I have a small oil leak coming from the rear timing cover on the 2.0 motor. I have been searching and have been trying to see if anyone has changed that gasket? Is it a pita or is it pretty straightforward? The gasket itself is pretty cheap, and i am looking at replacing that vacuum pump that sits on it anyways.
Btw its the timing cover on the rear of the motor that has the vacuum pump attached to it, next to the firewall.
