Results 1 to 8 of 8
    Jul 26 2013
    Norway
    Fault code for thermostat
    On my Audi A4 2004 I have a CEL coming and going. No other unusual behaviour experienced with the car. The engine temperature, driveability and all things appear as normal.
    I read out the following fault code:
    __________
    Address 01: Engine Labels: Redir Fail!
    Controller: 8E0 906 018 AH
    Component: 1.6L R4/2VSIM3 0002
    Coding: 0006271
    1 Fault Found:
    17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
    P1292 - 009 - Open or Short to Ground - Intermittent
    Readiness: N/A
    __________
    I'm planning to change the thermostat, but I am unsure whether I must also change other things as well. From the part store looks like there are two options; thermostate and thermostate with housing. It is a substantial price difference on these two.
    As I have limited experience with this car and interpretation of the fault system I was hoping for some guidance on what action to take.
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Check the sensor that goes into the housing. If the sensor is broken or corroded then you need to change it. Unfortunately the sensor is built into the thermostat housing. I learned this a few months ago.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Veteran Member Three Rings OMG_SHARK's Avatar
    Aug 17 2012
    02 1.8T 5spd, 05 1.8T USP Avant 6spd, 06 SV650 custom
    238.9E3 from a cool place
    While replacing the thermostat, go ahead and replace the j-plug as well.
    Unicorn Society Member #10
    AKA: VeryTG
    Dec 25 2004
    Earth
    Since OP is in Norway...we need to ask what engine he has? The European Audi's can differ from the USA models....
    There is a DIY write-up to R&R the thermostat....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jul 26 2013
    Norway
    Hi. Thanks for reply.
    The car spesifications are A4 8E, Engine code ALZ, 75 kW, 1.6 l. Unfortunately it looks to me that this model is not covered very well by the available service manulas (Haynes, Bentley).
    To me the message "Open circuit...Open or Short to Ground" from the fault code suggests that there is something electrical. As I understand the thermostat is a pure mechanical thing so my best guess is that the sensor in the housing is bad. Think I will replace the thermostat with housing/sensor and also this J-plug. (Please correct me if i'm lost here...)
    Dec 25 2004
    Earth
    Quote Originally Posted by sanoj78 View Post
    The ALZ 75KW, 1.6l never made it to the USA....
    We have the 1.8t.
    The vast majority here on this forum are USA based with the 1.8t.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The code is for a short in the thermostat heater. You have a map controlled thermostat. It doesn't have a sensor. I believe the ALZ and APF are similar. Clicky click Before you replace the thermostat hake sure it's plugged in properly.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    My 4-pin coolant temp sensor went bad recently and I was getting the 1292 code along with the running fans at start up and, oddly enough, an engine that wanted to stall the first second I put my foot on the gas when driving the first 15 minutes or more. What sucked is I replaced that sensor with a new one that was defective. I paid up for OEM instead of the cheapest knockoff I could find! The knock-off also had off dimensions that let it drip quite a lot of coolant to the point it was empty in 2 days. OEM = fine now.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
