Page 1 of 4 123 ... LastLast
Results 1 to 40 of 139
    Senior Member Three Rings vtwinjunkie's Avatar
    Aug 10 2013
    Various motorcycles
    NOVA
    B7 A4's 2.0T DEFECTIVE valve cover
    Its no secret that others have had issues with leaking valve covers. I have dont multiple searches and found nothing on "defective valve covers" so I wanted to bring this info to the community...
    My car was recently at the Audi Dealer for an oil consumption issue (among other things)...I went through a quart of oil in 800 miles.
    The dealer inspected the car and found evidence of a valve cover leak that was routing oil into the turbo down pipe and burning back through the engine...
    All very basic info that many of you know about these 2.0's and I recently learned as well
    What I find very interesting is the wording they used on the ticket when I went to pick up the car....they stated that the issue was caused by a DEFECT in the valve cover in one of the passageways which was causing it to re route the oil into the turbo down pipe....I have a 2008 and I find this interesting that if they knew they had a "DEFECT" why the hell didn't they replace it by now!!!
    Is anyone else aware of this DEFECT that is the supposed culprit? I only bring it up because I have done some research before posting this to make sure It is not common knowledge and I have seen posts of people replacing the valve cover gasket 2 and 3 times and still not fixing a "valve cover leak". seems like it is an issue with the "design" of the valve cover. Or at least thats how audi describes it.
    Just hoping to bring some new info to light about this common issue and If I can save someone time and money in parts I would like to help!
    I can copy the wording used on the ticket verbatim later today if it helps.
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    I actually talked about this a bit in my PCV thread towards the end in the troubleshooting section. I had a so called defective valve cover a while ago, the rear PCV passage came loose or craked inside and was sucking oil vapors into the intake ahead of the turbo.
    http://www.audizine.com/forum/showth...stem-explained
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    That is a whole bunch of oil to be loosing in under a 1000 miles. Shiro talked about the PVC breather that had possibley cracked. But OP your talking about the cover itself being defective? I have lost a bit of oil.....under a half quart in 5000 miles. I take that as pretty normal consumption. Vtwin was this an all of a suden loss of a quart? Or it got worse over time?
    Jul 26 2009
    DMV Area
    No I'm actually talking about the passage through the valve cover itself. I even posted pictures long ago with my old valve cover.
    - Chip
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by shiro1745 View Post
    I actually talked about this a bit in my PCV thread towards the end in the troubleshooting section. I had a so called defective valve cover a while ago, the rear PCV passage came loose or cracked inside and was sucking oil vapors into the intake ahead of the turbo.
    Very good write up! but I am not sure if I am having the same issue. My paperwork says that I had oil in the boost pipes. your write up talks about oil sucking into the the intake ahead of the turbo. I am not extremely familiar with the design of the motor yet but are we talking about the same thing?
    Jul 26 2009
    DMV Area
    Quote Originally Posted by vtwinjunkie View Post
    Yes, same thing. Air gets sucked ahead the turbo then it gets pushed by the compressor into the intercooler pipes, I'm guessing that's what he was refering to when he said boost pipes.
    - Chip
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Oil in the boost, or intercooler pipes, can come from two places: the turbo, or the rear pcv (breather). I've been dealing with consumption recently, and will probably replace the valve cover as my next move. I have a feeling it's the secondary oil separator in my case. I've had a lot of oil in my intercooler pipes, and did a vent-to-atmosphere setup that reeks of oil. It's no good. I want it all to be brought back to stock anyway to pass emissions and not asphyxiate myself, plus I've lost a bit of fuel efficiency without the vapors being burned by the engine.
    Chip knows his stuff, and the write-up he did only proves that point.
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Aug 10 2013
    Various motorcycles
    NOVA
    Oh I see! well good info none the less. thanks!
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by schnellboy View Post
    I am uncertain how long the issue has been there. I just purchased the car about 2 months ago. However I will def keep an eye on it and I am supposed to notify the dealer when the light comes on again. A consumption test they call it..
    Oct 29 2009
    Sold - 06 b7 2.0T a4 avant quattro
    Kitchener, On. Canada
    I think I had this same issue, was losing a quart in under 1000 km.
    The shop I deal with swapped the oem valve cover for a IE billet one and added a new catch can that vents to my downpipe.
