Results 1 to 7 of 7
    Senior Member Two Rings mikeh14's Avatar
    Apr 30 2012
    San Diego, CA
    Removing side mirrors
    Does anyone have a DIY on removing the side mirrors? I had mine wrapped in gloss black vinyl, but it doesn't look very good. I think it would be a lot easier to do if the glass was out and the mirror was off the car. I found a DIY for removing the glass on an A4 (I assume it's the same on the S4) but can't find good instructions on removing the mirror from the car. Has anyone done it?
    2012 Phantom Black S4: S-Tronic - Sports Diff | AccuAir B8 Sport Kit | AWE Intake | AWE Exhaust | GIAC Stage 2 v2 | GIAC DSG Tune | AWE Pulley | AG M580 20x10 Brushed Candy Apple Red | StopTech 380mm BBK | Deval Carbon Diffuser | RS Grill | Red supercharged badges | 15% tint
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Apr 30 2012
    San Diego, CA
    Sweet.. that looks like it'll help
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    Move the mirror all the way down and towards the door (bottom right corner if driver side). You can see with a flash light that there are small tabs you can release with a screw driver and the mirror pulls right out. Unplug the harnesses and you are set. The rest of the housing just snaps apart but be really careful everything is plastic and it can be like doorcards, once you take it apart it never snaps together again quite as tight.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Apr 30 2012
    San Diego, CA
    Quote Originally Posted by PitchS4 View Post
    I don't think I'll take off the silver cap, just want to take the entire housing off the car and then remove the glass so the vinyl can get right inside behind the glass
    Senior Member Two Rings dreaddontdie's Avatar
    Jul 12 2011
    2018 S5 Sportback, 2014 Q5 TDI
    Chicago, IL
    would love to see pics when you are done
    current:
    s5 (2018, sportback, prestige, daytona gray, magma red interior, s sport, dynamic steering, driver assist, carbon atlas)
    q5 (2014, tdi, prem+, lava gray, nav)
    past:
    s4 (2012, prestige, moonlight blue, black/silver nappa, dsg, ads, sport diff, h&r oe springs, eurocode alu kreuz/sway bar/end links, michelin pss, milltek non-res, 034 & apikol mounts, giac stage II, roc-euro intake)
    Apr 30 2012
    San Diego, CA
    Best picture I've got so far:
    I'll get some closer ones next time I wash it :)
