Results 1 to 40 of 41
    Aug 18 2011
    Clunking noise coming from the rear in low speed maneuvers
    I've researched rear clunking noise and a lot of results seem to point to suspension components (control arms, etc.)
    My car is a 2013 with the AK, Eurocode bars and endlinks. I installed sway bars 2 months ago and haven't heard this noise until 2 days ago.
    The clunking seems to be happening more during turns and almost exclusively at low speeds. Going over bumps and uneven road doesn't seem to induce this clunking. When I turn around a sharp corner slowly in a parking garage, for example, there is a periodic clunk (sounds metallic, every 1-2 seconds) coming from the rear. Also happens when I straighten out the wheel sometimes and go straight, mostly at low speed.
    I suspect it may be a leaking sport diff, but I haven't had the chance to look under the car.
    Has anyone else experienced this? I'm gonna scan for codes with VCDS tonight and take it to the dealer tomorrow.
    EDIT: I should add: I'm at 14200 miles.
    Senior Member Two Rings bbhbba's Avatar
    Mar 06 2011
    '17 BMW 440i Grand Coupe MPPSK ; '18 Audi SQ5 TDI
    Nor Cal Bay Area
    I have similar small knocking noise coming from the rear. I have same setup as you and USS+end links were installed less than 2 weeks ago. It happens more often when I'm backing up slowly, <5mph. I don't think it'd be the sport diff as it started after USS was installed. I'll get down there and re-check all bolts this weekend to see if anyhing is loose.
    2013 S4 Prestige S-Tronic
    Senior Member Two Rings trinacria's Avatar
    Jun 06 2010
    LI,NY
    Quote Originally Posted by bbhbba View Post
    I have similar small knocking noise coming from the rear. I have same setup as you and USS+end links were installed less than 2 weeks ago. It happens more often when I'm backing up slowly, &lt;5mph. I don't think it'd be the sport diff as it started after USS was installed. I'll get down there and re-check all bolts this weekend to see if anyhing is loose.
    I'm on stock suspension and have same noise when backing slowly. I have SD an 43k on odo.
    Aug 18 2011
    Just stopped by a shop and they told me my stretch bolts for the Eurocode sways/links loosened up. Apparently, it's been happening occasionally. They re-tightened them and the noise is gone.
    Feb 25 2013
    MI
    Good to hear, I just did the install a week or so ago and the noise is pretty bad (had a hard time torquing the front end links while on ramps), I'll get under there this weekend and make it proper.
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    Quote Originally Posted by rs4dreams View Post
    Glad to hear it all worked out.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Stage 3 Forum Advertiser Four Rings David@EuroCode's Avatar
    May 26 2004
    Quote Originally Posted by trinacria View Post
    We have had 3 cars on stock suspension doing the same exact thing but have not been able to narrow it down. :(
    "If everything seems under control, you're just not going fast enough."
    - Mario Andretti
    Sep 12 2009
    Torrance, CA
    Looks like I'll be tightening bolts this weekend. Would Loctite help?
    Current: 2022 e-tron: Navarra Blue P+
    Previous: 2011 A4 Quartz Grey Metallic P+ 6MT Sport Package
    May 26 2004
    Quote Originally Posted by grnfool View Post
    These are stretch bolts, if installed torqued to spec and stretched correctly they will not back out and no loctite should be required.
    - Mario Andretti
    Jun 06 2010
    LI,NY
    Quote Originally Posted by David@EuroCode View Post
    Yeah Dave, that's why I chimed in. I don't think this has to do with your bars or end links.
    Aug 18 2011
    Perhaps I'm not understanding fully, but something doesn't add up. I had the clunking from the rear, took it in to Achtuning, who did the original install of my sways/endlinks and they said that the stretch bolts were loose. Did they need to use a new set of stretch bolts since they needed to re-tighten them?
    Also, what could have been the cause of them coming loose in the first place? It happened about 2 months after the original install. After they re-tightened them, I've had no clunking.
