Results 1 to 40 of 74
    Senior Member Two Rings jmswashere's Avatar
    Jun 27 2013
    St. Augustine, FL
    Things you probably want to get looked at when you buy a used 2008 S6
    Here is some information for the commitment it entails after purchasing a used 2008 S6 with approx 50k miles on it.
    In December 2012 I bought a used 2008 Audi S6 in Phantom Black with the Technology Package, and 46k miles. I bought it online, without ever test driving it (from 10000k miles away), because I knew after doing the research this was the car I wanted, needed, and deserved.
    I knew that there were virtually no after market parts to set my wallet on fire, and I knew that it was big, powerful, safe, and ate through gas like nobodies business.
    But there were problems. No used car purchase is perfect, especially one prone to high amounts of carbon build-up. When I was finally able to drive the car in April 2013, the first week I drove it, a CEL came on. After taking it to the dealership, they said it had popped for multiple misfires. Which was no surprise with all the research I had done previously. I had made sure to change the oil, and all 4 tires as soon as I bought the car, and run octane booster and fuel cleaner through a few tanks of gas (no dice with the CEL).
    So this prompted my first visit to the Audi Dealership: I mentioned carbon build-up, but no one there was really taking me seriously, or wanted to spend the time to do the cleaning, so I just let them do their thing.
    1. Carbon Buildup: I knew this would be my main problem with this car, just because it was a previously leased car, probably driven by someone who didn't appreciate that this car was built to be driven hard and taken care of. They probably didn't know that you should only use top tier gas (preferably without ethanol (which is impossible to find)), get oil changes every 3k miles (even with synthetic oil), and run octane booster and fuel cleaner additives through the gas every other tank or so. The dealership said that this was one of the worst cases of carbon buildup they had ever seen (after they finally bore scoped the engine). So here we go...
    2. Oil Separator: This is what the dealership came back to me as the cause of the problem for the first visit. Which is understandable due to all the sludge from the carbon buildup going back through and gunking up everything. But I knew that wasn't the real culprit.
    I got the car back, and it threw another CEL on the way home from the dealership... not unexpected. So I took it back again.
    3. Fuel Injectors: I knew these were bad just due to the nature of the carbon build-up on the valves, ports and intake.
    So this time, I had a sit down with the Audi Service guys, and told them I wanted to do it big time. I wanted to try and get everything fixed at once. So I finally convinced them to bore-scope the engine for carbon deposits and anything else messed up. I also had them walnut blast the intake manifold, valves, and ports for carbon build-up. Later on some other things popped up as well...
    4. Starter: After getting everything back together while doing the carbon cleaning and replacing the injectors, the techs fired the car up, and promptly blew the starter. They tried to act like it was no big deal, but do to it being their fault, I had them spend the 2k in parts, and 20 hours in labor to fix it. So check your starter... before it blows up in the shop.
    After getting the car back, I drove it home... and low and behold, another CEL popped on. Again back at the dealership, and doing mountains of my own research, I felt like I knew what was going on.
    5. Spark Plugs and Coil Packs: After this CEL came on, I switched service managers at the dealership to a much more personable and knowledgeable person. He said he was tired of having my car in the shop, because it was such a pain to work on. So I asked him to do everything in his power to make sure he wouldn't see it again (and bought him some awesome Vodka). So after replacing the Spark Plugs and Coil Packs, again checking for any missed carbon buildup, looking for any missed software updates, or additional problems, it appeared my car was in tip top and healthy shape... but not just yet.
    After driving around for about 3 days without a CEL, it came on again... but not in the usual fashion during mid-range RPM acceleration. This time, it just popped on... but after having my car in my hands for about 2 weeks of the 3 months I had been able to drive it, I said "F" it, I am just going to drive it for awhile, and that's precisely what I did. There were no problems, no lags in acceleration, no warbling or stalls during a cold start-up, or flashing of the CEL in the mid range RPM acceleration. But I was still uneasy. BUT, before I could do anything about the CEL, my passenger side tail light went out.
    6. Tail Lights: At around 50k miles, apparently both LED tail light assemblies like to blow out. BUT NEVER FEAR! For it's not the WHOLE tail light assembly, it's just the board behind the red case, that holds the bulbs. So don't let anyone rip you off in saying that it's 450 dollars for a new tail light, when in reality, it's only $136 for the bulb holder, where the prongs burnt out. I forgot to mention... but the drivers side tail light had went out 2 weeks after getting delivery of the car, and my wife got ripped of by having to buy a whole new tail light, which was probably the same exact problem. It pays to give Vodka to your service representative.
