Originally Posted by
Seerlah
Should have gone with Glyco. Don't forget your thrust washers. And an FYI, I used Mahle rod bearings and spun a rod bearing on one cylinder. I plasti-gauged, used a quality digital torque wrench, and it spun. Not sure if it was that or the Permatex assembly lube. Next time around I used Kolbenschmidt rod bearings (what IE uses), Glyco main bearings, Glyco thrust washers, and Amsoil assembly lube. Worked out fine this time around.
Think mine might actually be glyco, the rod bearings are Mahle though. The thrust was integrated in the bearing.
It seems number 4 is a 360 bearing. Can't find why though.
Used redline assembly lube.
It's fine I put lube under the bearing on the rods and journal? I hope so because the head is on now.
