Okay so... I bought a 99 Audi A4 from this guy and he straight up told me that the water pump is bad, timing belt could use a change, and the throttle body was out. I made a decent deal with him and ended up getting it towed after i drove it off the lot for awhile for fear it it would over heat/timing belt snap.
So i replaced the timing belt on it and the water pump and now the car wont start. I put my brother in-law's CEL checker on it and i got the following errors;
P1545-Exhast gas temp sensor circuit low Bank 1 Sensor
P1338-Camshaft position sensor A circuit high input
P1392-Camshaft potion sensor B bank 2 Circuit low input
I know for a fact that i got the timing belt on after about 1000 attempts i got the cams lined up and i got the crank on line. I ended up using pain on the cams and belt and the crank to the block so i knew how many teeth and all i needed to adjust my belt. I read on a different thread that the 96 that the Camshaft sensor, MAF sensor, Engine coolant sensor, and outside air sensor all run into the same wire into the computer.
Any other help or confirmation of my dug up info would be appreciated.
I've just spent too much money to throw this away... Its making for a nice project though!