    Anywho, at the dealership, I had them run the code for the CEL, thinking for certain it would be another misfire code... BUT IT WASN'T (Hooray?!); It was actually a deficiency in the right bank catalytic converter. I was slightly puzzled by this, but after some digging, found that the cats are probably not up to par due to the amount of fuel that was not ignited because of the misfires, and was leaking down into the cats, causing damage when ignited there, or if it just sat there.
    7. Catalytic Converters: I haven't taken my car in yet, but I will next week, and hopefully I will get the cat replaced and not have any problems for a while... I will keep everyone posted. (UPDATE: The cat was replaced under warranty, but apparently a $350 O2 sensor was not covered... Yay me).
    8. Fuel Pumps: During a routine drive back home from work, and during decent acceleration, the was a noticeable jolt and then a loss of acceleration with the gas pedal depressed. The EPC (Engine management) light popped on first. I stopped the car, turned it off, and back on to see if it would clear the code, and then as soon as I started to accelerate again the EPC popped on, this time followed by the CEL. I drove the car straight to the dealership, because I didn't feel comfortable driving the car. After 2 days, the dealership got back to me, saying that the fuel pumps were bad; They were gunked up from all the carbon in the engine. The dealership replaced both high pressure fuel pumps under my USAA extended warranty in only 2 days. Excellent!
    Now the car is running fantastically, with no problems at all. With basically all new components in the engine, it pulls like Hell's Horses.
    P.S. - I finally had some maintenance pop up on the car: Had to replace both front brake rotors and pads= $1k. That hurt my pockets...
    My S6 is at 53600 miles now.
    Another problem/Update:
    9. EGR/Combination Valves: After driving around for about a week or so with a VERY rich gasoline smell wafting into the cabin and a CEL on, I decided totake the S6 into the dealership. Luckily I did, because when I started it that morning, the gasoline smell was stronger than ever, and there was smoke coming out of the drivers side headlight from the lower drivers-side of the engine bay. There were no problems on the way to the dealership. This was caused by the before said ridiculously insane Carbon Build-up.
    During the week I drove the car with the CEL on before taking it into the dealership, there were no problems besides the above mentioned and a big decrease in gas mileage. I never did figure out where the smoke came from, but I figured the gasoline smell was from the engine running rich. If anyone has any advice onto why all that would of happened, please let me know.
    The cost of 2 EGR valves, and the associated hardware... AND labor... is a whooping $1200.00. And the big reason for that is because apparently the majority of extended warranties (explicitly) don't cover EGR valves for some god forsaken reason. I guess you can get an extra emissions warranty or something to cover those, and o2 sensors, along with other bits and ends.
    HOPEFULLY... This is the last thing I have to do for awhile that's related to fixing the Carbon Build-up in the car. Let's cross the fingers!
    10. Torn front passenger CV axle boot; All 4 control arm bushings are bad (possibly having to replace all front suspension components: Control arms ect...).
    The dealership is quoting me 8 hours of total labor just for the 4 bushings (4 hours each side). That may be a misunderstanding from the dealership, but I will figure it out and update the info as I go. My USAA extended warranty said they would only cover half the labor... so I am trying to figure that out as well.
    The car was finished up today. To anyone, anytime, please get an extended warranty through somewhere. TOTAL: $5500.00= me paying $1500.00 for some uncovered labor and wheel alignment.
    What started out as a simple alignment and wheel rotation, I felt a bit more wobbling during hard cornering... And then the O2 sensor CEL popped on and stayed on finally. Here's a list of shit I found wrong and working with the dealership, got fixed:
    - All 4 front control arm bushings were replaced
    - Front passenger side cv axle boot was torn... Ended up replacing whole axle (under warranty) to be safe, due to damage
    - Bank 2 O2 sensor replaced
    - 2 coil packs replaced because of misfires.
    Since owning the car-
    TOTAL OVERALL COSTS: $25,000
    TOTAL COVERED BY WARRANTY: $22,500
    PRICE OF WARRANTY: $4,000
    11. So after being gone for about 6 months, I had some new problems heap up:
    - Drivers side headlight needed to be replaced.
    - 2 vaccum hoses were cracked causing bank 1 and 2 to run lean and a CEL to pop, leading to below:
    - One of the throttle body valves were stuck open; and upon further investigation USAA recommended that the whole intake manifold (and the associated throttle body housings??) needed to be replaced (probably because of prior carbon build-up).
    I am currently getting the diaphragm going to the throttle bodies and 1 vaccum hose replaced to hopefully stop the leak. The intake manifold and the labor is being covered by my USAA warranty (about $2k), but the hose and the associated labor for that was a bit to much for USAA... so I have to pay $565 out of pocket...
