Results 1 to 8 of 8
    Established Member Two Rings FastMoneyPlaya's Avatar
    Mar 18 2010
    S5, A4 and GL350 Bluetec
    East Coast
    Scan Code 00870-168 DTC Definitions not found! ???
    My ENGINE LIGHT went on in my 2010 S5, so I bought an Autel scanner which is supposed to read Audi CAN BUS codes. I got this message and cant figure out what it means - an no help from the Autel web site either:
    00870-168
    CAN BUS
    DTC definitions not found! Please refer to vehicle service manual
    This is the scanner I bought:
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Thanks
    2010 S5, 6spd, Prestige, B&O
    Mar 18 2010
    East Coast
    I found the answer. This is what the manufacturer replied to an e-mail I sent:
    Thanks for your recent inquiry.
    VAG405 is a very old model, so your car, 2010 Audi, may not be included.
    Lesson learned - I need to find a scanner that works with my car...
    Aug 04 2010
    Queenz/Westchester
    Where are you located? You can get it scanned with Vagcom
    Mar 18 2010
    East Coast
    Quote Originally Posted by shonseb View Post
    CT... I saw Ross-Tech has a good system, but I don't want to spend $299 for it - I just want something simple to read codes - nothing fancy
    Aug 04 2010
    Queenz/Westchester
    Just find someone in your area:
    http://www.audizine.com/forum/showth...VAG-COM-Owners
    I'll do it for free if you come down to NYC
    Mar 18 2010
    East Coast
    Thanks for the generous offer. I'll let you know if I'm in Queens. In the meantime, I'm just gonna take it to the dealer as I am still under warranty.
    Aug 04 2010
    Queenz/Westchester
    No problem, I'm actually in Westchester often. If you need anything done, just PM me!
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    Lathrop, CA
    If you got us the code and info from vag-com VCDS we could give you some help.
    Ross-tech has been the standard for a long time we have 2 cables here for our shop and office. We have been using them since 2005. You can pull codes on ALL modules, reset service reminders, reset codes and log data.
    http://www.ross-tech.com/vag-com/index.html
    You can actually use it to "tweak" you car some as well. We have been doing since the B5 models, all though the newer cars you can customize more from the car option in the console the pre B8 cars required vag com for those tweaks.
    More info on that here -> http://www.ross-tech.com/vag-com/cars/audiB8.html
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
