Results 1 to 22 of 22
    Registered Member Four Rings Sales@IE's Avatar
    Dec 01 2011
    SLC, UT
    Integrated Engineering's 2.0T TSI/TFSI engine builds
    With the impressive performance levels of aftermarket turbos on the 2.0T TSI VW/Audi engines, it is more important than ever to build the engine for strength. We are getting more and more of these 2.0T TSI cylinder head, short block, and long block builds coming through, and we thought we would show you guys some photos from these very cool builds. I will update this thread periodically with new customer projects and builds I think you guys will find interesting.
    This first customer wanted a strong bottom end for a GTX30R setup with high boost levels. This specific customer decided to run a set of our Integrated Engineering Tuscan I beam 144X22mm rifle drilled connecting rods. With a hight strength-to-weight ratio, the Tuscan connecting rod delivers the highest strength properties available on the VW/Audi market, while retaining a light weight design.
    The Tuscan connecting rod will be the foundation for the IE Race Spec JE custom piston with a TSI direct injection dish design. The customer opted for JE's self lubricating, anti-friction/anti-wear Tuff Skirt coating to be applied to the piston skirt along with 22mm through-hardened high-carbon bearing steel tool steel wrist pins. The 22mm tool steel wrist pin design is incredibly strong and will withstand insane power levels without the need for a larger diameter, heavier pin.
    Calico coated ACL race connecting rod bearings were chosen for their maximum wear resistance properties and durability to protect against distortion at high RPMs and increased power levels.
    With the parts list finalized, the tear down process can begin.
    Now that the short block has been stripped down, the blueprinting, balancing, and machining process can begin. The block receives a hot tank bath and a complete inspection. Once verified clean and healthy, an Integrated Engineering torque plate is bolted to the block to simulate the distortion caused by clamping on the cylinder head, ensuring round cylinders and achieving precise piston to cylinder wall clearances. Once the boring and honing process is completed, the block surface deck receives a fresh machined surface for a proper head gasket seal.
    Before the final assembly started, the customer supplied a custom engine block paint to match his theme.
    INTEGRATED ENGINEERING
    High Performance Automotive Components
    Forged Internals - Valve Train - Race Engines - Intake Manifolds - Billet Accessories - Suspension - Brakes - Fueling
    WWW.PERFORMANCEBYIE.COM / IE FACEBOOK
    Dec 01 2011
    SLC, UT
    The bottom end including the block, pistons, rods, and crankshaft are all measured to multiple decimal placed. Clearances are verified and recorded before the assembly begins. At this point, the piston rings are filed to the required gaps for the build, then installed onto the pistons. The assembly process is completed with all pistons, rods, and crankshaft installed and bolts torqued to the proper specification.
    The short block is finished and ready to perform with whatever the customer is willing to throw at it. The short block will be delivered along with a check list of all measured clearances, care sheet, and Brad Penn break-in oil.
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Love all the photos!!! Beautiful work and craftsmanship!!! Wish my wallet was deeper!!! hahaha!!
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Jun 27 2011
    You IE guys are EVIL EVIL people.
    DO DO WANT...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 05 2011
    Finland
    This is simply the best picture thread in years in the B8 section! Is the builder on AZ? Would love to see the outcome of this and especially curious on how he is planning to address the somewhat restricted flow in valvelift headside..?
    Apr 05 2011
    Pacific Northwest
    Beautiful!
    Highlander's Build Thread
    Dec 01 2011
    SLC, UT
    Thanks guys!
    Quote Originally Posted by Razzel View Post
    I am not sure if the owner of the car has a build thread or is active on the boards, I don't believe so. However, we do know he is leaving the head factory for now and getting the rest of his build finished up. He may have plans for a IE built or IE CNC head in the future with IE valve springs and retainers for some serious RPM. Once the engine is back in and the car is up and running he plans on seeing what kind of power levels he is making with the GTX turbocharger, and then look into furthering that power with a built head down the line.
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    Pretty epic. Too bad the customer isnt active here, would love to see more of this build.
    2015 Subaru WRX STi | Limited | Dark Grey Metallic | Sport Tech | Xpel Ultimate
    Sold -2013 Audi A4 2.0T | Premium | 6 MT | Brilliant Black | Xpel Ultimate | Tint: 35% Front 20% Rear
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    car porn!!! seriously beautiful work!
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Feb 24 2013
    CA
    Any more motors, ie? Amazing job:)
    Stage 3 Forum Advertiser Three Rings Tyler@IE's Avatar
    Oct 07 2013
    Salt Lake City, Utah
    Quote Originally Posted by Ulisses03hd View Post
    We have some FSI blocks and 1.8T long blocks currently in the works. I know we have a couple cylinder head builds coming up for the TSI soon... so I will update with that!
    LIVE FAST, BUY FUN
    Tuning - Intakes - Intercoolers - Exhaust Systems - Engine Internals
    PERFORMANCEBYIE.COM / IE FACEBOOK / IE INSTAGRAM
    Feb 24 2013
    CA
    No more updates?:(((
    Feb 24 2013
    CA
    Any updatesssss??? Pleaseeeeeeeeeeeeee:))))
    Feb 24 2013
    CA
    No more updates huh :/
    Oct 07 2013
    The car we built this for is running strong. We just finished up a big build for an S3 in Australia, that was a very cool build. I can post some photos of that here soon if you would like.
    LIVE FAST, BUY FUN
    Feb 24 2013
    CA
    Please tyler, that would be great÷
    May 07 2014
    Ditto, anything you can show us is fantastic!
    2010 A4 2.0t quattro 6mt
    Dec 27 2012
    2011 Q5 S-line, 2012 Q7 TDI, 2007 Continental GT
    New York
    Truly excellent job! Is the torque plate available or 1.8 will work as well.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Anyway to get these pictures working again???
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    It looks like they changed their domain name at some point. this is just a repost of something from their blog: https://performancebyie.com/blogs/ie...rt-block-build
    Active Member Two Rings Allroad23's Avatar
    Sep 16 2020
    NorCal
    New here......Please let me know if IE or APR Stage 1......
    2014 Allroad.....
    THX
    Jan 16 2011
    Earth
    Quote Originally Posted by IHave2Turbos View Post
    Sweet thx