    Yay me... but still, this car is redonkulous sometimes.
    My dealership service guy said that the diaphragm going to the throttle bodies was going to be replaced, not the entire intake manifold... I am not entirely sure what that part entails, but he said just the part was around $1k. Luckily USAA took care of that for me, but I still owe $565 to replace a cracked vacuum hose and the associated labor; (they had to pull off the bumper to replace it).
    Money: At the time of purchase I also bought an extended warranty through USAA for $4k , entailing complete coverage (except for lights and regular wear and tear) over 36k miles/3 years, with no fees or anything when filing a claim. I have spent about $5k total for: tires, oil change, carbon cleaning, and some extra labor that wasn't covered by the warranty. BUT, it the grand scheme, I paid that much, instead of paying the full amount of approximately $25k in diagnosing, labor, and parts that I would of if I had not purchased an extended warranty.
    So please, use this FYI, and if you have any questions, suggestions, or pointers, please don't hesitate to let me know.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Wow. Pays to have a good warranty!
    Have you thought of deleting your catalytic converters instead of having it replaced?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by LINDW4LL View Post
    I will once I don't have a warranty anymore. :D
    Sent from my iPhone using Tapatalk - now Free
    Current: 2023 Audi RS6 Avant - Daytona Grey; CCBs; Carbon Optics; AWE Exhaust; OEM RS6-P Bronze Wheels; APR Intake
    RIP: 2020 Ford Mustang Shelby GT350; 2017 SRT Jeep Grand Cherokee; 2014 Audi S4; 2015 Dodge Charger SRT 392; 2008 Audi S6; 2006 Nissan 350Z
    Active Member Two Rings Wake's Avatar
    Aug 12 2013
    07 Cadillac STS-V, 07 Cadillac Escalade AWD, 03 Cadillac Escalade EXT, 96 Corvette LT4
    Stafford, VA
    Quote Originally Posted by jmswashere View Post
    Wow, now that's a high maintenance vehicle!
    Really? Synthetic oil changes every 3K miles? Does the engine have a lot of blowby built into the design?
    I'm used to GM vehicles and from experience on the Northstar engines the carbon buildup problem was an issue due to putting a high performance engine into a "grandpa car" that was never exercised. On the Northstar a Cadillac engine engineer told me to probably once a week run a hard WOT on it getting onto the freeway. That cured any carbon buildup inside the engine. His instructions were to flog it hard as many times as it took until you couldn't see a brown cloud behind you anymore usually 3-5 times. That did the trick, no more carbon buildup problems. On a side note, it was an entertaining thing to do to a person tailgating you in the right hand lane at night. If I didn't do it in awhile I'd gas out the guy riding my bumper. They back off nicely when the thick cloud comes out the pipes, not quite what a diesel engine does on a truck but a nice thick cloud of gunk for them to enjoy. LOL!
    And gas additives in addition to top-tier gasoline? I would think that might do more harm than good. I don't trust putting things in my tank off the shelf that claim to do these extra things that top-tier gasoline won't do.
    2005 Audi A6 4.2L S-Line
    2007 Cadillac STS-V
    2005 Cadillac Escalade
    1996 Chevrolet Corvette LT4
    1998 Oldsmobile Aurora
    Veteran Member Four Rings ebi718's Avatar
    Oct 29 2011
    2009 A8 L
    Brooklyn, New York
    Interesting post; thanks OP. There's always the (valid) argument for extended warranty. As for additives/octane booster, etc, I am also wary of putting some unknown fluid into my engine/fuel tank.
    Sent from my SPH-L720 using Tapatalk 2
    '10 A6 3.0T Quattro Avant Prestige Phantom Black Pearl Effect (Link)
    '09 A8L Phantom Black Pearle (Link)
    '13 A7 Quattro 3.0T Phantom Black - SOLD
    '07 A6 3.2 Quattro Avant S Line - SOLD
    Feb 12 2013
    Boston, MA
    Ill only use octane booster if I have to fill on 91 (have the 93 tune) I see no reason to get 3k oil changes personally, oil changes really have nothing to do with the carbon buildup. It's all about the FSI not really working the way it does in the newer engines and you essentially cant stop it, just have to pay for the cleans.
    Sep 21 2005
    A4/Corrado
    BC
    wow.. i bought my 2008 S6 with 80k miles and only thing that went bad was the thermostat and it was cheap and ez fix. since i dont know when my S6 had the carbon clean done, i'm getting it done next week at CTS Turbo.
