Considering I was able to run the same system in a 04 C230K, with one additional amp, something's not quite right here. This car i had 0GA going from the battery (in front) to the trunk.
I'm actually running LESS power now than i was previously. As for speakers, most are 8ohms in my system. Nothing is stock except the MMI. I run 7" speakers in the doors.
When i was running full class A/B in my Acura, I had my alternator redone for 120A. Also had an overdrive pulley on it. However, the change to Alpine's PDX series should have had a significant drop in power requirements.
I know there's an obvious voltage drop issue to the rear, as I measure 14.4 up front, while the rear reads mid to low 12s and under at times, which is why I'm suspecting the cable is insufficient for my needs.
Again, I'm not using the cap to magically "gain more power". I'm using it to level the load and clean out some of the dips and valleys during bass hits. Caps are more responsive to delivering power than say a battery is. Directly pounding on your alternator probably isn't very good for your regulator either. Providing a consistent draw of power from your alternator will help it gear up for the current demands. A drop in voltage signals the regulator to produce more, then as the bass subsides, you end up with an over voltage situation, prompting the alternator to stop producing, just as the bass hits again, forcing the voltage spikes to be increasingly massive.
Recoiling your alternator does nothing when your pipe is only so big. Imagine having a huge lake full of water. If you're only sucking through a straw, what's the point? Yes, I'm on the stock battery. The car is a 2012, so should be good still.
I'll recheck my grounds. Seems like it could have rattled loose. I'm using one of the factory bolts in the spare tire well. They have acorn nuts on them. Not sure what they're used for, but seemed to work decently initially anyway. One thing I did notice while inspecting some wires was that one of my grounds leading back to my distribution block had melted through the sheath and grounded itself out on the bolt in question. I've replaced that cable and put loom over it now.
My draw is minor. 2200WRMS, more than most people, but not quite up there with the big hitters. Plus they are all class D.
