Originally Posted by
LakeTahoeQuattr
Great that sounds like something I need to do now too. Can you eloborate a little more on this retrofit. I went to theretrofitsource and searched under a 2002 allroad and the only thing that poped up was a 3" ZKW-R
Also, I know bi-xenon was offered on the FL a6 as I have seen it on our 04 4.2, but how do you retrofit the signal to tell it to flip the lense to full on when the high beams are turned on on an allroad? Does the bi-xenon flapper motor or whatnot tap into the hi-beam on/off wire or something?
I'm in the everything is pieces and I keep working on other things phase.. so I don't have all the answers just yet.
Allegedly a 3" projector will fit in the AR housing I saw a build thread on one of the lighting forums where someone did it. So something like the 3" evo lights (someone just linked to I Forget where) in theory almost bolt directly up to the 3" late A6 lights, if the bolt pattern is the same they may bolt directly to the 2.5 early lights or allroad lights. So the ZKW-R is one that might bolt up to a 3" and possibly the E55 (I think that is what it is called) I've seen installs of but that took a little modifying of mounts.
What some people do is bolt threaded rod to the new projector then epoxy that to the shroud part of the factory light. This obviously works but you kind of get one shot. Some lights you can rotate the reflector/cut off in relation to the mounting holes to align them others you cannot. The ones I'm using you can't so I need it to be lined up first time. My plan is to make aluminum tabs that go from the factory holes to the holes that fit my new projectors, that is where I have left off and just drew up the other day to make sure no holes overlapped in a complicated way (on another computer I"ll post later).
There is also the issue with front to back, like if the mounting surface to front of the lens is different you need to account for that or it makes making thick mounting tabs impossible due to it changing height. So it can be a little tricky.
Since nothing really is a straight bolt in to these lights I think they are hesitant to say this is a direct plug and play kit like some other cars have.
As for the bi-xenon flap, yes taps into high beam signal, you can get splitters that plug between the high beam bulb harness and split it to like an amp connector and then the other side is an H7 (or whatever your bulb is) to plug back into the stock light. It is a very low draw motor on the flap so if you are using stock wattage high beam bulbs should not be an issue. This is all most factory systems do anyway, share that circuit. If you were running higher wattage high beams I"d probably use the stock signal to trigger the flapper and then relay the new high beam bulbs, safest way to do that but uncommon for most here. I'll probably just tap into the high beam + wire for the flap, no need to spend money on a fancy splitter when it is all apart and I can easily work with the harness :)
Many of the projectors are clones (or refurbs) of the vehicle they are based off hence the names of like FX (infinity) and evo... self explanatory.
