Results 1 to 40 of 55
    Deactivated Three Rings
    Jun 08 2010
    The World's Fastest Audis
    Lathrop, California
    NOW AVAILABLE FROM JHM: B6-A4 3.0L Downpipes, ECU Tuning, and TCU Tuning
    We decided that since we've made you guys wait a long time already, we're just going to skip the whole group buy process and drop the price on our downpipes IMMEDIATELY.
    The retail pricing for our JHM 2.5" Stainless Steel Downpipes is $750. But as part of our official release and introduction to the JHM 3.0L program, we're going to start them off at a limited time introductory price of $695!!! This pricing is LIVE so navigate to our site using the links below to make your purchase!
    These downpipes will fit ALL B6-A4 (2002 to 2005) 3.0L V6 cars with Manual or Automatic (Tiptronic) Transmissions.
    JHM B6-A4 3.0L V6 2.5" Stainless Steel Downpipes:
    Why did we go with 2.5" piping diameter? We tested a few different piping sizes (2.25, 2.5, and 2.75) and found that in every configuration - stock ECU calibration with a stock sized (54mm) cat-back, stock ECU calibration with an aftermarket cat-back, JHM Tuned ECU with a stock sized cat-back, and JHM Tuned ECU with a stock cat-back - that 2.5 inch piping diameter provided the best gains in acceleration and high-end power without sacrificing low-end torque.
    If you are looking to unlock the potential of your 3.0L V6, these 2.5" downpipes are the key. They are an absolute MUST for anyone looking to get more power out of their car. Our extensive research has proved this point time and time again. When we put our 2.5" downpipes on a stock car, the car was impressive as compared to stock and the increased airflow of the downpipes definitely made the car seem a bit more "peppy". However, when we put the downpipes on a car with a JHM B6-A4 3.0L V6 ECU Tune on it, the result was amazing. The combination of the increased airflow from the downpipes and the ability of the JHM ECU Tuning to take advantage of that increased airflow completely transformed the power band of the car. The gains in low-end torque were good but the most impressive power increase can be found in the top-end of the RPM range. With the motor breathing more freely and the addition of our ECU Tuning, the 3.0L just keeps accelerating up top!
    The biggest gain in power comes from removing the huge catalytic converter complex that Audi has placed right up against the head of the motor, just after the outlet of the exhaust manifold. This inlet is INCREDIBLY SMALL. It's even smaller than the already tiny diameter of the stock exhaust piping. Look at these photos showing the ID of the OEM downpipe inlet and comparing the JHM Downpipe Inlet to the OEM Downpipe inlet:
    This next picture shows both the location and the size of the incredibly restrictive OEM Catalytic Converters. Yes, Audi has actually put two catalytic converters in that small space - the pre-cat and main cat.
    Look at the size and location of that cat! This drastically slows down the airflow coming out of the motor and creates heat right at the back of the motor - both of which are bad for making power. By removing the catalytic converter AND increasing the piping diameter to 2.5", we solve both of those issues! Actually, the inner diameter of the JHM Downpipe at the inlet is over 2.5 inches!
    Our JHM B6-A4 3.0L downpipes have a reducer at the end of the pipes that will allow you to run these pipes with a few different cat-back setups:
    - Stock B6-A4 3.0L V6
    - Stock B6-S4 Cat-Back
    - ANY Brand X B6-S4 Cat-Back designed to mate up to stock downpipes
    In our testing of different exhaust setups and in our experience with cat-backs for the B6-S4, we've found that all aftermarket cat-backs neck down to the stock piping size EXCEPT for the JHM-Fast Intentions 2.5 inch cat-back. So, if you have a stock cat-back or pretty much any other aftermarket cat-back, our JHM 2.5" downpipes will bolt right up to your system! Just secure your downpipe to cat-back connection with your OEM downpipe to cat-back clamps. If you need OEM downpipe to cat-back clamps, we sell them in our store. Just search for "clamp 54mm".
    **Note: If you are interested in running a full, 2.5 inch exhaust setup, we already have adapters made to connect our B6-A4 3.0L V6 2.5 inch downpipes to most FULL 2.5 inch B6-S4 Cat-Backs (i.e. ones that don't neck down to stock pipe sizing), including our JHM-Fast Intentions Cat-Back. Call us for details.**
    We will also be offering a set of 2.5" Stainless Steel Downpipes with High-Flow Cats. These can be found HERE.
