Results 1 to 25 of 25
    Veteran Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT, 2005 Jetta Wagon TDI 5MT, 2006 CBR1000RR
    Plano, TX
    4.2 Exhaust Manifold Upgrades, Revisited
    I've just purchased some exhaust manifolds from an early 4.2. They are the style with the (supposedly) larger collector and individual primaries that run all the way to the collector.
    I realized that I've made an assumption: 4 primaries to the collector rather than 3, and a bigger collector mean better power output. However, I've never seen empirical evidence to that effect. Has anyone actually bothered to do the swap and can they comment?
    Apr 18 2007
    ny
    Would a header style setup be an option?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    Quote Originally Posted by A62TURBO View Post
    Not really. JHM looked at producing headers for the C5 4.2L but needed 10 people to buy in to get it started and couldn't raise the interest. Basically no market means no real non-custom performance upgrades for the 4.2L. The early 4.2's had the same pre-catless system that the S6 got.
    Current: 2012 Q7 Prestige 3.0T
    Former: 2008 FSI V8 Touareg, Galpagos Grey Metallic on Sienna interior… self-immolated due to low pressure fuel leak on exhaust manifold
    Former: 2002 S6, Silver on Silver Pearl w/ Alcantara insert.... stolen, used in a targeted gang murder and given a Viking funeral
    Former: 2000 A6 4.2L... killed by a distracted driver
    Apr 22 2010
    Plano, TX
    These are the exhaust manifold part numbers I've been able to find.
    077 253 033/034J: early 40v 4.2 non-S. Fits down pipes without precats. 4 visible primaries in collector, free studs (i bought a pair today)
    077 253 033/034T: later 40v 4.2, non-S. Fits down pipes with precats. 3 visible primaries in collector, screw-in studs (in my car from the factory)
    077 253 033/034Q: all of 40v 4.2 S6/S8. Fits down pipes without precats. 3 visible primaries in collector, free studs
    As for down pipes, it seems the only difference I can find is whether or not there are precats; can't find anything on a larger or smaller inlet.
    4b3 254 500/550 GX = has precats
    4b3 254 500/550 CX = has no precats
    Jun 22 2013
    i have a 2000 Audi A6 4.2L came stock with
    4b3 254 500/550 CX = has no precats.........cats are located under car which equals less engine bay heat soak.
    Also JHM's Audi S4 B6 headers fit the Audi A6 C5 series with the belt driven v8. ......from what i have been told from a couple people. There are very minor mods needed for them to fit.
    Senior Member Two Rings alterdcreations's Avatar
    Apr 06 2010
    Totally in for this
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    I'd think the difference would be negligible. Curious to see though.
    Apr 18 2007
    ny
    Quote Originally Posted by alterdcreations View Post
    Totally in for this
    That's what everyone said last time too lol
    SOLD
    Greg
    C5UNION
    Apr 22 2010
    Plano, TX
    I just want to get the best parts in there that I can while the subframe and oil cooler housing are off. Don't really have time to reinvent the wheel or wait for a new parts offering...
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    Yup, right up until you figure out they are $1500 and you have to remove the engine to install them, they sound like a great plan.
    AEB: Boost goes in, valves come out.
    2003 Audi S6
    Not to threadjack, but there are a few 4.2 gurus in here, so I figured I'd mention I'm parting out a 4.2 engine that I just pulled out of a 2000 A6 with 100k on it, motor ran fine, timing belt looks new, trans died, obviously. Let me know if you guys need anything.
    Jul 23 2010
    Port Moody, BC
    Quote Originally Posted by Castor Troy View Post
    ding ding ding!! This is largely why they never took off last time. Installing headers make lots of sense as a "since I'm in there already" type of mod when you already have the engine pulled for something else. To pull the engine just to install headers? The power gains aren't nearly enough to justify it.
    Jun 22 2013
    ^Long tube headers for a v8 that actually are designed correct and create a shotgun effect in the collector are deff worth it. Great increase in bottom end power. now when a set of headers cost 2,700 dollars than yes i agree it may not be worth it especially if you paying to have them installed!
    Jul 23 2010
    Port Moody, BC
    Quote Originally Posted by Vinnie981 View Post
    The JHM headers that fizzled and died on the vine were also long tube and designed specifically for this engine...
    I'd have to see dyno charts to prove exactly what the gains are before I could agree whether it's worth it or not. What are you expecting to see in the way of gains? 20hp? 30? Even if these headers show unexpectedly phenomenal gains, once the cost of purchase and installation is factored you're still getting a pretty low power increase/dollar spent ratio and that's why no one has really pursued products stuff like this for the 4.2. $0.02.
    Apr 22 2010
    Plano, TX
    Exactly my point. This is a "while I'm in there" occasion, as I (think I) can wiggle the motor around and access everything I need to in order to make the installation happen. But my budget is about $100 for 15-25hp, not $1500 for 40hp.
    Are the manifolds with 4-1 collectors better the later manifolds with 4-3-1 collectors, or am I better off just staying with what I have?
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by redneck truck View Post
    Apr 22 2010
    Plano, TX
    Hmm, that engine seems to be missing a couple cylinders, but it's awfully heavy!
    Feb 06 2012
    Lake Lanier, GA
    It can also double it's output using spinny things to create power out of nothing.
    Apr 22 2010
    Plano, TX
    As can the 4.2, if only someone made a set of pistons to handle it!
    Veteran Member Four Rings Widebody4.2's Avatar
    Jan 08 2012
    S6 Avant
    Central MA
    Does anyone think there room for a short style header? Something that'll allow more flow but not more constructive.
    2017 C7.5 S6 APR Stage 3
    RIP DAZ
    May 16 2008
    South Texas
    THe pistons aren't the weak parts, it's the rods.
    Apr 22 2010
    Plano, TX
    Well, but the compression is awfully high to be making boost.
    Jan 08 2012
    S6 Avant
    Central MA
    It'll take 7 psi all day
    RIP DAZ
    Jun 22 2013
    sure will.....
    and as scotty said it the rods and wrist pins to worry about
    Jun 22 2013
    Quote Originally Posted by Widebody4.2 View Post
    im sure it can be done....but V8's prove best with the long tube header over shorties.
