Results 1 to 13 of 13
    Established Member Two Rings B8-A4's Avatar
    Apr 05 2013
    PA
    AC only blows cold air when your driving?
    Ive been having this issue on and off with my AC, and when your sitting not driving it gets warm, then when you start to drive it cools down again. Whats your thoughts on this?
    Feb 22 2013
    '08 Jeep GC, '08 Roush Mustang, '65 Shelby GT350
    Westchester, New York
    x2 same with my 2012, only cold when in motion.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    First thing I would do is check to make sure your radiator fan is working when the car is idling with the AC on.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Senior Member Three Rings WngoA4's Avatar
    Jan 09 2012
    So.Cali
    I have the same issue with my 2012.
    2012 Premium Plus A4 : Moonlight Blue: Currently fighting the modding bug but losing the battle!
    Senior Member Two Rings AudiHockey's Avatar
    Jun 18 2012
    Huntington Beach, CA
    My 09 blows cold air while in motion and not in motion
    2009 Audi A4 2.0t Quattro
    Oct 02 2006
    Wadsworth,OH
    Could be that the condenser is not getting enough air flow. As others have said start with checking to see if your secondary fan is coming on when the AC is activated.
    Jason
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Well shit.....
    Apr 05 2013
    PA
    not really sure how much help that is :-),
    all my fans are working correctly when they should.
    just something else ill have audi look at when they tear my motor apart for new pistons and rings.
    Quote Originally Posted by AudiHockey View Post
    Oct 02 2006
    Wadsworth,OH
    Might want to throw a set of gauges on the AC system and check your high and low pressure too. If you know a friend with a shop that services AC they should have them.
    Jason
    Senior Member Three Rings Celiot29's Avatar
    Jul 17 2012
    boston ma
    I have always thought this was just a product of getting no airflow while stopped as I have had this in both my 09 and 13" a4 it's still cold when stopped just not nearly as cold as when in motion
    2013 Audi A4 Quattro brilliant black | light pckg | convenience pckg | 35% all around | RS4 grille | S4 trunk lid | S Line rear valence
    Sep 14 2006
    Well my ac just doesn't blow cold air period...
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    This is a bit confusing. Do you mean it blows LESS cold when not moving or NOT cold at all. Obviously it will blow less cold when the engine is at idle. That's every car, its belt driven.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by b4a41point8t View Post
    Not necessarily, it just depends on whether it is designed with sufficient capacity. They use variable displacement compressors that are constantly adjusting how much they pump per revolution, based on the cooling requirements. When the engine is at idle, the compressor will be turning slower, but it could still be pumping as much via increased stroke. Though if you've swapped out to a smaller crank pulley, I could see the capacity being reduced enough that it couldn't keep up at idle, even at max stroke. Even before variable displacement compressors became commonplace, the compressors would cycle based on suction pressure/temperature, so they could still maintain capacity at idle, IF it was sized sufficiently.
    With that said, I have noticed on my B8 that it typically goes through an odd period in the afternoon when I leave work on a hot day... when I come to a stop light shortly after leaving work, it goes through a brief period where it feels as if the AC has been switched off briefly, then back on. I've posted about it here. But that seems to be a brief one-time occurrence per cold start, it resumes normal cooling after that, even while still being at a stop.
    '11 S-Line A4 Avant