    Our JHM ECU Tuning for the B6-A4 3.0L V6 can be found HERE.
    After a lengthy development period, we are excited to finally offer the JHM B6-A4 3.0L ECU Tuning. We went to great lengths to calibrate this tune to get the most out of your 3.0L V6 motor. Our tuning will completely change the performance of your car. You will experience increased and improved throttle response, increases in low end torque, and increases top end power. Our tuning also features our proprietary JHM Launch Assist feature! This is a great assist for those looking to launch their car easily and consistently, without any hassle. **NOTE: At this time, we only have a true Launch Assist for manual transmission cars. If you have an automatic/tiptronic car, consider purchasing our TCU tune which features an increased stall to help you get off the line faster.**
    Our JHM ECU Tuning you will give you noticeable improvements in the performance of your 3.0L. However, if you add our JHM 2.5" Stainless Steel Downpipes ON TOP of the ECU tuning, it will completely transform the power band of your car. If you are looking to unlock the potential of you 3.0L V6, these 2.5" downpipes are the key. Check them out in the Engine and Performance Section. They are an absolute MUST for anyone looking to get more power out of their car. Our extensive research proved this point time and time again. When we put our 2.5" downpipes on a stock car, the car was impressive and the increased airflow of the downpipes definitely made the car seem a bit more "peppy". However, when we put the downpipes on a car with a JHM B6-A4 3.0L V6 ECU Tune on it, the result was amazing. The combination of the increased airflow from the downpipes and the ability of the JHM ECU Tuning to take advantage of that increased airflow completely transformed the power band of the car. The gains in low-end torque were good but the most impressive power increase can be found in the top-end of the RPM range. With the motor breathing more freely and the addition of our ECU Tuning, the 3.0L just keeps accelerating up top!
    Please click on our product page and read the section "HOW TO GET YOUR ECU JHM TUNED" for information about getting your ECU Tuned by JHM. All ECUs must be sent to JHM at this time. We are working on gaining the ability to flash the B6-A4 3.0L V6.
    Our JHM TCU Tuning for Tiptronic Transmissions can be found HERE.
    The JHM TCU Tuning for your Automatic B6-A4 3.0 makes your Tiptronic Transmission shift faster and harder. We firm up the shifts to give a clean and crisp gear change that is faster and firmer than the stock characteristics but still not too abrupt. We feel our JHM TCU Tuning makes the car shift how it should have from the factory. It gets rid of the sloppy and slow slipping of the OEM TCU calibration and replaces it with firm, crisp, shifts. This allows you to get the most out of your Tiptronic B6-A4 3.0L by allowing you to put the power to the ground faster.
    Our TCU Tuning not only speeds up the shifting on upshifts JHM also modifies the downshifting characteristics and the behavior in "Tip Mode" to make the car more performance oriented while still being very streetable. We also improve the downshifting as well, we have been told it feels "less clunky".In our development for the TCU tuning we made a few different calibrations that could make the transmission shift harder, but we found that this made the car feel too much like and old muscle car, and less like an Audi.
    When you increase the power of the vehicle, the slipping and sliding of the OEM calibration will prematurely wear out the transmission. While it may be comfortable, the slipping of the transmission means that all of the clutch packs in your transmission are doing more work and slipping more, wearing out faster. The faster and firmer shifts prevent this wear by decreasing or eliminating the slipping.
    Similarly to the ECU Tune, the JHM TCU Tune must be completed at JHM. For information on getting your TCU tuned by JHM, go the the product page and read the section titled: "HOW TO GET YOUR TCU JHM TUNED".
    In addition to these items that we just released, we stock almost anything you could need for your B6-A4 3.0L V6! If you don't see what you need or want on our website, feel free to give us a call and we'll try and get you what you need as soon as possible!
    Again, thanks to all of our supporters who have pushed us to release these downpipes, the ECU tuning, and the TCU tuning. We wouldn't be where we're at now if it wasn't for your support online AND your support through purchases of oil change kits, spark plugs, air filters, and short shifters. Thank you for every 3.0L purchase - large or small - it all helps us to continue to release industry leading products for your vehicles.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    What' the size/cell density of the HFC that you're using? Also, any idea of how long you'll have the introductory pricing? I definitely want to get them and a new exhaust, but probably won't know if I can get them until the end of next month.
