Results 1 to 3 of 3
    Jul 01 2013
    PA
    Pros and cons of resonator Delete
    what are the pros to this? Im thinking about putting the vibrant 1149 eithor 3" inlet to 3'' dual tip with a new Y pipe that goes into a 3'' downpipe instead of the stock one that goes into eithor 2.25 or 2.4 i cant remember witch. i dont know weather to get a high flow resonator, this guys sounds really nice http://www.youtube.com/watch?v=3yIeIjUJfeQ
    But i also am thinking about just stock Y pipe and just putting a straight pipe to the muffler no resonator, this sounds real good also but i dont know if theres a power increase from no res or fatter pipes. any suggestions??
    riding dirty since 94
    2001 2.8 30v A4 ebony pearl
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Re: Pros and cons of resonator Delete
    Con - a LOT more cabin noise
    Sent from my Galaxy S4 using Tapatalk 2
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    If you don't have a ton of money, most 2.8L I believe are just doing stuff like this guy,
    http://www.audizine.com/forum/showth...-exhaust-build
    But sometimes instead of a resonator they just put a muffler on and skip the resonator.
    I'm currently in the process of trying to figure out how I want to do my custom exhaust I'm going to just basically chop off after the two cats, weld on a Y adapter to a single pipe...Then straight pipe to a muffler.
    Just still trying to work out the inlet dimensions and outlet dimensions..
