Update 8/31 11:00AM - Arnott GEN II front and rear air springs and Arnott Bilstein front and rear shock absorbers ordered from Arnott on eBay for $2,113.99 with free shipping. Also comes with hardware, front upper strut mounts, and o-rings.
Update 8/31 11:14AM - Hotchkis front and rear sway bar kit ordered from Summit Racing Equipment through their website for $449.97 with free shipping. Comes with bushings and mounting hardware.
Update 9/3 - eBay re manufactured steering rack ordered from eBay for $225.56 with free shipping. Comes with inner tie rod ends, boots, clamps, and Servotronic relay and is lifetime warranty!
Update 9/8 - FCP Euro control arm kit ordered from their website for $510.16 with ground shipping. Comes with all 8 control arms, inner tie rod ends, S4 style outer tie rod ends, front sway bar links, and complete hardware kit.
Well, now with the newly acquired allroad I think it's time to start getting things straight. I sold my B5 S4, and this is what I had for this section:
Steering/Suspension
Perform four-wheel alignment (133,395)
Perform power steering system flush using Seafoam Trans Tune and fill using Audi OEM power steering fluid (117,200)
Audi OEM power steering pump (78,479)
ECS Tuning lightweight black power steering pump pulley (137,536)
Hayden power steering oil cooler kit (includes core, mounting ties, hoses, and clamps) (133,395)
Master Pro left inner tie rod (123,000)
Moog left steering rack boot (123,000)
Meyle heavy duty outer tie rod end kit (includes hardware) (123,000)
Raceland coilover kit (includes wrenches and spring/damper assemblies) (133,127)
034 Motorsport street density front upper strut mounts (133,127)
034 Motorsport street density front control arm kit (includes hardware) (131,128)
034 Motorsport street density front sway bar links (includes hardware) (131,128)
Neuspeed rear sway bar (includes bushings, brackets, and hardware) (134,086)
Meyle heavy duty rear sway bar links (includes hardware) (131,336)
Audi OEM right front wheel bearing kit (includes hardware) (102,658)
Audi OEM right rear spindle assembly (91,152)
Audi OEM right rear wheel bearing kit (includes hardware) (91,152)
Audi B6 S4 18”x8” ET45 “Avus” wheels (with center caps)
Kuhmo Ecsta LE Sport 225/40/18 tires
Audi B5 S4 17”x7.5” ET45 “Avus” wheels (with center caps)
Bridgestone Blizzak WS-70 205/50/17 tires
AudiUP 5x100/5x112 12mm 57.1 hubcentric wheel spacer pair (includes ball seat bolts)
AudiUP 5x100/5x112 15mm 57.1 hubcentric wheel spacer pair (includes ball seat bolts)
Now, I know the allroad is going to have a different setup since it's an A6. The plan at this point is to get Arnott GEN 2 bags for the front and rear along with the Arnott Bilstein shocks for the front and rear. To go with those I plan on getting the Hotchkiss front and rear sway bars and installing 034's Street Density control arm kit in front and replacing the inner and outer tie rod ends with Meyle HD components. The sway bar links will also but upgraded using the Meyle HD links. I will be doing the power steering cooler like my B5 as well since it's a cheap mod and gets rid of the PITA metal tube in the front. I'm still not sold on a set of wheels yet, but I do still have the winter setup listed above that I may use.
What are your thoughts?
