Results 1 to 33 of 33
    Established Member Three Rings BillyT's Avatar
    Apr 09 2013
    San Francisco
    Will these Eurpoean headlights on Ebay.co.uk fit my car?
    2005 S4 Cabriolet 6MT - Corsa Catback, Stasis Ohlins Suspension, VMR v710 19x8.5" Wheels, JHM Shifter Trio, JHM Intake Manifold, Throttle Body & Spacers, JHM "piggie" Downpipes, JHM Lightweight Crank Pulley, JHM Lightweight Front Rotors, JHM 91 Octane Tune, 034 Snub Mount, K&N Filter with Airbox Mod, 15lb Odyssey Battery, OEM Clutch - 1/4 mile: 13.6 @ 100 mph.
    Apr 09 2013
    San Francisco
    But even if the right hand drive thing is an issue it seems they can be found on the German Ebay too:
    http://www.ebay.de/itm/SCHEINWERFER-...item3f284ecee1
    http://www.ebay.de/itm/SCHEINWERFER-...item5d42da2eb3
    These are all in the $200 range whereas American venders sell them for over $1,400!
    http://www.ecstuning.com/Audi-B6_S4-...ght/ES2575395/
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    They will fit your car. Your b6 s4 should have came with xenon headlights from the factory. The difference with a set of rhd headlights would be the cut off. Since drivers drive on the opposite side in most of the European countries, the cut off plates will be positioned opposite of what we would see on us spec lights. You can easily remove the two phillips screws holding the plates and switch them from the left housing to right, and right to left. Kind of hard to explain, but in the US, the cut-off beam should be something like this:
    ____/____/ The slant being used to light up road signs on the right and not blind oncoming drivers on the left. While euro spec lights are set with a beam like this:
    \___\___ the slant being used to light up road signs on the left and not blind oncoming traffic on the right.
    source: personal experience with the ecodes on my b5.
    TEAM|AXION
    Apr 09 2013
    San Francisco
    BTW, my car is a B6 Cabriolet, so the headlights are different from the other models.
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Ill tell you guys what i know. On some helix/depo/oem projectors there is a flap that can change it. I don't remember how it would be done but you could make it work with fiddling with the projectors. however i would just buy these:
    http://www.ebay.com/itm/190819632248...84.m1439.l2649
    ive put them in two cars of mine and the look and work great. Finding the bulbs for them is a bitch... side from that no complaints here.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Apr 09 2013
    San Francisco
    Quote Originally Posted by jeffrey146 View Post
    I don't like the way not all 3 of those are circles.
    What about how my current headlights auto-adjust themselves every time I start the car?
    Mar 26 2005
    Quote Originally Posted by BillyT View Post
    lol..the headlight itself may be different from other models, but it's the same concept. Depending on what those ebay sellers are including or not including with the headlights, you may have to take off the leveling motors from your own headlights in swap it into the new headlights. Use the search button; you may find some more info regarding the flap/plate from other b6'ers.
    TEAM|AXION
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Be very careful, most sedan parts will not fit the cabrio. However, since the code is 8H and not 8E, there is a chance that they will fit.
    The ebay.uk link you posted should fit, but they are for halogen headlights and I'm assuming you have the bi-xenon?
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Apr 09 2013
    San Francisco
    Are Americans actually able to sign up and make purchases on European Ebay sites?
    So it seems the British ones have the reversed side of the road issue and aren't bi-xenon.
    I really don't totally understand everything about the self adjusting factor either.
    It looks like the German ones have no orange to the blinkers at all. Isn't that a US requirement?
    Feb 19 2012
    Draper, Utah
    I really dig them. Guess that just me though.
    ...BBK coming soon
    Apr 09 2013
    San Francisco
    They're not bad, but the non-complete circle things still kinda bugs me. I also don't see any cabriolet specific version anywhere.
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by speedydragon View Post
    Since drivers drive on the opposite side in most of the European countries,.
    Just to clarify here, there is not a country in the EU that drives on the left hand side of the road (RHD car).
    Having driven RHD cars with RHD lights on The right side of the road I can tell you that it is far from ideal for both you and oncoming traffic.
    Cheers,
    Jim
    Apr 09 2013
    San Francisco
    Quote Originally Posted by LJH View Post
    Cheers,
    Jim
    Yea, I was gonna point that out. Think the UK is one of the only ones like that.
    Apr 09 2013
    San Francisco
    Quote Originally Posted by R&Cs4 View Post
    What about the German ones? The text on the page says "Lighting: Halogen & Xenon"
    http://www.ebay.de/itm/SCHEINWERFER-...d=520541815700
    http://www.ebay.de/itm/SCHEINWERFER-...d=520530485904
    Oct 03 2006
    Actually more countries then not, world wide, drive on the left hand side of the road.
    Cheers,
    Jim
    Apr 09 2013
    San Francisco
    Cheers,
    Jim
    In Europe I mean.