    :O:O
    Jun 27 2013
    St. Augustine, FL
    The big reason I was using octane booster and some fuel cleaners, was to burn off any debris and, initially, see if I could burn off some of the carbon residue... but no dice. I now just use, BP/Sunoco/ or Shell gas, which should help in the long run for carbon build-up. All of the drive train problems stemmed from the carbon build up... So just an FYI.
    Jun 27 2013
    St. Augustine, FL
    As an update to some of the things that I have had to fix due to the carbon build-up:
    Feb 12 2013
    Boston, MA
    You got ripped on the brakes... That's 500 for those parts on genuine audi parts .com and doing front brakes is NOT 500 worth of labor
    Jun 27 2013
    St. Augustine, FL
    Tell me about it... But I'm keeping it dealer maintained until the warranty runs out, and I don't have the tools to do it right now...
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by BlueVR View Post
    BlueVR, you have 20x10s on your S6 right? What suspension setup do you have to get the right fitment?
    Established Member Two Rings tboo72's Avatar
    Jul 05 2013
    WI
    10000 miles away? Is that a typo?
    2013 S7 Prestige
    Established Member Two Rings IrishCreamPuff's Avatar
    Jul 23 2013
    C7 Z-06, '07 S6 (sold)
    United States
    This sounds very similar to my purchase of an '07. Thank god I got that warranty, it's saved me about 20k.
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    What warranty company did you get your extended through?
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by BlackS6 View Post
    USAA.
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    Sounds good i might pursue them also.. how much did it run if u dont mind me asking
    Jun 27 2013
    St. Augustine, FL
    My car was at 47000 miles when I got the warranty. The price goes up with how many miles are on the car.
    I paid $4,000.00 for a 3 year/36000 mile warranty.
    They usually have multiple options, I think they had a 12 month/12000 mile; 2 year/24000 mile; and something higher...
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by tboo72 View Post
    Nope not a typo... I was literally across the world. Haha.
    Jun 27 2013
    St. Augustine, FL
    Veteran Member Four Rings 03a4b6ztk's Avatar
    Jun 21 2013
    North Carolina
    Not sure if scaring me away from an s6 or just make me want to dig deeper in prepurchase research.
    Sent from my SM-T2105 using Tapatalk
    Knuckles
    4X4 with the Straight Pipe Roar!!!!!!!!
    Jun 27 2013
    St. Augustine, FL
    The car, in itself is phenomenal. The sound that engine makes is heavenly, and I love the understated aggressive look. This is my first Audi... And I don't look back.
    Jun 21 2013
    North Carolina
    Im in love with the looks and straightpiped V10 amazingness.
    Knuckles
    Senior Member Four Rings The_Transporter's Avatar
    Jul 04 2012
    United States of America
    I have tried over and over to stop people from buying the V10 S6. I think others may interpret it me incorrectly, but I truly have a 'benevolent' purpose in spreading the gospel of nightmare stories and of endless problems, along with increasing costs thrown into that particular car.
    I LOVE the 'idea' of the C6 S6... But knowing several people (with deep pockets) who ended up selling their S6's within one-year... I feel a responsibility to be extremely open and honest and help others make a competent decision.
    Audi dealers are desperately trying to dump these cars on unsuspecting buyers. The platform is just riddled with problems.
    The sound is glorious, however... a stage 2+ C6.5 A6 3.0T will leave it in the dust for performance and will have very few 'issues, if any.
    I sincerely wish you good luck in your ownership of the S6.
    All-Black C6.5 A6 3.0T Premium-Plus
    APR Stage 2+
    APR Pulley
    SST 'True' Cold air Intake
    SST Quad-tip Exhaust
    S.T. adjustable Coilovers
    H&R Sway
    EBC dimpled & slotted Rotors
    Exterior Mods:CarbonFiber mirrors, S6 Door Blades, RS6 grill, KimmelEyelids,S6 valance
    20x8.5" O.Z. Ultraleggera HLT's 255/30/20
    Jun 21 2013
    North Carolina
    What other problems. I'm genuinely curious as I want one of these
    Message sent, no data packets lost in transfer
    Knuckles
    Jul 04 2012
    Quote Originally Posted by 03a4b6ztk View Post
    Fuel pump
    Injectors
    Carbon
    transmission gasket seal (C6 4.2's have posted about this as well)
    Plugs
    Coil packs
    Someone posted a damaged/cracked intake manifold (please feel free to comment whoever that was..I cannot remember)
    I've posted before that 2 of my colleagues who owned S6's (both sold them within a year) Had to routinely keep extra coil packs in their car just in case of a failure.
