I'm in the process of replacing the '02 A6 4.2's coolant expansion tank & temperature sender after draining out the old coolant.
Now fresh new G12++ coolant needs to go back in but, according to the ElsaWin service docs, a suction jet pump doohickie (special tool VAS 6096) is called for to create a vacuum in the closed cooling system which will the suck in the mix of new G12++/distilled water while bleeding air from the system at the same time. The only bleeder valve I can find in the engine bay is a small manufactured hole in the upper heater core hose which is intended to match up w/ a bleeder hole in the pipe when said hose's clamp is loosened and said hose pulled back sufficiently enough.
I'll admit that after wrenching on a few decade-old Fords, GMs, Volvos, and, of course, VW/Audis (mainly 1.8Ts), this is the first time I've come across such an involved refill procedure. I've looked through ElsaWin at other engines and it seems that only the 4.2L V8 is this way, esp. among C5s.
So, the question, isn't there a more DIY-friendly approach to refilling & bleeding the 4.2's cooling system?
