Originally Posted by
SlickMachine
Pressing the lock button on the remote should lock in the current settings, pairing them to that FOB. The memory buttons on the door are separate from the key FOB function, and no matter where the seats/mirrors are positioned, upon unlock with the fob, they will go to the position paired with that fob. I'm not sure if this is an Advanced Key function or not. Do you have advanced key?
I don't believe so... I have to put the key in the ignition. But I think the mirror does move back when pressing the unlock button... so maybe?
I also saw a thread about to set the memory for the fob you have to press which memory setting on the door you want to pair to the fob and holding it, then holding the unlock button on the fob you are setting it to for 2+ seconds and then it should save that setting to the key... but I'm assuming that's just seats. Apparently there's three different codings available for the memory controller, 1 for by last adjustment upon locking, 2 for paired using the method I just explained, and 3 for no memory.