    Apr 04 2011
    2003 3.0 Avant
    Yorktown, Sterling VA/Bend, OR
    These going to fit an AWE cat back?!
    Oct 15 2006
    From a few to one...
    Arlington, VA
    i'm guessing that since the cat's location is changed, the rear o2 sensor will plug in just for show and the car will throw a CEL unless we get the tune?
    and just to double check, the downpipes fit cabrios, correct?
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Jun 08 2010
    Lathrop, California
    Quote Originally Posted by imnuts View Post
    The high-flow cats are the same that we've been using in our B6-B7 S4 Downpipes and Headers and our B7-RS4 Downpipes. They are a very high-quality, 300-cell, spiral metallic substrate.
    Quote Originally Posted by yorkcountydub View Post
    If your AWE cat-back is built for OEM B6-A4 3L downpipes or OEM B6-S4 Downpipes, they will fit!
    Quote Originally Posted by NyteEscape View Post
    You are correct on both questions. Based on all of the testing we've done, you'll really want to get the tuning when you purchase our downpipes. Yes the downpipes will make a big difference compared to stock downpipes but the OEM ECU calibration can only do so much with that increased airflow so you'll be leaving a lot of power on the table without the tune.
    The downpipes do fit cabrios.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Hey Guys,
    Thanks for the orders over the weekend! Your JHM 3.0L Downpipes and Maintenance items will be shipping out ASAP. We appreciate everyone's continued support and are happy to see that everyone is still excited about the program as much as we are .
    Jake
    Aug 12 2009
    Dirty Jerz
    For the video, do you have the resonated or non-res FI exhaust installed? Also, do you have any videos or sound clips from in the cabin to see how loud (or quiet) it is inside the car with the down pipes and exhaust?
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Makes me wish I would have bought that 3.0 avant when I had the chance instead of the 1.8T. Good work guys! The value here is when needing to replace the cats and add a few hp for less $$.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by coowhip View Post
    +1 for this.
    Active Member One Ring Blacksunshine's Avatar
    Jan 08 2011
    04 twin Turbo SVT Cobra, 04 F150 FX4
    Utah
    Price looks right on par with the quality IMO. I will for sure be getting thees along with the tune in the near future.
    I have a quick question for JHM on what the readiness monitor display for the cats after the tune. does it display ready, not supported,NA?
    Thanks and keep up the good work on the 3.0 JHM
    2004 Twin Turbo Mustang SVT COBRA 1025 RWHP
    2009 Silver A4 premium 2.0T Quattro - Wife's
    02 Audi A4 Quattro M6 3.0 - My daily
    2004 single Turbo F150 FX4
    Jun 08 2010
    Lathrop, California
    In all of the shots where the FI Cat-Back is installed with our downpipes, it is a resonated system. As for my clips, let me go through our archives and see what we've got. We should have something for you. At the least, I can run out and get you in-cabin audio from my car but it currently just has downpipes installed.
    You totally should have! Regardless, thanks for the feedback and let us know if you need anything for your 1.8T! We don't discriminate!
    Quote Originally Posted by Blacksunshine View Post
    Sounds good, Blacksunshine. Call us when you're ready to order. We'd love to get you setup. In our tuning, one of the best values (in addition to the performance aspect) is what we were about to do with the readiness. With the JHM tune, all the readiness tests are allowed to run successfully and show up as PASSED!
    Feb 02 2010
    I’m very interested in getting the JHM B6-A4 3.0L V6 ECU Tune or TCU. It’s my daily car and it’s too bad it can not be done without sending the ECU to JHM. I bet a lot of guys in the same boat as me. How soon can it be done (flash) at local JHM dealers?
    Aug 12 2009
    Dirty Jerz
    Quote Originally Posted by Keaton@JHM View Post
    Thanks, I'm not interested in a really loud system for my car, at least not yet. Videos don't sound like it's too loud outside the car, so I'd think it wouldn't be to loud inside either.
    Aug 26 2005
    Do you have a TCU tune for the 1.8T tip?
