I pulled the cylinder 6 coil/plug to diagnose a misfire and the hole was pooled with oil. I checked the other cylinders and all others have oil in them too. The 6cyl had the most oil so I assume that is what caused the misfire. Now I know a failed valve cover gasket would cause this but I replaced the gasket 3 months ago and it has not leaked anywhere else. The thing that stumps me is it is leaking from all cylinders, not just one. Is there anything that can cause a new vgc to fail or did I just get faulty parts.
