Results 1 to 23 of 23
    Veteran Member Four Rings wootek's Avatar
    Jan 10 2012
    Philadelphia, PA
    Motorcycle like noise from my engine
    Ever since last night my car makes motorcycle engine noise when I drive my car its very unusual. Car react absolutly normal but the noise I know it's very hard to explain but this noise wasn't here before. My car is 2010 A5 2.0t model.
    Here's youtube link to the sound
    http://www.youtube.com/watch?v=AwrC1rhvzfE
    http://www.youtube.com/watch?v=-9JsMcZwYgI
    from Galaxy Note II
    2010 A5 2.0T Ibis white | APR KO4 | RS5 Grille | BBS CI-R 20x10 DPE CS-16 20x10 (20" RS5 Rotor for winter) | H&R OE | Caractere spoiler | AWE Quad Exhaust | AWE Downpipe | AWE Boost Gauge | 2013 Refresh Tail lights | VAG-COM Mods | Rieger RS5 Style bumper | E-Codes | STaSIS Sway Bar | KMD Tuning Diverter Valve | Eurocode Goodies | Alu Kreuz | Rieger window spoiler | Brembo GT 6 Piston 380mm | BFI FMIC
    Aug 04 2010
    Queenz/Westchester
    Hog or crotch rocket?
    Jan 10 2012
    Philadelphia, PA
    Re: Motorcycle like noise from my engine
    Quote Originally Posted by shonseb View Post
    What r u talking about?
    from Galaxy Note II
    Aug 04 2010
    Queenz/Westchester
    Lol, i'm trying to figure out what kinda sound it is. Does it sound like a harley or a GXR? Have you noticed it change with RPM's, Speed, in different gears? making turns or braking? Low pitch or high pitched sound?
    Jan 10 2012
    Philadelphia, PA
    LoL sorry, it makes high pitch reving when u step on gas and let go on neutral
    from Galaxy Note II
    Established Member Two Rings bdons's Avatar
    Oct 31 2012
    07 cayman s
    Raleigh NC
    I'd say its probly the filter and turbo.
    2013 A5 Phantom Black on black
    Savini wheels/ custom turbo back exhaust/ custom high flow intake/ rs5 grill/ test pipe/ UD pulley/ cts turbo fmic and piping/ APR stage 2 e85/ h&r springs/ eurocode sway bars & end links/ Alu Kreuz / full tint/ vagcom mods/ all led
    Aug 04 2010
    Queenz/Westchester
    It's all good, I should have worded it better.
    Hmmm, not really sure. but if it's just in neutral I would point to the clutch first (flywheel?). Any change when using the clutch recently? besides the FB wheel, did you do any other mods?
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by bdons View Post
    Thats what I was thinking first, but he said no change in the way the engine acts.
    Edit: also check engine light would come on because of the MAF
    Jan 10 2012
    Philadelphia, PA
    It also sounds some what like plane its reallh hard to explain.
    from Galaxy Note II
    Aug 04 2010
    Queenz/Westchester
    ok that does sound like the turbo... Are you sure you never heard it before and maybe just noticing now? Also did you clean your air filter recently?
    Sep 28 2010
    NW NC / DE
    LULZ.
    Jan 10 2012
    Philadelphia, PA
    I got the eurocode turbo inlet hose along with afe filter about going on two month
    from Galaxy Note II
    Veteran Member Four Rings ssv22's Avatar
    Aug 31 2011
    Washer & Dryer
    CA
    did u open the hood? maybe some one stole the 2.0?
    Jan 10 2012
    Philadelphia, PA
    I know it's hard to tell but I could hear it from this video, it seems like the noise is getting louder when you let the gas go.
    Aug 04 2010
    Queenz/Westchester
    I couldn't hear it right of the bat, but I eventual did hear it. Sounds like a prop plane. I haven't got a clue what that is. Maybe ask the a4 guys since they know a lot more about the 2.0
    Sent from my Nexus 4 using Tapatalk 4
    Jan 10 2012
    Philadelphia, PA
    First thought it could be bearing but not sure about that or it sounds like it could be loose clamp under the car
    from Galaxy S4
    Veteran Member Four Rings Just A B8's Avatar
    Sep 29 2012
    is Messy!
    Northern NJ
    Check this thread out and read what the OP is describing with his issue. It might be that your wheel bearing is shot. Try unloading weight by driving and swerving (of course in closed road conditions) to see if the sound disappears when you turn left or right while going on the speed that you hear the sound.
    B8 A4 | PRESTIGE | S-LINE | SPORTS PACKAGE
    034 | AIRLIFT | AFE | APIKOL | APR | AVANT GARDE | AWE | BILSTEIN | DEFI | DEVAL | EUROCODE | HOEN | ROC-EURO | SPC | VIAIR | XPEL | YAKIMA
    Veteran Member Three Rings Zee Dgerman's Avatar
    Sep 06 2010
    Montréal
    Sounds to me like a defective wheel bearing. I've had 2 changed on my S4. I initially thought like you there was a problem with the transmission, turbo or engine. I'm pretty sure that's your problem, get it changed asap.
    Ian
    Quote Originally Posted by wootek View Post
    from Galaxy Note II
    Jan 10 2012
    Philadelphia, PA
    Quote Originally Posted by Captain Freez View Post
    Ian
    Did it sound like reving noise?
    from Galaxy S4
    Oct 31 2012
    07 cayman s
    Raleigh NC
    I watched the videos and I agree that it sounds like a wheel bearing but without further experimenting I couldn't say. Also have you modified the exhaust recently? Check to see if you have any exhaust leaks or damage to the muffler because my exhaust will growl a little louder as I slow down to a stop.
    Jan 10 2012
    Philadelphia, PA
    No, didnt scraped or modified my exhaust area at all.
    from Galaxy S4
    Sep 06 2010
    Montréal
    from Galaxy S4
    Yes
    2023 Audi A4 Allroad - Ordered
    2019 Audi SQ5
    2018 Audi Q5 - Sold, 2016 Audi S3 - - Sold, 2013 Audi RS5 - Crashed , 2010 BMW X3 - Sold
    2010 Audi S4 - Sold, 2006 BMW X3 - Sold, 2003 Subaru WRX R1 - Sold, 2001 Subaru WRX - Sold
    1998 BMW M Roadster - Sold, 1997 Honda Prelude - Sold, 1996 Acura Integra - Sold
    Aug 04 2010
    Queenz/Westchester
    So.... what happened with the noise?