    I've only done a few hundred km in the couple weeks since I got the car back, but it hasn't lost any oil yet.
    I'll call my shop tomorrow to see if he still has my old VC. If he does I'll check it out to see if there's anything wrong with and will get some pics if there is a problem.
    Sold - 06 B7 A4 2.0T Q6MT avant - BB
    Mods:Uni stg2 HPFP 91oct, KMD HPFP, ER SMIC's w/034 hoses, 034 TIP, 034 HFC, Custom quad-tip, a4 sport suspension, RS4 rear sway, RNS-E, RS4 carbon trim pedals & shifter, S4 Recaros, AWE vent mount boost gauge, Black RS4 look grill, Votex front splitters & side skirts, Ti window trim, S4 mirrors, LLtek LED headlights, DDM HID Fogs, Black 19" O.Z. Ultraleggera
    Oct 29 2012
    Montreal
    Got the valve cover replace about 8 week ago. No sign of burning oil anymore. Was a quart for about 3000km 08 a4
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Anyone have photos of a defective valve cover? I am curious.
    I have bad consumption, but perfect compression. Thus, must be losing it somewhere in the PCV.
    Jul 26 2009
    DMV Area
    Quote Originally Posted by PNW Avant View Post
    You won't see it unless you remove the VC, it's easy to check though. It's passage 1f-----1r. You can remove the PCV valve, block one end and blow air into the other, if it leaks air it's bad. That passage should hold air.
    And I actually I have some pictures of a bad VC somewhere but as I said you would only see it on the inside.
    - Chip
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Yes that's what I was referring to - inside photos.
    Jul 26 2009
    DMV Area
    This is the only one I found now.
    - Chip
    Aug 10 2013
    Various motorcycles
    NOVA
    I have my old valve cover still. Let me take some pics tonight an post them
    Senior Member Three Rings typeslone's Avatar
    May 09 2011
    06 A4Q 2.0T, 91 GTI VR6 Drag car
    North Jersey
    I have seen this happen with a few 2.0T's. I also see a fair amount of the 2.5 5cylinder vw's that need valve covers because the internal pcv valve goes bad.
    91 GTI VR6 - all motor madness 12.62@106mph and dropping.....
    06 A4Q 2.0T - Revo Stg2/APR HPFP/034 HFC/TT Downpipe/EuropaParts Exhaust/Eibach Springs/Bilstein Sport dampers/RS4 Rear Swaybar/Fluidampr/RS4 engine mounts
    10 WRX hatchback - Torqued performance Stg1/Perrin/Whiteline/Enkei BR7/The wifes daily is faster than mine!
    Caste Systems Performance
    Lugtronic
    Established Member Two Rings Bigcoryss's Avatar
    Dec 02 2011
    2009 Audi A3
    Baltimore, MD
    I have an 08 2.0T as well and had the very same issue. They never stated it was defective, only that it was leaking around the seal. I went in to the dealership because i was getting a low oil warning and they topped me off for free, diagnosed my issue, and proceeded to charge me 200 bucks to fix it all. I thought it was reasonable, but that could just be me.
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Sounds reasonable. I'm looking at getting a new valve cover this week for ~$200 from the dealer. It's not that much more expensive than online stores, and I'll be able to throw it in the car this weekend.
    Oct 14 2009
    Okinawa Japan
    It's a fairly common problem that I've seen on a lot of the silver Valve covers, not so many of the Black ones iirc
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Mar 24 2013
    Oakdale, CT
    Just another reason to get an aluminum one eventually.
    -Adam
    Nov 03 2012
    CA
    This is a lame question, but how do these come off? It looks like you just pull them with needle nose pliers away from the little tabs that stick into them. If so, will they go back on, of will that bend them out of shape?
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    Cut them. You'll need a new pair of clamps because those will be useless. One time use crimp clamps.
    Sent from my Throne using Crapatalk.
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Oetiker clamps. Great, but one time use only. There's a way to get a needle nose in there to release them, but if you have a set of side cutters, that'll do the trick too.
    Jul 26 2009
    DMV Area
    I stick a flathead screwdriver in from the side and twist left and right until the bent becomes loose, then you can grab the tip with pliers and remove it, I even used a lot of them again.
