Results 1 to 11 of 11
    Jul 23 2013
    United States
    New tires 275/40/19
    Hey I need a help.Found great deal on new continental extreme contact dws tires
    but here is a problem
    2 tires are 245/40r 19 and
    2 tires 275/40r 19
    I have audi A5 S-line with OEM audi Y spoke rims
    I would like to know if any of you have 275 tires installed on A5 and this rims.Im scared that rear tires will be too wide
    Sep 02 2005
    Montreal
    Forget that deal, those are wrong sizes. The 275 is too wide, and the 40 series is too big. Don't do it.
    Jul 23 2013
    United States
    Thanks
    I have now 255/40 19
    im scared that 35 will be too low,in chicago we dont have that good roads a lot potholes :))
    so 275 is way too wide?
    Jan 07 2011
    2013 C300 4Matic
    way too wide.
    nyc has bad roads. i run 35 profile. just drive carefully. not like a mad man.
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Sep 28 2010
    NW NC / DE
    255/35 on a 19 is plenty of rubber. Seriously.
    Jul 23 2013
    United States
    So I should go with 255/35?
    any advice for good all season tires?
    Sep 28 2010
    NW NC / DE
    Yes.
    The new Pilot A/S 3 has excellent reviews. Also look at the nero m+s.
    Oct 16 2006
    Naperville
    **might be too wide for the stock 19s. I run 275 on a 20x10" wheel on the s5.
    May 02 2013
    Las Vegas
    what are the stock 19 peelers size? and how many different sizes are there normally for 19 inch rims?
    Sep 28 2010
    NW NC / DE
    New tires 275/40/19
    8.5"
    Sent from my iPhone
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    sidewall thickness: 275*.4=110 -new proposed
    sidewall thickness: 255*.35=89.25 - stock
    Meaning, you will be sitting approx 2" higher off the ground compared to stock.
    Also Conti conveniently tells you what the optimal rim width goes with what tire size, check out the chart http://www.continentaltire.com/www/d...tasheet_en.pdf
    '23 Tesla Model X | '17 Ducati Supersport S
