Results 1 to 13 of 13
    Senior Member Two Rings NJeuro's Avatar
    Apr 20 2010
    hamilton nj
    New fuel pump now misfiring wtf
    Ok so last week my car died on me and wouldn't start back up check fuel pressure at rail no fuel .. Check power and ground at the pump all ok .. Order and installed bosch 40 pump from 034 Motorsports .. Started it up ran ok took it for a ride started misfiring and sounds like it was backfiring through the intake .. I thought maybe the wot box was messing up sounds like I'm hitting 2 step when I try to accelerate .. So I disconnected the wot box jump the coil wire still misfiring .. Now I checked fuel pressure at the rail seems ok .. I don't know what it could be .. My a/f gauge reads 14.1 and goes up when I give it some gas .. Anyone could help would be appreciated
    Established Member Four Rings milan2k13's Avatar
    Jun 09 2013
    Orlando, FL 407
    I believe I've read a lot of negative reviews on that pump. What stage are you, that's a high flow pump
    More Power, More Problems! 1.8Tiny
    B6 ---> Motoza Stage 1+ | 550cc | 034 HFC | Forge TIP | Forge 007 DV | 2.0T FSI Coils | NGK BKR7E | K&N Drop-In | 93 Proof |
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I don't have any problems with my Bosch 040 fuel pump. Bought the drop in kit from 034 Motorsport. Do a scan to seee where the misfires are happening. Could be that one of the ignition coils is going bad... or the spark plugs are fouled.
    How are the injectors? Looks like you're running way too lean. You shouldn't be that high (or going higher) for your A/F reading. See if you can find someone who can measure the fuel pressure to make sure you're getting enough. The OEM pump (and the Bosch 040) should be delivering 4 bar of fuel pressure.
    USP CLUB MEMBER #34
    Apr 20 2010
    hamilton nj
    I finally got around to look at the car today traced my steps back to the fuel pump and found the efi hose i use from the fuel pump to the sending unit split open caused not enough fuel pressure causing the misfire .. What type of hose are using from the pump to the sending unit CYBERPMG .. I also notice im running extremely rich 10.0 af at idle and doesn't really change at all while im in boost
    Dec 05 2007
    I'm running regular Autozone fuel hose (I think) in my tank on a B5 A4 with an 044. No issues, despite warnings not to run that hose in the tank. My suggestion is to fit the stock hose if you can.
    Apr 20 2010
    hamilton nj
    I did the same size hose keeps splitting through , second hose this week
    Im thinking that the bend is to much for the hose and causing it to split
    Feb 23 2004
    Stow, OH
    I did get the fuel line kit from 034 Motorsport. It's a braided line that goes from the fuel rail back to the pump.
    http://www.034motorsport.com/fuel-in...n-p-18675.html
    USP CLUB MEMBER #34
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Quote Originally Posted by NJeuro View Post
    Does it idle at 4 bar?
    http://www.audizine.com/forum/showth...ssure-too-high
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Nov 17 2008
    Im assuming that you meant the OEM plastic hose from the pump outlet to the tank lid split?
    -Andrew
    Apr 20 2010
    hamilton nj
    Yeah I'm talking about the hose from the pump to the tank lid split. I'm using 5/16 efi hose .. I know it running way to rich if my a/f is 10.0 . I might have to drill the fuel filter return line out has anyone done this before
    Jan 12 2012
    kearneysville wv
    Hey man i know this is an old post but i am having this same issue, did you ever find a solution. Im on my 3rd hose and it just split again.
    Apr 20 2010
    hamilton nj
    Jromine I finally got some high pressure efi hose that's holding up . I modified the fuel filter and still running crazy rich I can small the fuel not being burned
    Established Member Two Rings TravisSavoie's Avatar
    Nov 06 2012
    Webster
    You should try the DW300 fuel pump, i just installed mine and i love it!