    - Chip
    Established Member Two Rings Sweir1171's Avatar
    Nov 02 2012
    B8 S-line Monza silver, B7 S-line Titanium stage 2+, Ducati M900, Suzuki RMX250
    Cleveland, OH
    Anybody had luck with replacing these VC's with a new OEM one? I have the same problem with blow out from 1f-1r.
    I just picked a new OEM VC and it looks like it's going to last maybe 5 minutes. The VC is from the dealer but it in no way reflects the German engineering i expect.... The plastic seems look almost super glued. I'm going to stop in and check out the other VC's they have in stock in the morning before I install
    Thanks - Steve
    [IMG][/url] Untitled by sweir1171, on Flickr[/IMG]
    Jun 27 2011
    Quote Originally Posted by Sweir1171 View Post
    Fixed the image for you.
    I might be ordering up a new VC for my B7 soon.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Nov 02 2012
    Cleveland, OH
    Thanks! Was working on that..... Ha
    Jun 27 2011
    I can't tell if that's normal or not, but maybe put a bead of rtv on there? Be careful though you really don't want to let rtv get into the oil system as it'll really gunk up the pickup tube and could cause blockages...
    -CP
    2017 Q7 3.0t
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Or maybe some super glue? That's disappointing to see mine is tight as a ship from 1f-1r, but I think there's a problem with it upstream. I'll be getting one in the next few weeks.
    Jul 26 2009
    DMV Area
    Quote Originally Posted by kaz02a4 View Post
    if passage 1f-1r is good I would not worry about the rest. There's nothing else that can fail since the other two ports 2 and 3 are not suppose to hold any pressure, they're one with the crankcase, 2-3-4 is all one and as you can see number 4 is an opening to the crankcase.
    I think you're just wasting money if you buy a new VC.
    - Chip
    Aug 10 2013
    Various motorcycles
    NOVA
    UPDATE****
    800 miles since the valve cover /valve cover gasket replacement and No oil loss.
    looking good so far.
    Nov 02 2012
    Cleveland, OH
    Awesome to hear! I stopped at the dealer yesterday and the other 6 VC's they had looked worse than mine.....
    Put the new one on last night. Crossing my fingers. Power feels more consistent across the board so far though!
    [IMG] Untitled by sweir1171, on Flickr[/IMG]
    Jul 26 2009
    DMV Area
    BEWARE!!!
    All of you guys who get the VC replaced at the dealership make sure somehow they use the same two screws that hold the coilpack harness in place. This is how I got two valve covers punctured through, they lost my screws and used different longer ones, they just went through the VC. So they messed up the first one and I did the second not knowing I had the wrong screws in there. Now I'm still running the new VC with the two wholes in there, I don't see myself paying another $200, anyway I'm venting to air and this causes no vacuum leak.
    - Chip
    Dec 19 2010
    Connecticut
    Oooooo good find!!! That could be a problem you almost would never know happened
    Powered by iPhone using Tapatalk -
    ll B8.5 S4 l 6MT l IE STG ll SP l Daytona Grey w/ Magma l Sport Diff l Black Optics l B&O l AWE Touring w/ non res DP l 19" AG M590 l Luft-Technik Intake l P3 Gauges l EuroCode SS l RS4 Grille l Carbon Valance l DeAuto Fogs l RSnav ll
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Maybe I'll try hooking up the regular pcv system on the original VC then? I just don't know what else it could be. I might just try running some heater hose down lower than where it vents to now, just to keep the fumes from getting in the cabin. Meh. The screws that hold the coil packs on is interesting though. I know one of mine is stripped, but it looks like a normal length screw.
    Veteran Member Three Rings abzoni's Avatar
    Nov 13 2010
    We can actually use GTI VC's, I'll report back when I get more mileage on the engine and see how it holds up.
    GT3071R, built motor, complete fueling system upgrade etc etc.
    Jul 26 2009
    DMV Area
    Quote Originally Posted by abzoni View Post
    Why would that be any different?
    - Chip
    Jun 27 2011
    Or just don't use the coil harness screws at all. I forgot to put mine in a long time ago. Meh. Hasn't caused any issues...
    Possibly cheaper?
    -CP
    2017 Q7 3.0t
    Nov 13 2010
    cheaper and more readily available in my area apparently.
