So as i was changing out the CTS (P2181 along with t-stat), i saw quite a lot of oil build-up on my transmission case and down the back of the engine. This leak actually got slightly worse while the front of the car was raised on jack-stands. After some research I believe i have narrowed it down to the vacuum pump. Using thing thread as a reference:
http://www.audizine.com/forum/showth...=1#post7971687
So here is my question:
How can i determine if it is the pump leaking or if it is just the o-ring?
I have tried getting my cell phone in there and recording a video to see if i can spot the leak, but i could not get a good enough angle to find a leak.
The o-ring itself is about $13 shipped from ECS, but an entire pump assembly is about $300.
Based on the pictures, the back of the pump comes off, is it possible to take it apart and "re-seal" it using a liquid gasket?
so far i have already replaced the CTS, T-stat, pcv, belt tensioner, serpentine belt, and valve cover gasket. The cam follower and oil change is also in the near future. I have only owned the car for about 3 weeks, so i would prefer not to buy a $300 pump.
Thank you everyone in advance!!
