Results 1 to 12 of 12
    Established Member Two Rings Grenalis's Avatar
    Apr 29 2013
    St. Louis, MO
    04 A4 B6 1.8T Alternator Pulley
    I am hoping someone has come across this issue and can shed some light on it for me. My issue is that my serp belt tensioner is bouncing a good 3/4". From what I have gathered the issue is in the alternator clutch pulley. The issue I am having is that apparently there are like 4 different alternators that were used, so that means that there are 4 different pulleys. My question is, is there any way of finding out which one I have so I can order the correct pulley, w/o pulling the alternator. I Don't see any sort of markings on the sides I can see from the exposed sides of the alternator. Please, any help would be greatly appreciated.
    2004 Audi A4Q B6 1.8T
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Well assuming you have never replaced the alternator before, I would say go to the dealer with your VIN and ask them.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Dec 15 2011
    Edmonton Alberta
    When I look kit up on my parts suppliers lists (3) it only comes up with part number 06B903119D as the only replacement pulley available...
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Apr 29 2013
    St. Louis, MO
    I tried that fR3ZNO, and they said it lists 4 different alternators and 4 different pulley and 3 different amperage, so I would need to find out who made the alternator and how many amps it is.
    Thank you Dubsport Inc. I will look that one up.
    Update: I found that one at http://www.europaparts.com/alternato...6b903119d.html I just hope its the right one. $70 bucks is a lot to drop on a incorrect part.
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Dec 15 2011
    Edmonton Alberta
    That is the correct part number according ETKA and my local suppliers!
    -Richard-
    Apr 29 2013
    St. Louis, MO
    Thanks Dubsport Inc. Would be nice to be able to use that ETKA / partslink24. I did see that it said alternator versions but of course I cant look w/o paying for the service. Unless of course you will share :P BTW what is the Q for after your A4 in sig?
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Grenalis View Post
    Make sure it's not the belt tensioner either.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Dec 15 2011
    Edmonton Alberta
    Quattro..:)
    -Richard-
    Apr 29 2013
    St. Louis, MO
    Well in my experience that is what I would have thought it was, was the tensioner. I did replace the tensioner pulley to no avail. but everyone says its the Alternator pulley, so thats why I was going to replace it.
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Oct 02 2006
    Wadsworth,OH
    There's no reason the tensioner should be moving like that. I wouldn't think the alternator pulley has nothing to do with it. Chances are the tensioner is bad. The tensioner has a dampener in it (like a spring) to absorb vibrations and when the belt jumps around. When this dampener goes bad the tensioner pulley will have more play (like you're describing)
    Might be time for a new tensioner if its never been replaced. Another sign its bad is the infamous chatter from the tensioner - it's not always present but as it gets worse it will eventually chatter.
    Jason
    Apr 29 2013
    St. Louis, MO
    Ok, so I ordered the entire tensioner and will install it whence it arrives. I will post if it fixed the bounce issue or not at that time. Thanks Guys
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
    Apr 29 2013
    St. Louis, MO
    Well it looks like that did it. Just a lil bit of bounce that from my experience is normal. Thanks for confirming what I thought it was. I'm glad on this one that I didn't go by what most forums say that is the culprit and change the alternator clutch pulley. Thanks Guys
    5 Speed Tiptronic
    Dolphin Grey
    Stock FTM
