Results 1 to 32 of 32
    Apr 19 2012
    Tri State
    Bump...Squeak...Bump...Squeak...Bump...Squeak
    Hello fellow Azers. I have a question for you. Every time I go over any bump in the road in my B7 S4 I get a squeak/chirp sound that comes from the front of the car. It does not matter if I hit a slight bump on the right front tire or the left front tire -- it squeaks on both sides. I took to Mendham Audi (worthless dealership IMO) and they said everything looked fine and -- of course -- they could not replicate the sound on the road test. I know it may sound petty but the squeaking sound annoys me to no end. Any suggestions?
    Thanks in advance.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    check strut mounts and front sway bar bushings. You can spray some white lithium grease in the sway bar bushings and see if that works.
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    if it squeak put some grease technique... it may also be control arms as well as spring bushings
    19" BBS CK wheels, Bilstein PSS9 coilovers, 034motorsport front adj. control arms and rear swaybar, Vw Brembo 4-piston front brakes, b7 rear brakes, StopTech SS Brake Lines, Sprint Booster.
    Buy my parts PM me - for sale b6 s4 front brakes Tyrol sport stiffening kit, kW v1 coils. Usp front valance unpainted.
    Apr 19 2012
    Tri State
    Does anyone have photos of the spring bushings and sway bar bushings?
    Veteran Member Three Rings blackedoutt's Avatar
    Sep 16 2007
    B7 S4, MK1 TT, Tacoma
    Southern Indiana
    I also have this chirp that I haven't found either. How do you check the strut mounts? I also found that my upper control arm bushings are starting to tear.
    YEAH BUDDY!
    Veteran Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Upper strut mounts.
    Sent from my SGH-M919 using Tapatalk 2
    Mar 02 2013
    uk
    I had a very similar issue for quite a long while on my audi s4. I put mine up on the shop lift a few times to try and figure out wtf the noise was. All bushings and everything looked ok, so I thought it might be the upper mounts or something.
    Anyway, I ended up removing all plastic underbody trim to give the car a good clean, and found loads of dust/dirt/small stones stuck between the chassis and the side skirts. A very small line that i opened gently and got a hand brush to clean it all out. Stopped all squeaking noises! Was strange, but there was a load of crap in there. Might be worth giving that a try?
    Established Member Two Rings cobraBLACK's Avatar
    Dec 06 2010
    UK
    I have that and it's the brake pads rattling. My garage managed to stop the front one doing it but one of the rears is at it now.
    Give yours a look-see.
    Audi S4 Avant (B6, 2004) in Goodwood Green. V8, motherhubbards!!
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by biyitch View Post
    /\/\...would be willing to bet this is it. try applying the brakes lightly as you go over a section of road that causes the rattling...that will tell you if it is your brake pads rattling.
    Cheers,
    Jim
    Senior Member Three Rings yObOyGeo's Avatar
    Mar 13 2012
    Prius
    Boston, MA
    I have the same squeak .. Been dying to find out what the heck it is
    Sent from my iPhone using Tapatalk - now Free
    Established Member Two Rings tboo72's Avatar
    Jul 05 2013
    WI
    Any idea what the fix is? I think I have this.
    2013 S7 Prestige
    Active Member Two Rings Mokes's Avatar
    Oct 10 2006
    2010 Honda Element EX
    Downtown L.A.
    For me, it was the brakes as well. For a long time i had squeaking from my front end, thinking it was the suspension. When getting a tune-up, had them check the suspension for the noise, said suspension is fine. And of course could not replicate the noise. I finally gave up. Recently my brake pads wore out and also had to replace the rotors.
    Squeaks are now gone!
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    does sound like rattle clips on the brakes. had an identical situation earlier this year.
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    My 04 S/4 has no noise ...and my Porsche Tech ( friend ) who installed water pump and all related parts mentioned this.
    Your valve covers are leaking...I just finished R&R that. Took my time and feel good that I was able to do this.
    Back to your question, he also advised me that strut bushing and sway bar are gone / worn...so this coming weekend. He's going to take it to work and do this for me. Mine does not make noise, but it sounds like the heavy 4.2 simply wore those components out. Oh my S/4 only has 74k on it and I drive in LA where most if not all the roads are smooth.