    Vorsprung durch Technik
    Nov 11 2010
    Rochester, MN
    Do I understand correctly that the JHM downpipes with the High-Flow cats actually contain real catalytic converters, just different from the OEM cats? Does that mean they contain a front and back O2 sensor for each cat? Do they trigger the CEL, which can be eliminated with the JHM ECU tune?
    Are the JHM downpipes with high-flow cats louder than the OEM downpipes? Are they liable to smell more than the OEM downpipes?
    Sorry for all the questions, but since I've got P0421 and P0431 I need to do something about my current cats on the car. Depending on the answers to my questions above, I might be interested in these.
    19" B8 S5 Peelers
    Aug 12 2009
    Dirty Jerz
    Quote Originally Posted by SlickFix View Post
    From the picture, the front/rear O2 sensors are right next to each other on both the HFC and catless versions, so you'd get a CEL for catalyst efficiency with either. Above they state that the HFC is a 300 cell density cat, same as the one used in their S4 & RS4 downpipes, so it's a read catalytic converter, not sure if it'd prevent the smell or not, but it shouldn't be as bad as completely catless.
    Jun 08 2010
    Lathrop, California
    diagnosticator - We don't have an off the shelf tune ready, but it is something we've worked with on one off projects in the past. To have something ready for a full release, we'd probably need a car at our shop for 1 - 2 weeks to complete the final minor aspects of the tune. I see you're in Seattle, WA. That's on the same coast as us, want to ship us your car for a bit???
    SlickFix - Our 3.0 DPs with our High Flow Cats are indeed "real catalytic converters". This is the same 300 cell, high-flow race cat we've been using on all of our exhaust products (B6-S4 Downpipes, Headers and RS4 Downpipes). They are a very high-quality cat.
    Yes and yes. Removing the huuuuge restriction of the OEM cat and enlarging the inlet of the downpipe increases the noise level of the exhaust as compared to stock. As you can see from the video, with an OEM cat-back, the downpipes sound aggressive, but not obnoxious or too loud. As for the smell, Audi designs those massive cats to be so big and so restrictive for a few reasons, one being to catch all of the un-burnt fuel and have the catalyst burn it up. While our high-flow cats will still "clean" the exhaust gases coming out of the motor, they're nowhere near as restrictive as stock cats so there will be an increase in smell.
    I hope I've answered your questions. It sounds like our downpipes with High Flow Cats might be for you. Paired with our ECU tuning, it'll get rid of all the codes associated with having aftermarket cats or none at all.
    From the picture, the front/rear O2 sensors are right next to each other on both the HFC and catless versions, so you'd get a CEL for catalyst efficiency with either. Above they state that the HFC is a 300 cell density cat, same as the one used in their S4 & RS4 downpipes, so it's a real catalytic converter, not sure if it'd prevent the smell or not, but it shouldn't be as bad as completely catless.
    Hah. I guess you beat me too this. And yes, we've kept the oxygen sensors in their OEM locations so you can still use the OEM style sensors and so we don't affect any of the air to fuel readings that get sent back to the ECU from the sensors.
    Feb 02 2010
    Quote Originally Posted by coolblue View Post
    Keaton, How soon can it be done (flash) at local JHM dealers?
    Aug 12 2009
    Dirty Jerz
    When I got mine flashed last summer, I sent it to them, it was flashed and back to me the same day it arrived at JHM. Total time out of my car was 2.5 days as I sent it via overnight and it was returned via overnight as well. I'm in PA, JHM is in CA, so not to bad for turn around IMO.
    Aug 31 2011
    Lathrop
    Flashing is something we definitely something we want to do for the 3.0L, as it has been successful for te B6-B7 S4, RS4 as well as the B5 S4. However there is no ETA as of now for when it will be setup and ready for public use.
    As of now we are just going to continue the Chipping Method, where you mail us your ECU. If you overnight it both ways, as stated above will only 2.5 days.
    Jake
    Aug 31 2011
    Lathrop
    Hey Guys,
    Just wanted to stop by and give everyone a huge thanks for all of the orders and support! We appreciate all of the Tune orders, Downpipe orders, and even the Oil Change Kit orders!
    Every order you guys place with us helps us fund the 3.0L Progam, and we appreciate it!
    Jake
    Aug 31 2011
    Lathrop
    Thanks for all of the orders guys! We have more sets built and in stock and ready to ship!
