Originally Posted by
Gromit
The pics in your build thread are awesome. The ones from after you installed the PSS10s look like you lowered more than the minimum 30mm lowering those coils require. Is that true? If so, what's your drop? And am I seeing that you dropped the front more than the rear? Great work on your ride!
Thanks man !
In the beginning, I had the H&R OE Springs installed on my car, the handling had improved comparing to the stock springs, but the damping seemed to get worse and there was always some crank noise in the front when I was driving through bumps.
Finally I decided to go with the coilovers. In fact, the PSS10 was a graduation gift from my GF.
When I got it installed, I told the tech that I wanted to maintain the same height as before. But 6 weeks later, all springs settled down, and rear tires started to rub the fender.
Then I have it adjusted----higher the rear only. And yes, the drop in the front is a little bit greater than rear but I'm not quite sure about the exact measurement.
Please pardon my spelling & grammar errors since English is not my mother tongue.
