I just had my car inspected (which is mandatory annually here in PA), and my front brake pads were both at 5/32". My mechanic said I should be good for at least another 6 months or so, so I was going to have them rechecked in the Spring. Well my brake pad wear indicator came on the day after the inspection, and I want to temporarily disable it. I have searched and found the only sure-fire way is to cross the sensor wires, but that seems like you'd have to snip the connector off. I tried some VCDS coding (Instruments-17, Coding, Long Coding Helper, Byte 10, Bit 0), but to no avail. I tried clearing all codes as well.
I was just curious if anyone has been in the same boat and found an easy way to temporarily disable this. It is annoying to hear and see the warning every time I drive, especially since the warning is where my song titles or Nav info is typically shown on the DIS. Any help would be much appreciated. Thanks!