    Jake
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Is there any possibility in the future for something like this for the B5 2.8?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Jun 08 2010
    Lathrop, California
    Downpipes back in stock!
    Quote Originally Posted by fR3ZNO View Post
    fR3ZNO - I don't think we'll ever have a production set of 2.5 inch pipes for that car, sorry man. If you wanted to look into doing a custom setup of some sort, we'd be happy to help you out with that in whatever way we could.
    And to everyone else, just wanted to thank you AGAIN for the orders! Keep 'em coming! Our Fabricator just finished restocking our shelves and we have both catted and catless pipes ready to ship!
    Feb 09 2013
    WNY
    Depending on how costly something like that would be, I'd be very interested.
    I would imagine that the DPs would be very similar to a set for a B5 S4. Only difference would be the flange and maybe slightly longer in order to meet up to the exhaust manifold on the 2.8.
    Thanks for your response!
    Jun 07 2013
    16 A3 8V 2.0T Quattro Sedan S-Line, 15 A3 8V 2.0T Quattro Sedan
    Richfield WI
    2004 Avant 3.0 with Tip here. I like the ECU tune and the catless downpipes. Just a few questions.
    I see the 3.0 ECU tune options are for 91 or 93 Octane. Could you provide an 89 octane tune that would enable me to run the less expensive mid grade gasoline here in SE Wisconsin for everyday driving while still retaining the ability to run 93 octane when I would like some added performance?
    It appears that this tune still requires the use of properly functioning O2 sensors even with the catless downpipes, is that correct? Will the tune throw a code if an O2 sensor goes bad or will it always maintain a ready status for emissions testing status?
    I'm also curious if your 3.0 with Tip test sled is using the OEM TC or did you upgrade to an aftermarket TC like Revmax or Level 10? I ask because I'm having the upgrades performed in conjunction with a TC replacement to resolve the P0741 fault code. I'm leaning towards the Revmax since my installer has had some experience installing their product for a few drag racing clients and they have been impressed with the build quality and positive client feedback.
    Thanks~Mark
    Aug 12 2009
    Dirty Jerz
    Quote Originally Posted by wisconsinbrew View Post
    You need to keep the primary O2 sensor, and make sure it is functional, or the engine isn't going to run that well. I'm guessing that the secondary O2 sensors are still there, but it essentially ignores the readings for them as the only real purpose is for catalyst efficiency monitoring.
    Jun 07 2013
    Richfield WI
    imnuts, JHM got back to me with a response. Negative on an 89 octane tune and your assumption about the O2 sensors is correct. Never did receive a response as to whether they are using an OEM TC or an aftermarket upgrade in their 3.0 Tip test sled.
    I'm interested in the products, however, I can't find any dyno charts with hp and torque data for either the 91 or 93 octane tunes on any of the Audi forums or the JHM site. Nice videos but no hard data to base a purchase decision on.
    Thanks~Mark
    Jun 08 2010
    Lathrop, California
    Thanks~Mark
    wisconsinbrew - Thanks for the interest. DEFINITELY keep those primary oxygen sensors in the pipes. The secondary sensors also need to be installed for our tuning to run correctly. The ONLY codes we eliminate in the tune are the codes that would pop up for not having OE catalytic converters before the secondary oxygen sensors.
    And as for 89 octane you should really NEVER be running that in your car. The minimum you should run is 91 and ideally 93 if you can get access to it.
    In our tiptronic car, we had an OEM Tiptronic transmission in the car. While upgrades to your tiptronic transmission are a solid way to go, they are absolutely not required to run our tune on a tiptronic transmission that's in good shape. The key to getting the most out of those transmissions is servicing them. Replacing the fluid and filter can go a long way to extending the life of your transmission.
    Finally, I don't know what other hard data you need other than the fact that our B6-A4 3.0L V6 is the fastest one out there. In addition to the timeslips, our videos also give you some other hard data when we demonstrate how our car stacks up to other A4s with much more money spent on modifications and upgrades.
    Jun 07 2013
    Richfield WI
    Ordered the 93 Octane tune and catless downpipes. As long as the ECU was out, I decided to pull the TCM and see how much JCM can improve the slushbox shifting. Will have these installed along with the Revmax Level 1 TC and a pair of Magnaflow 14829 mufflers. Kinda of an early Christmas present.
