Results 1 to 19 of 19
    Established Member Two Rings tacticsfirst's Avatar
    Sep 04 2011
    Twentynine Palms, CA
    Power Steering Aeration Problem. BUBBLES BUBBLES BUBBLES!!
    So, I had my car SMOG tested and I passed with flying colors. But, as I was leaving the shop I noticed my ps pump was making a lot of noise and my steering was very loose. I popped the hood and behold ps fluid all over the drivers side engine bay. I opened the ps reservoir cap an the fluid was very frothy. As a precauition I changed the ps return line with the banjo fitting that goes from the steering bar to the cooler. I added mineral ps fluid and bled the air out of the lines by jacking up the front end and turning the steering wheel from lock to lock slowly about a million times. After a final top off of the fluid to the "M" in Max on the dip stick, I started the car up. It was good for about 30 seconds then the noise returned and the froth came back.
    Has anyone had this issue? I have seen a lot of A4 threads on this issue but have not seen much on the S4 side. If anyone can tell me whats up with this It would be much appreciated.
    Evil Monkey Is Watching You!
    JHM 91 Tune, Piggy DPs, Magnaflow catback exhaust, JHM Short Shifter, Stern Motor Mounts, Stern Snub Mount. Hotchkis H-sport front and rear sway bar. 034 adjustable upper control arms, Bilstein PSS9s, Kenwood DNX7190hd Navigation Headunit. Ummmm... WeatherTech Floor Mats.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Sounds like the pump might be cavitating due to an obstruction?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Sep 04 2011
    Any way to purge the pump other than rotating the wheel. I have done the process first with the engine off and also with it on.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    To properly bleed the power steering you want to leave the cap off.
    Then start the engine and turn the steering wheel back and forth like two times. Then shut the engine off and wait for the bubbles to go away. Repeat until all the bubbles are gone. If it takes more than like four tries then you still have an issue.
    A lot of people leave the power steering fluid cap on while trying to bleed out the air and the tiny vent hole is not enough. I have seen the rubber lines around power steering pump start leaking from age and they allow air to be sucked into the pump but that problem is much more common with the older 3.0 V6s.
    Sep 04 2011
    I'll give it a whirl jimmy. I had the cap off for the process every time bit your suggestion is just different from the ones I have tried so thanks.
    Sep 04 2011
    Well, I did it 4 or five times and no bubbles. Then I turned the car on and let it idle and after about 1 min it started aerating again.
    Sep 04 2011
    I have ordered a new reservoir from ECS. It seems like my old one may be trapping bubbles behind the filter screen. I'm going to do a complete flush as well. It sux not being able to drive my car.
    I know if I take it to a shop the labor hours are going to kill my wallet. I hope this fixes it.
    If anyone knows a problem location for air to get sucked in please share your knowledge. I'd rather buy a hose clamp then keep messing with this mess
    Veteran Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Quote Originally Posted by tacticsfirst View Post
    I am on the same sinking boat with you. My p/s started to have those symptoms and now its leaking bad from somewhere in the pump area. I am going to replace some hoses and the reservoir.
    Sent from my SGH-M919 using Tapatalk 2
    Sep 04 2011
    I think I would rather have a leak like you. I don't have a leak that I can find, but then again all the fluid that bubbles out of the reservoir would make it hard to find. I don't even know what I am looking for. If you are replacing the return line from the rack to the cooler, it took me about an hour. 22mm open end wrench for the banjo fitting. If you figure it out, let me know.
    Aug 01 2009
    Houston, TX
    This will be the third time I do it on two seperate cars. I already replaced the return hose and I am starting to think thats the issue I have again. I have posted on a seperate thread about this issue. Did you reuse the washers on the banjo fitting?
    Sep 04 2011
    I did reuse the washers, it was completely dry up by the rack so I think they were still good
    Aug 01 2009
    Houston, TX
    When you turn your wheel does the return hose flex? Like it does not have enough fluid moving through.
    Sep 04 2011
    Quote Originally Posted by S4King View Post
    Which return, the one going to the reservoir or to the cooler? Id have to get one of my friends to watch.
    Aug 01 2009
    Houston, TX
    Sorry meant the hose from the pump to the cooler.
    Sep 04 2011
    Ok! So! I think it is fixed. I replaced the reservoir and flushed the fluid really well. No more noise and no more frothing.
    I don't know which remedy was the cure, I would suffice to say it was the old fluid. I'm not the first owner of the car and who knows when the last own flushed it if at all. 115,000 mi on it currently, the fluid might have been that old.
    Thanks for everyone's help. Now, does anyone know how to get rid of the tacky oily mess under my hood?
    Apr 24 2009
    Frisco, TX
    Steam-cleaning, or a lot of degreaser.
    Sep 04 2011
    Thanks dparm. I'll get at it here shortly.
    Aug 01 2009
    Houston, TX
    Glad you got it fixed. I am still having issues with mine. Fluid is now squirting out of the hole of the reservoir cap. Got a new res ordered but I think the hose coming from the cooler to the tank is not good.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    good to hear you solve the issue. my S4 had a similar issue and a good fluid flush solved it for me.