    Also, I am still getting high-pitched squeaking from the rear on some drives though, even though the shop said that the endlink bearings were greased up well. Could something else related to the bars/links be the culprit there?
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Is it EuroCode stuff you have on? If so, it wouldn't be the first time a full metal ball joint sway endlink decided to squeak after usage. Why do you think Audi doesn't put them on the car as OE?... Because everyone would be bitching that their 50k car squeaks too much. People that buy performance cars will sometimes even bitch that their brakes squeak because they're performance disks/pads. It's hard to find that happy median.
    Also, as a personal question... If it is EuroCode sways you have, are yours the ones where they took the bar and just pinched the ends closed (not welding them)? I've seen pics of those and because of that construction, there is a chance for water to get in where the hole for the screw is and also the very end of the bar and cause some rusting... this could also lead to some squeaks. Take a closer look.
    Aug 18 2011
    Quote Originally Posted by SwankPeRFection View Post
    Yup, I've got the EuroCode stuff on and happy with them overall. I can live with the occasional squeaking for the added performance it offers. Eurocode seems to claim that they shouldn't make any noise though and it appears that most people don't have this issue. Also, my fronts don't squeak.
    Not sure what you mean by pinching vs. welding, but it looks welded to me: link
    Aug 05 2013
    N/A
    Yes, those look welded in those pics as if they changed the design on the ends to better meet what a properly built sway bar should look like. Take a look here... http://www.youtube.com/watch?v=98m0GdhVIQ4 Those are also EuroCode sways, but I'm betting an older design. Can't say which ones you have, but it was worth a mention since I too had the same concerns with the original design of their product.
    Dec 05 2010
    Los Angeles, CA
    I have had Eurocode sways and end links for about one year on my 2013 Audi S4. I had to replace the rear end links about six months ago and the front ones a few weeks ago. Apparently the bearings can become loose and cause the suspension knocking noise. The noise goes away as soon as they are replaced. After looking at the OEM end links I'd rather live with occasional noise with the EC links.
    Aug 05 2013
    N/A
    Quote Originally Posted by BzzzBom View Post
    I have had Eurocode sways and end links for about one year on my 2013 Audi S4. I had to replace one rear end link about six months ago and one front one a few weeks ago. Apparently the bearings can become loose and cause the suspension knocking noise. The noise goes away as soon as they are replaced. After looking at the OEM end links I'd rather live with occasional noise with the EC links.
    Or we could complain to EC about it and have them correct the design issue with them that's causing this problem. They aren't the only company in history to design solid metal endlinks with ball joints that have metal to metal contact, but they seem to be one of the ones that have noise problems with them. I'd vote on inferior metal or bearing usage or poor geometry in the design as the cause for this. It's certainly something EC should go back and figure out what to do to correct it for future customers.
    May 26 2004
    The rod ends we use do not squeak as they are teflon coated, they can and will make a clonking noise only if the teflon coating has shifted or time has taken its tole and created radial play. The factory rubber piece collapses after about a year or two and stops doing its job as intended. The design of the factory bars cause the links to sit cocked when attached to the shock fork causing the bushing to deform prematurely. The design on the bar can't be changed as it wold cause it to interfere with other components on the vehicle. This means that although the factory droplinkis do not make noise, its deflection behavior as a result of the collapsed sections cause it to no longer be predictable and require replacement just as the spherical ends. The only difference is that the factory bushing while damaged can be driven on for 200K and wont make noise or alert you that they have been shot for the last 170K. The benefit of the spherical end is that it will still do its job just as intended even when it gets noisy. Replacement cost of the EuroCode rod end rebuild kit is less than what it costs to replace the factory droplinks.
    There is no such squeaking that will take place as a result of any water entering the crimped ends of the sway bars. From the thousands of bars sold world wide from the arctic to south east Asia not a single complaint of squeaking other than when the bushing were not lubed correctly or just needed to be re-lubed as they became dry over time.
