Hi everybody, I'm was lookking on other category before posting but I haven't found the right category for my question, so I ended up here. My question is quite simple, how you setup to make sur to use a third party VAG-COM adapter to work with any ross-tech software, what is their differences. First I'm pretty sur that I'm not the only one who wonder about that. Here is what I heard and did. Mine was bought on eBay and came with a demo version of VAG-COM 409.1. I try everything to install it on a Windows 7 laptop, nothing succeed so I build up a vm using XP and it installed like a charm. I loaded the software, and test in the option, he found the interface. Then I try programming the Remote Windows but when I clicked on "46-Central Conv." He started loading, loaded two information and then said "Too many connection error", so I tried disabling the Seatbelt chime, everything worked fine. So I searched on the internet and found the changing the 16ms response to 12ms solved the problem but it didn't.
SO ! I'm wondering if any of you have tips to help use the VAG-COM, I'm not a big badass using this so I need some advice. I checked for the original ross-tech but they aren't given.... So if you can help, it'll be pretty awesome.
Thank you so much hope you'll be able to help
