    Jan 30 2009
    New York, LI
    2011 A4 shutting off while driving...
    Hello, my A4 is APR stage 1 and Ive been having some trouble with it during my commutes to work. During the little hiccups, the motor would not rev past 2500 and then would shut off followed by a whole host of error messages. I scanned it tonight and Code: P2294
    Category: Powertrain
    Definition: Fuel Pressure Regulator 2 Control Circuit/Open
    This is what came up. Any info on this problem would be greatly appreciated. Thanks!
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    overheating perhaps? maybe a fan or pump is not working
    2010 A4 quattro, Tiptronic, Ibis White
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    I take no credit for this but searched your code and this is what came up:
    P2293 & P2294
    Possible Causes:
    Fuel Pressure too Low
    Intake Camshaft Failure
    Possible Solutions
    Check Measuring Values for Fuel Pressure
    Check for bent/squeezed Fuel Lines
    Check Fuel Pressure System for Leaks
    Check Fuel Filter & Filter in Fuel Pump
    Check Fuel Quantity supplied by the Fuel Pump
    Special Notes
    Check Fuel Pressure
    North American Region (NAR) check TSB 2015153 (01-09-03 > 15-10-01 > 15-10-02), the Intake Camshaft might have a worn out Fuel Pump Cam.
    Check the Fuel Pressure first.
    Special Functions
    Checking Fuel Pressure
    Prerequisites:
    Ignition ON
    Engine ON (Idle)
    System voltage at least 11.0 V.
    Coolant Temperature at least 80 °C
    [Select]
    [01 - Engine]
    [Meas. Blocks - 08]
    Group 103
    [Go!]
    Field 1: Fuel Pressure (Low), Specification: 2800...7200 mbar
    Field 2: Fuel Pump Adaptation, Specification: -1000...+1000 %
    Group 140
    [Go!]
    Field 3: Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
    Increase the Engine Speed while checking this value, the Pressure has to rise with the Engine Speed.
    Group 230
    [Go!]
    Field 1: Specified Fuel Rail Pressure (High)
    Field 2: Actual Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
    Field 3: Deviation between specified and actual fuel pressure, Specification: max. 5.0 bar
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    North American Region (NAR) check TSB 2018183 (20-08-01) and verify the High Fuel Pressure Sensor (G247) Part Number
    I would make sure you are giving the car high quality fuel either 91 or 93 octane - preferably top tier fuel as recommended by Audi and maybe throw in some fuel system cleaner from Chevron Complete Fuel System Cleaner. Perhaps you just got a bad batch of fuel...try a different station or something and see how it is....if the problem persists then I would look into fuel filter/pump. Good luck.
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    We talked about this issue in another thread. This happened to me once too with me chalking up to having the wrong dipstick. Someone mentioned it may have been the transmission filter.
    Euro Tails Crew
    Senior Member Three Rings Celiot29's Avatar
    Jul 17 2012
    boston ma
    High pressure fuel pump possibly as mine did the same thing, though it wasnt intermittent so maybe not
    If so it was about 400 bucks out of warranty at dealer
    2013 Audi A4 Quattro brilliant black | light pckg | convenience pckg | 35% all around | RS4 grille | S4 trunk lid | S Line rear valence