    - Mario Andretti
    May 26 2004
    We had too many bars being rejected during QC as a result of the crimped ends not being perfect, this made us go with a solid forged end to have better consistency and less rejects.
    - Mario Andretti
    May 26 2004
    We use only the highest grade bearings and rod ends made 100% in the united states by FK Bearings. These bearings not only have the highest radial load possible for their size, but also do not carry the same teflon coating as the run of the mill FK part, additional provision have been made to ensure a better end user experience.
    With that said we do not design nor manufacture rod ends or bearings. These bearings do not have metal on metal contact- there is a teflon coating on the inside of every race. There are no geometry issues with the parts designed and no inferior metal was used to manufacture these parts, only certified aluminum. We tested several other brand rod ends back in 2009 when we first acquired our B8 and ended up using FK. Although they are the most expensive they were also the product which passed our 40K mile test the best using our 4 in house B8/B8.5 vehicles. At one point we had 4 different rod ends simultaneously on the same car each end of every link on both sides were different allowing us to cycle all four through the same scenario.
    As noted previously all spherical bearings will develop radial play over time causing the ball end to move and make noise, this typically takes place over 1-2 years of use.
    Below pasted from a previous post with regards to the factory links.
    This means that although the factory droplinks do not making noise, the deflection behavior as a result of the collapsed sections would cause it to no longer be predictable and require replacement just as the spherical ends. Only difference is that the factory bushing while damaged can be driven on for 200K and won’t make noise or alert you that they have been shot for the last 170K. The benefit of the spherical end is that it will still do its job just as intended even when it gets noisy. Replacement cost of the EuroCode rod end rebuild kit is less than what it costs to replace the factory droplinks.
    - Mario Andretti
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Prior to may last track day, I took my car in to a local Audi indy shop to diagnose some front suspension noise. I suspected (and they confirmed) the EC end links. While I fully accept this is part of the deal when you start to replace factory parts (where NVH is of prime concern), I was hoping to get more than one winter and 6 track days out of these (they've been rattling since the spring). The noise is most obvious when the links are unloaded, i.e. travelling on a straight road with small bumps.
    David, what is the cost of the rebuild kit? I want to get this done as I'm tired of my wife saying my car sounds like a bucket of bolts every time I go over a manhole cover. Even if rebuild is an annual thing, I would still never to back to the stock bars/links.
    May 26 2004
    Quote Originally Posted by Leor604 View Post
    Track days put far greater stress on the links and thus will cause them to develop radial play much sooner. This is true for every parts of your car when tracking it. My general rule of thumb for track days is that each day is the equivalent of putting 10K on the street.
    As for the pricing on the kit I'm going to have Greg respond to that tomorrow, he was putting a SKU together. For the last three years we have not had anymore more than a hand full of requests for replacement, but as the kits get older it's come time. He should have it all up and available by the end of this week.
    - Mario Andretti
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    David:
    Aside from suspension components, tires and the clutch, what other specific components do you think one track day puts on the equivalent of 10k street miles?
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    May 25 2010
    Vancouver
    Perfect, thank you David.
    Yeah, we all know that tracking is stressful on the car. Every time I finish a track day I feel a little guilty about what I'm doing to my nice car. That feeling lasts about a day and then I'm anxiously looking forward to the next one. I guess there are worse things to be addicted to, lol.
    May 26 2004
    Quote Originally Posted by s4buckeye View Post
    David:
    Suspension would consist of Shocks, Control arms, strut mounts & wheel bearing, the steering rack, tie rod ends, sport differential, differential mount, engine mount & transmission mounts all take a beating.
    - Mario Andretti
    May 26 2004
    Right there with you on that, I've been tracking Audi's since 2002 and have never looked back. It is an expensive hobby for sure, but one that I'm very proud of.
    You have not driven a car until you have taken to the track at least once!
