Customers have asked us several times about how to replace the diverter valve. Since mine recently failed, I decided to do a quick write up on how to do the install! Follow my Build Thread for more information on the B7 A4 2.0T.
Replacing your Diverter Valve is easier than most people think, and below are the tools I used.
Tools needed to remove DV:
1x Socket Wrench
1x 2" Extension
1x 5mm Allen Socket
The first thing you are going to want to do is remove your belly pan, once your car is up in the air (whether it be Jack Stands or a Lift).
Removing the belly pan requires you to loosen the plastic screws and you can use a Flat Head or Phillips Screwdriver to do so.
Once the belly pan is off, you can see the bottom of your turbo where your Diverter Valve is located. Take the harness and unplug it.
Once the harness has been unplugged, remove the three 5mm Allen Bolts from the DV.
Now, pull the DV out of the turbo (should come straight out).
Put the new Updated Diverter Valve into the turbo and tighten the 5mm Allens back up and torque them to about 8ft-lbs and plug the harness back in.
Now put the belly pan back on and you are done!
Here is a side by side shot of my torn Diverter Valve next to my new Updated OEM Diverter Valve. As you can see, the design totally changed removing the failure prone diaphragm with a upgraded piston style valve.
For those of you who are experiencing a loss of power/boost, you may need to change your DV! We offer the new updated one on our website for $54.95!
Click HERE for more information!
Let me know if you have any questions!
Jake
