Results 1 to 7 of 7
    Jul 31 2013
    Maricopa, AZ
    OBD2 error codes: P0444 and P0243 and P2400 (EPC light on, but went off)
    Hi,
    I recently had these 3 error codes pop up (P0444 ; P0243 ; P2400). My car is an AUDI A4 B7 2.0T Convertible (104k miles, timing belt replaced at 82k). I have looked around this and other forums and I have found some useful information for each code separately. But I was wondering if there might a be a connection to these fault codes all popping up around the same time. Also EPC light went on but then just went away.
    I only had problems with coil packs prior to these problems. (about 1 coil pack breaks down every 7500 miles...)
    These codes come from Torque and OBD2 reader (not VAGcom)
    P0444: Evaporative Emission Control System Purge Control Valve Circuit Open
    P0243: Turbo/Super Charger Wastegate Solenoid "A"
    P2400: Evaporative Emission System Leak Detect Pump Control Circuit/Open
    All help would b greatly be appreciated.
    Veteran Member Three Rings S4Phantom's Avatar
    Jun 10 2012
    Im gonna guess and say that the solenoid is probably the problem and that is throwing the 2 evap codes
    2011 Phantom Black S4 Prestige Titanium Pkg., Sport Diff., Alu Kreuz, Milltek Non-resonated exhaust with oval tips, AWE Carbon Fiber intake, Stage 1 GIAC, Black powder coated Titanium Pkg wheels
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    N80
    Diverted valve
    Pcv valve
    Jul 31 2013
    Maricopa, AZ
    is the solenoid, the N80 purge valve: part nr 06E906517A
    or is the solenoid something else? thanks
    Jun 27 2011
    Quote Originally Posted by flapus007 View Post
    Yes, the N80 is that part number. That SHOULD take care of both the evap codes. If not then you might have an issue with the Leak detection pump or the charcoal canister.
    Not sure about the P0243 but the wastegate solenoid is the N75. It might not be plugged in, or it could be faulty. Here is the part: http://www.ecstuning.com/Audi-B7_A4-...N75/ES2574871/
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 29 2021
    Takoma Park, Maryland
    Hi, came across this thread which applies to my current problem. I have the same 3 codes (243, 0444, 2400) plus 2294. I replaced N80 purge valve, and checked PCV, which seemed good. (I unplugged hose to intake manifold, capped that port on the manifold). I didn't open it to check the diaphragm, but the problem is so intermittent that I don't think the PCV wold cause the symptoms I'm getting.
    Start up cold, often times get flashing EPC light, obvious misfire (usually cylinder 3) always CEL. Sometimes the symptoms will simply disappear if I do a key cycle. Sometimes the symptoms will simply vanish.
    Just interested to know if the problem described in this thread was resolved and what it turned out to be.
    I guess my next steps will be to checked the waste gate solenoid. I don't believe this car has ever had a diverter valve, either, based on the service history.
    Sorry for the ramble, thanks much for reading!
    Aug 29 2021
    I guess it's obvious, but I should probably mention the car is an 07 2.0 B7, (with 186,000 miles behind it!)