    Aug 31 2011
    Lathrop
    Thanks for the order! I look forward to the review.
    Jake
    Jun 07 2013
    Richfield WI
    Reinstalled the ECU and TCM this past weekend. Initial drive impression, firmer shifting! Rev Max TC, new tranny filter, JHM downpipes and Magna flow mufflers being installed today/ tomorrow.
    Awesome packing job on the parts!
    Aug 31 2011
    Lathrop
    Awesome! I cannot wait to hear your full review!
    Jake
    Jun 07 2013
    Richfield WI
    Here in Wisconsin we have two seasons, winter and construction. It may be tough to do a decent review for another few months but we'll see...
    04 A4 Avant 3.0 Quattro Tip, JHM 93 ECU, JHM TCU, JHM Catless DP, Magnaflow, RevMax TC, AFE Dryflow. For sale
    15 A3 8V Quattro
    16 A3 8V Quattro S-Line, JB4, APR Intake, APR DP & Hi Flow Cat, Res Delete
    Jun 07 2013
    Richfield WI
    Thought I'd provide a brief update. My installer reported everything went fairly smoothly with the exception of the connection of the DP to the OEM exhaust piping. He had some concerns about obtaining a tight fit and resolved the issue by using some header wrap. Due to corrosion present on the oem exhaust piping he cautioned the longterm durability of the welds from the Magnaflow mufflers to oem piping may not be reliable in my situation. I plan to visit a local shop that has a mandrel bender to have a custom system fitted with the Magnaflows and some new less restrictive resonators and an x pipe. Right now with the JHM catless dp's and the remainder of the oem exhaust intact, the exhaust sound is no louder than with the catted oem dp's. I was a bit surprised as I was expecting a louder exhaust note without the cats.
    My butt dyno indicates the JHM ECU tune really wakes up the 3.0.
    Most noticable change is the JHM TCU tune. This tune is not for the timid. I'm not sure if it is the combination of the Revmax TC with the JHM tuned TCU or just the TCU tune by itself, but the shifting is noticably firmer and at higher rpm, especially the first shift when attempting normal driving. It takes some getting used to if attempting normal driving under 30 mph. If driving like you stole it is in your game plan, you will love the shifting properties when dropping the hammer. Merging onto the freeway is a whole new experience, love it!
    15 A3 8V Quattro
    Aug 31 2011
    Lathrop
    Thanks for the orders everyone!
    Oct 15 2006
    Arlington, VA
    Has there been an update to the ECU tuning to allow me to get flashed rather than send the ECU in?
    Aug 31 2011
    Lathrop
    Thanks for the orders everyone! We got these puppies IN STOCK and READY to ship!!!
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    While I don't have the JHM tune (I have Uni) and I made my 2.5 in downpipes myself, I still want to give the guys at JHM a thumbs up for all their hard work and time spent developing their 3.0 product line.
    I also would HIGHLY HIGHLY recommend the combination of ECU tune and downpipes. It makes a massive difference on these engines. Also, having made a set of downpipes on my own, I can say they're not easy to get right. Stainless downpipes for $700 are a great deal. I think I spent about $300 or so in materials to build it out of aluminized steel. If I had done it as a one-off in stainless, I would have been looking at $500+ in materials alone. So guys, I can tell you JHM is not getting rich making these pipes... However the fact that they are offering them at $700, to me, means that JHM is doing this because they sincerely want to advance the 3.0 platform.
    In any case, if we break it down, $700 for the downpipes (20-25 CHP) and $500 for the ECU tune (15-20 CHP) and TCU tune ($500) means that for only $1200-$1700 you'll be making around 255-265 CHP (220 CHP stock + 35-45 CHP mods). You won't see that on a 1.8T without upgrading to a Frankenturbo F21, and that's gonna run you $1850 for a bare bones install with no other supporting mods like exhaust or intercooler.
    Anyway, just wanted to add my 2c and give JHM props for taking the time and investing the money to prove what these engines can do.
    Established Member Two Rings truea4b6's Avatar
    Aug 27 2015
    md
    Catless 3.0 downpipe Still available for cabriolet ?
    03 b6 3.0 cabriolet all stock ( soon to be a beast )
