Results 1 to 12 of 12
    Active Member Four Rings DinB's Avatar
    Apr 20 2012
    O
    Using the touch up pen
    So I got a tiny nick on my driver door edge. I bought the Audi RS5 pen but it seems wonky. The tip is some kind of a fiber thing that comes out. At first it wasn't getting wet so I flipped it around and that made things better but it is a messy way to do it. Anyway, I am finding the paint to look a bit chalky. I haven't applied the clear coat pen, but is there any advice on using the paint pen better?
    SOLD Ibis White RS5
    Factory: Nav., B&O, Sport exhaust, and Steel mesh/piano black trim
    Aftermarket: 20" Ti OEM wheels, 20% tint, v8 badges, dynamat in the rear parcel, Infinity Basslink sub, OEM silver tips, OEM alu-optic)
    To Do: (2014: KW HAS springs, spacers)
    "When the cat man speaks, you listen!" - Mops
    Mar 18 2011
    Denver
    You shouldn't need to flip the tip - just push it down a few times to prime it with paint.
    Next time, go with Dr. Colorchip.
    Jul 06 2012
    1970 Plymouth Duster 340 4-spd
    Twin Cities/Minnesota
    Watch this, it will help you out. https://www.youtube.com/watch?v=6xi3xmeO6C4
    Apr 20 2012
    O
    Quote Originally Posted by yas View Post
    Yeah I tried but there was very little coming out. I will try again.
    SOLD Ibis White RS5
    Veteran Member Three Rings kevinnijjar23's Avatar
    Feb 01 2012
    2014 A5 S-Line, 2015 E350 Amg package
    Orlando, FL
    Quote Originally Posted by DinB View Post
    2017 Audi A4
    2015 Mercedes Benz Polar White E350 AMG package
    2014 Audi A5 S-Line
    2011 Audi A5 2.0T (Sold)
    Oct 30 2012
    Florida
    LOL I saw that haha
    Sep 28 2010
    NW NC / DE
    Ha!
    Those pens are garbage. Get some out of the pen and use a proper brush to touch it up.
    I use these by E-Z Mix
    Jul 22 2013
    Michigan
    The dealer paint sticks are useless. My dealer told me to go to Michael's or any art and crafts store and buy some fine point or angle fine paint brushes depending on the type and size of chip you want to touch up. I bought several brushes, angled, round, fine point ect. and even some that only had maybe 10 bristles on them because the most recent chip I did was only a pin point size. 6 brushes cost $10.00. Then followed my own process.
    1. Since it was so small I used wax over the chip and surrounding area.
    2. Then I removed the wax with in the chip with rubbing alcohol and bit off the end of a Q-Tip so it was flat and rolled it over the chip removing the wax inside the chip.
    3. I mixed equal amounts of paint and clear coat in a small cup. I put a tiny drop of paint on a fine angled brush and in filled in the chip with just a little extra outside the chip on top of the wax.
    4. After it cured for 5-7 minutes I used some leveling fluid to remove the over filled chips excess paint lightly going over chip but not into the chip.
    5. After the touch up fully cured I used some light rubbing compound with a micro fiber towel and then repeated that step with 3M scratch remover.
    6. The next day I re-waxed the area and by golly no one could tell it was there.
    Easy, inexpensive, and it worked for me plus looks great.
    Apr 20 2012
    O
    Hmmm any idea why the paint does not seem to dry even after a few days? I can pretty much run it off with just a light run with the finger. :/
    SOLD Ibis White RS5
    Jul 25 2011
    Quote Originally Posted by kevinnijjar23 View Post
    lmao u sala phud
    Jan 11 2013
    C6 Z06 gone, now Sharkwerks 997 GT3
    california
    I had a what sounds like an very similar chip in the raised portion of my driver's door. While the Audi touch-up sticks are not great they work OK if you are patient enough to commit to a 2 to 3 week process. Clean the chip, apply a very very thin layer of paint from the stick, and leave it alone for a couple of days to dry/cure (OK to use the car). Repeat the process until you've almost filled the chip. Very carefully even(only) the applied paint with something like a 3M Microfine finishing sanding foam pad, and apply a couple of coats of the clear stick over a few days. Micro sand the last coat after a few days, and use a fine polishing compound to blend it into to rest of the door. Wax, and you are good to go....hopefully.
    If your paint won't dry, it sounds like you are not mixing the componnets in the tube by shaking it long enough, applying it way to thickly, or the ambient temperature is way too cold. Touch up isn't a one step process, if the paint doesn't dry between applications, or if you apply it too thick, it will shrink inside the chip when it does dry.
    Good luck, the alternative is to repaint your door, blending into the adjoining panels(expensive). Some (very few) professional detailers/paint shops can accelerate the chip repair process using heat lamps.
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Quote Originally Posted by 04onken View Post
    Thanks for this, although I can imagine less attention to detail going in to disarming a bomb!
