Results 1 to 16 of 16
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Cigarette lighter lights, but doesn't charge my phone
    for some odd reason, my girlfriends cigarette lighter doesn't charge my phone, but it can light a cigarette. what gives? i'm guessing it could be a fuse, but i'm not sure where/how to check. any help would be greatly appreciated
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Veteran Member Four Rings BrucexL33's Avatar
    Mar 19 2010
    2015 Prius Plug-In
    San Jose, CA
    If it can light a cigarette that means it works. It is a possibility that your charging adapter is not working correctly. Usually an adapter has a light indicator to show that it is on, does yours have that? Also try out another phone charger to test it out.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by BlazinB5 View Post
    Well, there's your problem right there. Cigarette lighters don't charge phones. I think you need a *phone charger* to do that.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Haha, good one. Check the fuse in the tip phone charger. The one for my gps actually blew, and I had to replace it.
    1998.5 A4 1.8TQM My Build
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by BrucexL33 View Post
    the charger works in both my B5's (with an indicator light), just not hers, so its definitely something wrong with hers
    haha, if only the problem was that simple
    Quote Originally Posted by xdewaynex View Post
    i figured it might be a fuse of some sort, but i got no idea how to find which fuse it might be
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    There's a fuse inside the charger, usually right under the spring tip.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    SO if the charger is working, and the cars lighter is working, is it possible that the phone charger cant draw enough power from the Cig lighter to actually charge the phone? For example, some usb ports on laptops have the voltage to charge the phone, not just connect it. However some ports don't, and you can connect the phone, but it wont charge. I think it might be a lower tech version of that sort of problem. I would check to make sure the cig lighter was at 12 volts.
    Eurosport Tuning at it's Finest
    Senior Member Two Rings marknad113's Avatar
    Aug 12 2009
    Pittsburgh
    my samsung galaxy only charges in my car if the screen is off
    1997 A4 1.8TQM Pearl White
    2001 TT 225Q Roadster Amulet Red
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    i tried to get a car charger to work in my 01, but it wouldnt. worked in a ford though. the problem is in the charger. the side contacts of the charger do not make contact with the contact inside the socket of the car. i dont know why it would work in some b5's and not others, perhaps the sockets were changed through the years. i'm fairly sure this is your problem
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    So just wrap it in tin foil so it will contact the socket 'more better'. It will charge perfectly for about 3 minutes until your car bursts into flames.
    Other option: add a [properly fused] aftermarket 12v socket that will work with all your chargers. Bonus: you can light up the cancer sticks *while* charging your phone.
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by redline380 View Post
    me and my girl both have 01's, so it's definitely her car acting up (i would think)
    Quote Originally Posted by Cgoon009 View Post
    any idea how to check that though? i'm guessing that i would need one of those things with the prong that measures voltage (hard for me to explain). would i be able to just poke one of the contacts to measure that?
    lol you're crazy
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Dec 05 2007
    Push it in harder.
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Push it in harder.
    Thaaats what she said.....
    Established Member Three Rings ToXicXxX's Avatar
    Jun 14 2013
    2009 A4
    Calgary, Alberta, Canada
    Smoking in an Audi... That's just wrong.
    Kyle
    2011 Obsidian Metallic Mercedes C63 AMG - P31 Performance Package - Limited Slip Differential - ECUProgram Stage 2 (540BHP) - 275/35/18 Rear / 235/40/18 Front Nitto Invo's on AMG rims
    Nov 12 2010
    Stillwater, MN
    Re: Cigarette lighter lights, but doesn't charge my phone
    Push it in harder.
    I'll have to try that. And maybe check the contacts and make sure
    Thats what she got too
    Quote Originally Posted by ToXicXxX View Post
    Neither of us smoke, but I test them to be sure
    Sent from my Galaxy S4 using Tapatalk 2
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Mar 02 2013
    DC
    Lol
    Here is what you would need to test voltage.
    You can get them at most hardware stores.