    Senior Member Three Rings CDN_S4's Avatar
    May 24 2013
    Rainbows and Unicorns
    NB Canada
    In Europe, England is the only one to drive on the left hand side, or how we like to think, the "wrong" side lol. Who else besides Singapore, Japan and the UK drives on the left?? Australia?
    Car History: 2007 GLI, 2001 A6 2.7T, 2007 GTI, 2004 S4
    Veteran Member Four Rings troyguitar's Avatar
    Feb 03 2013
    2004 Z06
    PA
    Places that used to be part of the British Empire
    http://en.m.wikipedia.org/wiki/Right...t-hand_traffic
    Sent from my SCH-I545 using Tapatalk 4
    2004 Z06
    2001 allroad gaytronic - Sold
    2008 TT 3.2 DSG - Sold
    2006 S4 Avant MT6 - Sold
    Apr 09 2013
    San Francisco
    Has anyone on here actually done this or does every one just either buy the $250 types jeffrey146 posted above or pony up for the $1,400 ones in the ECS link I posted above?
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    You might be able to just swap the projector assemblies from the left headlamp to the right, and vice-versa. That's what we basically did on my friend's WRX ProDrive headlamps that came from Europe.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Apr 09 2013
    San Francisco
    Thanks man. But so what happens every time a Brit goes on "holiday" to some EU destination?
    Veteran Member Three Rings Whatset's Avatar
    Dec 02 2008
    Jeep & a Vespa
    Left of center
    Quote Originally Posted by CDN_S4 View Post
    The thriving empire of Turks and Caicos does.
    Oct 03 2006
    You get these:
    http://www.motoring-into-europe.co.uk/faq.html
    In the old days before projector lamps you could just use black electrical tape strategically.
    Cheers,
    Jim
    Established Member Two Rings tboo72's Avatar
    Jul 05 2013
    WI
    Im thinking of getting ecodes but since Im not the original owner I have no idea if my car has them already. Is there any easy way to tell?
    2013 S7 Prestige
    Apr 09 2013
    San Francisco
    I just realized that B6 headlights have a dark gray or black background but they changed it to silver or chrome for the B7.
    I wonder if there's silver/chrome ones available for the B6 and if they would look better or worse. Anyone got such pics?
    Perhaps those Valeo ones are the only option for silver/chrome on the B6.
    Apr 09 2013
    San Francisco
    Veteran Member Three Rings Brettannica's Avatar
    Oct 14 2012
    2010 Audi A4 Avant
    Perth, Western Australia
    According to the description, If your car is an 02/2004 - 12/2005 then they should fit.
    It looks to be just the housing with no internals.
    I'm assuming Latvia is left hand drive?
    Sent from my GT-I9305T using Tapatalk 2
    In The Garage: B7 S4: JHM Tune Carbon Fibre: Vis Racing Hood, Relak Skirts & Paddle Extensions, Blades, DTM Deck Lip : 034 Snub & Bracket : JR Air Filter : H&R Springs : F.I. Catback : Gunmetal 19” 6RS V10’s • B8 A4 Avant: BSR Bling : 19” 4RS V10’s : V-Tech Chip
    Previous Rides: • E32 BMW 740i • E36 BMW 325i • B5 A3S • B6 A4 • Ford Falcon 351 • Triumph TR8 • Vauxall Super Tourer • Saab 9-3 • Saab 9-5 • Toyota Prado 4x4
    Oct 19 2009
    You really want to spend $900 on headlights? Search for the orange reflector removal DIY, you'll come out with pretty much the same result.
    '11 S4 6MT
    '58 Auto Union 1000
    '54 Corvette
    '64 GAZ 69M
    Atlas R-Line
    IG @this_is_r0b
    Oct 03 2006
    Far from the same result....E-Codes give you much better lighting.
    Cheers,
    Jim
    Oct 19 2009
    Cheers,
    Jim
    That may be true, but the question is if he's going for better lighting or just the visual pleasure of not having the reflector. If it's the latter, then pulling the reflectors make more sense than spending $900.
    '11 S4 6MT
    '58 Auto Union 1000
    '54 Corvette
    '64 GAZ 69M
    Atlas R-Line
    IG @this_is_r0b
    Apr 09 2013
    San Francisco
    I've searched plenty and found the going consensus is that the reflector removal DIY is impossible on cabriolet specific lights.
    Apr 09 2013
    San Francisco
    I also would like to switch from having a black background to a chrome or silver one plus better lighting is always a good thing.
    The ad also says "Without ballast, levelling device, without bulbs, self levelling system, HID low/high beam + halogen low beam"
    So how much of that can be used from my old lights and how much needs to be sourced and from where and at what kinda price?
    Apr 09 2013
    San Francisco
    Who is Valeo anyway? A third party vendor Audi rebadges as OEM? And if so can I just order stuff from some website that stocks all their stuff?
