Results 1 to 33 of 33
    Feb 01 2008
    Advanced key option
    Hey everyone
    I just bought a 2010 s4. The car does no have the advanced key option. Is there coding we can do through vag come to activate this option? I want to be able to unlock and lock the car with the door handle sensors.
    Thanks in advance
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    Do you have the touch handles? On your door handles do you have the little squares on the outside of the handle. I do remember seeing an option for advanced key when i was playing with my vcds cable.
    2017 SQ5 Premium + | weathertech floor mats | 20% tint
    Sold:2012 S4 Premium + | 6MT | comfort key | supercharged badges | weathertech floor mats | 15% tint | Gunmetal VMR 710 18x9.5 w/ bridgestone potenza RE970AS from PYSpeed| Roc-Euro intake | Alu Kreuz | Eurocode Meisterwerk ASTS | 034Motorsport Transmission Mount Insert | Spulen Rear Differential Mount | ECS GEOMET Slotted and Drilled rotors | Hawk Ceramic pads
    Feb 01 2008
    Yes i have the sensors on my door handles
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    Get in touch with DavidB8, he should be able to help you out with that. He seems like a retrofit guru
    Senior Member Four Rings dbX79's Avatar
    May 24 2012
    2011 BMW 328i Coupe
    Atlanta,GA
    Advanced key option
    That's a additional feature for the old models. Now it's standard. I don't think it matters if you use vag com if its not there vag com will not change that. You can have the dealer or Audi Customer Service look up the features of your car and they can tell you. All that would have to be wired into the doors.
    2013 S4 Ibis White | Black Nappa Leather | DSG | MMI Navigation Plus | B&O | Sports Differential |Carbon Atlas Inlays | 19" 5 Spoked Peelers | VAG Com |
    Nov 11 2012
    California
    Are you sure the little squares on the door handle means you actually have sensors? Or did Audi make all the door handles look the same?
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    My 2012 has squares on the door handles and they do not seem to be anything more than modeled into the handle. I do not have advance key, I don't think? I do not have a push to start button in the car, key has to go into the dash.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    i wondered this as well
    all door handles have the little squares (body colored) and i have the button on the trunk. but none of them work like a "smart key"
    i could understand not having the push button as standard, but my wifes 2010 base model prius has smart keys standard
    would love to retrofit this
    Nov 11 2012
    California
    I ran across this page from somebody trying to retrofit the smart key functionality in an A5. I would think the effort is similar, just to give you an idea of the work involved. Unfortunately it's in German. http://www.motor-talk.de/blogs/reini...-t3942288.html
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Hi - any of you who do have the advanced key --- do you ever charge it by inserting in dash? After 1 year I am getting a warning to recharge key ... Dealer told me I never had to use the dash mode ...
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Aug 08 2013
    Idaho
    Advanced key option
    Quote Originally Posted by Audi Advocate View Post
    I never put mine in the dash but I didn't know it charges that way. I'm too lazy is it mentioned in the manual?
    2014 Audi A4 P+ Brilliant Red | S-Line | Black Optics | Sport Package | H&R OE Springs | RS4 Grill
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Change the CR2032 battery in it. It doesn't have inductive charging in the dash slot.
    Sep 05 2012
    The manual tells you how to change the battery, not charge it. It's not rechargeable http://www.audizine.com/forum/showth...ry-replacement
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Oct 14 2012
    Empty...for now...
    SE PA
    ^ I concur, the S4 key fob does not have a rechargeable battery.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I think the confusion comes from BMW having a rechargeable key battery in their NON Advanced key . Comfort Access key(as BMW calls it) is also not rechargeable. BTW , it cannot be retro fitted in a BMW. Not sure about Audi's system.
    Feb 25 2013
    MI
    Isn't there the issue of detecting the key itself? Is this functionality present in the non-advanced key cars?
    May 05 2012
    Clinton, UT
    Quote Originally Posted by SwankPeRFection View Post
    Change the CR2022 battery in it. It doesn't have inductive charging in the dash slot.
    It is a CR2032. I just checked my key.
    Veteran Member Four Rings 100Daily's Avatar
    Jul 03 2010
    Parker, CO
    At a minimum you would have to actually purchase the advanced key itself and have it programmed. The advanced key is slighltly larger than the standard key, and costs $500 per key from the dealer. I would imagine there would have to be some additional hardware in the car as well, but I am not sure. It seems unlikely that you could software unlock this feature even with a key, but I am curious what you learn.