    APR Stage 2+
    APR Pulley
    H&R Sway
    Jun 21 2013
    North Carolina
    Quote Originally Posted by The_Transporter View Post
    Fuel pump
    Injectors
    Carbon
    Plugs
    Coil packs
    Gasket and carbon are the only two major things I see in that list. Everything else in that last is seen across the board of the audis it seems.
    Granted 10 injectors and 10 coil packs add up pretty quick.
    Knuckles
    Jul 04 2012
    Buy a 2009 A6 3.0T, then buy some S6 door blades. It'll look pretty darn similar. I have quad exhaust on mine too.
    Interior is not the same, however, it's not like you bought a Chevy. It's still a lovely interior.
    The 3.0T with a free-flowing setup sounds very much like a GTR,(which MANY people have said to me) and it is NOT a V10, but... it sounds pretty damn good to me.
    APR Stage 2+
    APR Pulley
    H&R Sway
    Jun 27 2013
    St. Augustine, FL
    Thank you very much for the luck. Most of the problems that have popped up are related to carbon buildup, which I have taken care of so far, with "minor" expense... I am hoping nothing else pops up, but I have taken care of everything I can, and the only thing I have to do now is keep up on maintenance and get a carbon cleaning every 20k miles. From my research and experience that should take care of any other problem.
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    I'm at 87K miles and have done carbon cleaning. The coil packs were recalled so most cars get it done early under warranty.
    i recall getting a flap motor replaced under warranty. I run fuel additive every once in a while and constantly make sure air filters are clean.
    I'm sure there are hundreds of other very happy S6 owners enjoying their V10's with very little problems out there.
    A quick check of service history and an aggressive test drive will give you a good feel of the car.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by 07S6 View Post
    I definitely agree with that. I think you have to be a little obsessive to make sure the car is always in good standing.
    Jun 28 2011
    MN
    This. I had my 2007 S6 for a year. I bought it with 18k miles on it and CPO and sold it at 30k miles after a year of spending a lot of time at the shop.
    Feb 12 2013
    Boston, MA
    I ditched my s6 after 10k miles, I had other reasons than maintenance, but my car had an unknown oil leak that could have cost thousands and I was not gonna fuck around with that.
    Jun 27 2013
    St. Augustine, FL
    I will update as I go. But I still love the car, it is fantastic!
    Jun 27 2013
    St. Augustine, FL
    UPDATE: The car was finished up today. To anyone, anytime, please get an extended warranty through somewhere. TOTAL: $5500.00= me paying $1500.00 for some uncovered labor and wheel alignment.
    Winning in my book... But even though the car is phenomenal, all this random shit is really starting to wear on me. I feel like there's really NOTHING else that can go wrong, but I've been proven wrong already.
    We will see... Maybe a 2010 E63 AMG in the near future...??
    Established Member Two Rings ApexRex's Avatar
    Nov 18 2013
    07 4.2 A6
    Chesterfield, VA
    Just wanted to say thank you for staying with this thread. There is a wealth of information here and a real world experience that someone looking for an S6 could find very useful. So many times threads get started and ditched. I appreciate that you have kept with this and documented it so well, even though I am not even remotely in the market for one. Thanks again, and if you do get that E63 be sure to post pictures!
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by ApexRex View Post
    You're very welcome, and I definitely agree with you that this information needs to get out there. I just look at it from the point of view that I would want if I was researching to possibly buy the car. Buying a new car is definitely in the future for me. I still have a while on the warranty, and I am going to wait until that is done to get rid of the car. Whoever gets it after me if I sell it should be thankful :D
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    My S6 is in the shop now im going to have everything looked at this time. Do you have a sound clip of your car with the Rear Resonator Delete?
    Jun 27 2013
    St. Augustine, FL
    I don't have the resonator delete yet. I'm going to do it after the warranty runs out.
    Jul 23 2013
    United States
    I know what you mean by this is all wearing on you. My car is constantly in the shop. I have the platinum warranty as well, but still I've paid about $6k on top of the warranty. Every time I think everything is fixed, the car breaks, or theres a new smell, or a new vibration. Oil gasket, carbon clean, new intake manifold, 2 new headlights, new power fluid reservoir, new coolant reservoir, new brakes, and now it's in the shop for a 32 hour job to replace 2 seals near the firewall for a coolant leak. Also the bushings in the front and back squeak. If I hadn't already put 10k into the car on TOP of the purchase price, I would've jumped ship long ago. Luckily for me though, I haven't had issues with CEL's. Just leaks. everything leaks. :(
    '12 BMW 535xi
    '07 Audi S6 (sold and forgotten)
    '15 Z-06