    - Mario Andretti
    Dec 05 2010
    Los Angeles, CA
    Are the end link replacement kits available yet?
    Mar 06 2011
    Nor Cal Bay Area
    Thumbs up
    I thought I'd give the B8 S4 community an update. I got a chance to put the car on a lift and re-checked all the nuts and bolts and everything was nice and tight. The knocking noise turned out to be coming from the tire pressure gauge (http://www.amazon.com/Joes-Racing-32...rds=tire+gauge) in my trunk . After I secured that tire pressure gauge, there has been NO MORE knocking sound. While searching for the source of the knocking sound, EuroCode has been nothing to truly great and helpful. Two thumps up to them!!
    Dec 05 2010
    Los Angeles, CA
    Eurocode has also been great helping diagnose and fix my end link clunking noise
    May 26 2004
    That is too funny. Thank you for the kind words!
    We work hard at supporting our customers as without each and every one of you there would be no EuroCode!!!
    - Mario Andretti
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Getting it here too on stock suspension. Of course, I'm at 51k.
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    May 26 2004
    Quote Originally Posted by Brooklyn View Post
    Thanks for sharing this info, as with all components factory or aftermarket nothing will last forever.
    Wonder how SwankPeRFection is going to respond to this one.
    - Mario Andretti
    Dec 05 2010
    Los Angeles, CA
    Going in to Eurocode tomorrow to have David drive and check my car. I am still getting a creak / slight clunking noise when backing out of my driveway or driving at slow speeds over an uneven surface. The noises are more pronounced after I have been driving for awhile.
    Established Member Two Rings willyspub's Avatar
    May 21 2011
    Houston TX
    Same question. I have the same clunking noise others have described here, presumably from the end links (tightened up the stretch bolts and the sounds remain). I too get the bucket-of-bolts comments from the wife, she absolutely hates riding in my car now.
    Dec 05 2010
    Los Angeles, CA
    Quote Originally Posted by willyspub View Post
    My noise is much more subtle and occurs mainly when the car has been driven for awhile. I am not a mechanic (far from it) but it sounds like play between the links and sway or sway and bushings. David will figure it out. He has been very patient and always helps me out no matter how small the concern. My wife tells me to just turn on the radio and forget the noise - probably a good idea :)
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    These cars make noise... mine clunks a little in back as well, the brakes squeel during light braking, etc. I think that clunking comes with the high performance part territory. Took my car to ETMS and they checked everything, all tight. Also now when I go full lock to the left then start turning opposite as in when parallel parking the left suspension makes a low snapping sound....
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Dec 05 2010
    Los Angeles, CA
    Last week the Eurocode techs removed my rear sways and end links and the rear noise was still present. After reviewing numerous threads on Audizine and Audi World it seems that our stock Quattro Audis make a lot of creaks, rattles and moans especially when driving on crappy roads (I live in L.A.). The Eurocode suspension parts totally transformed the handling of my car and I am glad they were not the culprit. The folks at Eurocode have been awesome and patient while helping sort this all out.
    2019 Nardo with all OEM options
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    I too have the EC sways and end links and am dealing with the low speed clunking noises. I also had the squeaking noises but hit the OEM bushings with silicon spray and that seemed to effectively addressed that annoyance. I will have to disconnect the end links and see if that is the source of the clunking. Admittedly, I am getting a little OCD about this as I am frustrated I have not been able to identify the source and correct it.
    Dec 24 2008
    Torrance
    Quote Originally Posted by 13ttaz View Post
    How long have you had the links on the car for?
    Torrance, CA 90501
    310-294-8108
    Apr 29 2013
    Arizona
    ^ About two months . . . car is 4 months new.
    Dec 24 2008
    Torrance
    Shouldn't be happening, either an installation error or you have a bad rod end. We have cars with 40-50K without any noise.
    Do you also have any other suspension modification such as springs or coilover?
    Torrance, CA 90501
    310-294-8108