    I hope this helps.
    0396
    Apr 19 2012
    Tri State
    Quote Originally Posted by FastEddie View Post
    I think you guys are spot on with this diagnosis because when I press the brake pedal over bumps in the road it does not make the sound. It is a certified car. Do I take it to the same dealer who could not get it to "replicate" on a road test or to another dealer and direct them to check the brakes? Or, do I try to correct it myself? Thanks.
    Established Member Two Rings seblove's Avatar
    Feb 28 2013
    los angeles, ca
    I had this problem too.. it's the clips on the brake calipers (part w/ the s4 logo on it)... you can either lubricate them and get rid of the noise for some finite amt of time (mine went away for about 8 months) or get new clips. For me it was a chirp from both front tires over any medium sized crack in the road, but it doesn't occur over speed bumps. Hope that helps
    Apr 01 2012
    Queens
    Quote Originally Posted by S4bmwslayer View Post
    You take it to whoever is cheaper. LOL its a "brake" problem and they will not fix for free. Or try doing it yourself. i paid 130 for them to fix it and resurface my pads.
    Established Member Two Rings snail_power's Avatar
    Mar 29 2011
    i have this same problem, sounds like a chirping going over bumps on both sides. Its very faint though, most people wouldnt notice. I will have to check those clips.
    01 S4 Avant 6spd
    00 2.8 Avant 5spd
    old:2007 Avant S-Line Titanium 6spd man (victim of rear end totaling)
    2006 S4
    Jul 05 2013
    WI
    Anybody have the part # for the front brake anti-rattle clips?
    2013 S7 Prestige
    Established Member Two Rings paul61's Avatar
    Mar 11 2013
    Waterloo, Ontario, Canada
    Thats what mine was.
    New pads and bingo..............noise gone.
    B6-S4 6M, Black on Black
    B5-S4 6M, Black on Black
    Senior Member Two Rings thomasskull666's Avatar
    Feb 11 2013
    St. Louis, Missouri
    Quote Originally Posted by tboo72 View Post
    8E0615269
    http://www.ecstuning.com/ES2063799/
    2007 Daytona Grey RS4
    Feb 28 2013
    los angeles, ca
    Quote Originally Posted by thomasskull666 View Post
    new ones would look so nice but hot damn they charge a pretty penny..
    Feb 11 2013
    St. Louis, Missouri
    Quote Originally Posted by seblove View Post
    It's ridiculous. Thinking about repainting mine to make em look like those. Would cost like $100 less
    Jul 05 2013
    WI
    Those are the factory clips???
    2013 S7 Prestige
    Apr 01 2012
    Queens
    Again i had the problem and Audi charged me 130 to sand and fix the situation. Its fixed and no problems.
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    These are the B6 factory clips >>> http://www.ecstuning.com/Audi-B6_S4-...aliper/ES6181/
    The clips with the S4 logo are factory B7 clips (both work for B6s and B7s) >>> http://jhmotorsports.com/products/pi...liper_Clip.JPG
    2004 Light Silver 6MT S4
    Mar 11 2013
    Fawwwkers!
    Wagner thermo-quiet pads = $75 / set.
    Installation cost = some elbow grease.
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Ive had a slow speed turning/brake noise for some time now, and sometimes when braking over bumps....Im thinking I may have bad clips. Mostly happens when turning right. What is it grinding against? The rotor?
    Apr 01 2012
    Queens
    Quote Originally Posted by paul61 View Post
    Fawwwkers!
    130 was fine for me. They were doing something else at the time (maybe oil change) so i didnt care too much.
    Apr 19 2012
    Tri State
    That is PRECISELY what my car does! I will try to lube them first. How do you suggest I do that? WD 40 with the long red stick to squirt it at the points where they attach? I think I will order new clips though.
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Has anyone done the rear brakes? Does the rear brakes have anti-rattle clips like the front? I'm asking because all of the clips are listed as front clips.
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Advanced Automotion has them for $50 a clip!
    http://www.advancedautomotion.com/pr...roducts_id=180
