Results 1 to 13 of 13
    Active Member Two Rings kovalrm1's Avatar
    Aug 09 2013
    battle ground wa
    advice for aftermarket Air suspension for my A8L
    i bought this A8L and did a S8 front conversion im trying to lower my audi as low as possible, my plan is to buy some nice VIP modular wheels but im not sure how low will the car go on stock suspension. and what can i buy or do to make it just drop to the ground when parked and raise a little bit when driving
    ive been messing around with the lowering links and i put them to the lowest setting but now the car doesnt go up or down just the yellow suspension light goes on and the options on mmi block out
    any advice?
    my car now
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Id put spacers on the rear and call it a day at most...but thats just me. Long cars look downright odd when theyre "slammed" or "bagged" or whatever its called
    Aug 09 2013
    battle ground wa
    Quote Originally Posted by Guitarmageddon View Post
    might just do that after i figure out my problem.
    the front is low but the back stays normal hight after messing with the links even tho they are set at lowest,
    Established Member Two Rings maxi3000's Avatar
    Sep 16 2010
    killeen tx
    I have the lowering links also ......I think I know what your problem is.....look at the senor arms are all of them facing inward if not........you have the links on wrong........all of the arms should be facing inwards away from the tires.....milddle of the car.....If the front is lower and the rear is high ....the arms on the rear are wrong.....just disconnect the rears make sure the arms in front and back are facing each other.......start from process all over again....
    Aug 09 2013
    battle ground wa
    Quote Originally Posted by maxi3000 View Post
    i did put them on wrong at first when my car raised super high like a truck. but then i changed the sensor lever the right way and it lowered and stopped but it didnt go as low as it did in the beginning even tho i made the links shorter then before but now for it to drop all the way i have to disconnect the link and move the lever down all the way so it touches the other end that's the only way it will lower how i want it but as soon as i put the link on it raises the rear again to the "lift" height when im in "dynamic" mode. the front goes up and down but back doesnt want to go lower.... frustrating
    Sep 16 2010
    killeen tx
    I would put the OEM links back on, let the CPU reset....1. Oem links back on drive forward then backward, make sure nothing pops up on the dash....make sure your on even ground....2. Then install the aftermaket links according to instructions....remember make sure to keep driveside window down.....drive forward and backwards.....3 the links you order may on let the car drop to a certain height.....remember front is heavier......LOL
    Aug 09 2013
    battle ground wa
    i Dont have the oem links, i bought the car like this. and no matter what height i make them i still get the code
    001400-suspension level control
    001 - upper limit exceeded - Intermittent
    and so on
    sooo frustrating ..
    Sep 16 2010
    killeen tx
    I think the links can only be adjusted 8mm shorter than OEM…..if its more than 8mm it will throw codes….
    Senior Member Three Rings 2modfast's Avatar
    Sep 20 2006
    Any other way to get the car lower without using the links?
    A man is defined by two things in life...by his WORDS and his ACTIONS.
    **FOR SALE...B6 S4 OEM DownPipes**
    Senior Member Three Rings Boom's Avatar
    Oct 29 2012
    08 Jetta
    VA Beach
    If you want a nice stance and want to be lower, go big or go home. Do air ride suspension and these to help with the setup. Good luck
    Nice ride by the way
    Established Member Two Rings boiseauctioneer's Avatar
    Oct 15 2012
    2007 Audi S8 2003 Jeep Cherokee Laredo
    Eagle, ID
    I have been looking for a set of adjustable control arms. Certain these will work on a D3 S8?
    Oct 15 2012
    Eagle, ID
    Per Brad Gardner - these will not work with the D3 A8/S8
    Aug 09 2013
    battle ground wa
    OEM suspension
