamps for the 2 hoses that connect to it (I think they're around 1/2" and 7/8"). Remove original 1-use hose clamps.
    Clamp shut both hoses.
    Pull original tank loose with coolant still in it, disconnect coolant sensor, remove and drain coolant tank.
    Connect sensor to new tank, install tank, connect hoses with new hose clamps, refill with coolant mix.
    2004 Z06
    2001 allroad gaytronic - Sold
    2008 TT 3.2 DSG - Sold
    2006 S4 Avant MT6 - Sold
    Active Member Two Rings Canucker's Avatar
    May 20 2011
    Calgary, AB
    Sorry to bump an old thread, but I just replaced my coolant tank and it didn't appear that the hose clamps were of a "single-use" type. I'm not the original owner of the car, so I don't know if they're stock, but the clamps on the car could be squeezed with pliers to open and seemed to close okay. I didn't have to cut, twist, pry, etc. Should I be out looking for screw-type clamps, or should I be okay?
    Appreciate your thoughts.
    Cheers,
    Bryan
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by Canucker View Post
    Cheers,
    Bryan
    You'll be fine re-using the squeeze clamps unless you somehow over-squeezed and mangled them.
    I personally buy new screw clamps from Advance Auto or AutoZone to replace old clamps but that's just me.
    2015 B8 SQ5
    Click Here
    Past
    May 20 2011
    Calgary, AB
    Thanks for the quick reply. I've kept the plastic engine cover off for now so I can have a good look after driving for the next few days. Things seem secure, so I hope I'm good to go.
    Cheers,
    Bryan
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    The factory spring clamps work fine. I recently replace my coolant tank too and reused the factory clamps. It is nice to see my purple/pink updated coolant clearly.