    2012 Audi R8 V10 Gated - Stage 1 - Phantom Black - Carbon Package
    Gone But Not Forgotten: 2013 S4 3.0 ---- 2008 A5 3.2 ---- 2005.5 A4 2.0T ---- 1993 90S 2.8
    Senior Member Two Rings Russtty's Avatar
    Aug 18 2010
    2009 Jetta Sportswagon TDI
    South West Ontario
    Subscribed: my car no longer unlocks when I get close to it and would love to figure out how to troubleshoot it. Hopefully some of the discussion in this thread would help! :)
    Ibis White 6MT B8 S4 Premium : Sports Diff, Nav, Carbon Atlas Trim, B&O Sound
    Eurocode Meisterwerk SS - GIAC Stage 1 - StaSiS Exhaust – Eurocode Intake
    Eurocode USS – Alu Kreuz - Potenza RE-11 on 19" OZ Ultraleggera HLTs
    SPM/Alcon 375mm BBK /w Ferodo DS2500
    Bilstein PSS10 Coilovers
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Russtty View Post
    sounds like one of your door sensors is bad, have you tried to pull any codes for the central locking system?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Aug 05 2013
    N/A
    Quote Originally Posted by ob_1jr View Post
    Ya, my bad, that's what I meant. Key slipped.
    Aug 05 2013
    N/A
    Are you touching the inside of the handle with your hand while the key is on you to unlock the doors?
    Aug 18 2010
    South West Ontario
    Quote Originally Posted by infinkc View Post
    Not yet. Taking it into the shop tomorrow so I will see if they find anything.
    As far as touching the inside of the handle.... It used to just unlock as I reached for the handle. Now nothing. The trunk sensor still seems to work, just not the doors. It doesn't matte which door either. The auto-unlock seems to be MIA. :/
    Jun 04 2010
    northern nj
    I have that problem to a smaller extent with my rear doors. My rear pass. door is especially annoying, you have to hold the handle for a sec for it to recognize it.
    May 05 2012
    Clinton, UT
    Quote Originally Posted by apexit1 View Post
    Mine seems to do the same thing. I know sometimes I have to put my pocket with the key in it closer to the car. I have had times of when I was driving down the road the car would tell me that no key was present. I probably should change my battery as I have had my car for a little over a year.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    its not suposed to unlock as you near the car though. its only suposed to unlock if you grasp the handle
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Three Rings S4_Phantom's Avatar
    Dec 19 2011
    South Florida (Boynton Beach)
    I have to pull the handle twice on my car to get it to unlock. I don't mind it though as it seems to be a safety feature. Sometimes it doesn't work at all. It's a little funky. I don't think the little squares do anything. They were molded into my '12 door handles, as well and I didn't have the advance key in that car. It is a cool feature, but really not necessary. I don't mind hitting the buttons and I find myself inserting the key in the dash half the time anyway. The battery is not rechargeable as far as I know. A CR2032 is a very common battery used in many applications. My garage door opener uses the same battery. Only a few bucks to replace.
    2013 Estoril Blue S4 | P+ | DSG | Sport Diff | Drive Select | B&O | Carbon Fiber | Silver Alcantara Seats | Advance Key | Red Supercharged Badges | 19" Ti wheels & Michelin PSS
    Founder - Audi Club South Florida | Web - AudiClubSouthFlorida.com | Facebook - Audi Club South Florida
    Aug 05 2013
    N/A
    You're doing it wrong. You don't tug at the handle to get it to unlock. You put your finders behind the handle and touch. The locks unlock, THEN you pull the handle. To lock it back up, you shut the door and touch the square button with a finger or the back of your hand/fingers. You need to make it a 1 or so second touch. It can't be a quick tap.
    These locks are awesome when you carrying stuff like food or other things where you can get one or two fingers on the handle but not more. I've even shut the door and locked it with my knee or elbow cus my hands were full. I get some funny looks sometimes. I'm going to try my nose next. Lol
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    If your hands are full after getting crap out of the trunk, you can also lock the doors by simply bumping the handle with your hip as you walk by. Works really well.
    Aug 05 2013
    N/A
    BTW, since we're on the keyless subject, when you wash your car, leave the key somewhere inside it. That way you won't set off the locks as you spray them down. Saw posts about this a few weeks ago, but couldn't find that thread again to share this.
    Oct 27 2009
    Miami, FL | Boone, NC
    Advanced key option
    Advanced key isn't just a coding thing. The key fob is different and hardware is missing on non advanced my cars (several receiver antennas, the door sensors - all cars have the molded "pads" on the handles, the start/stop console button, and wiring)
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Aug 18 2010
    South West Ontario
    Got the following code:
    00192 – Left Rear Door Handle Touch Sensor (G417)
    007 – Short to Ground
    I have a feeling it has something to do with the water I was getting in the cabin. The code was cleared and came back right away. I'm guessing I need to pull apart my door to fix it? Anyone had to do anything like this yet?
    Thanks
    Steve
    Jun 04 2010
    northern nj
    If you were getting water in the cabin it's worth a shot to take off the door skin and try and find the hardware for the keyless go. Make sure that theres no corrosion on any of the contacts.
