So, on to my question. I pulled up my PDF collection I got off ERWIN to check the torque specs for these. They appear to be stretch bolts. Looking a little further most of the suspension bolts appear to be stretch bolts. The manual says "always replace after removing". Is everyone getting springs installed replacing all of these bolts? Any reports of broken reused bolts? I know that the shop that did this work did not. I am wondering about the driver's site which is tight and appears to be fine. I also found that the top bolts have an tightening pattern which I am sure the shop did not do either. I am trying to decide if I should pull all of these bolts and replace them or just worry about the side that is loose.
Also, anyone have these bolts back out? I really doubt that mine did after being properly torqued. One side is fine.
This is the sort of thing that really pisses me off and why I try to do all work myself. I should not have trusted these SOBs to do this right.
