Results 1 to 27 of 27
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    B6 A4 Dual Intercooler Euro OEM - conerns regarding high boost
    As an alternative to
    - upgraded single SMIC' (quite expansive for the little gain in cooling capacity)
    - larger FMIC (bumper mods, loss of stock look; but lots of cooling capacity)
    - dual Euro stock FMIC (obviously double the IC capacity, much more than upgraded SMIC; stock look and fit)
    My only concern: Do the stock IC (with their plastic side tanks?) hold up to high boost pressure (say 22 psi), or do they tend to blow apart?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Mine started leaking shortly after I went to the 20+ lbs of boost. I believe Alexza4 had his end cap blow completely off. With that being said I know others have successfully used the dual intercooler set-up with higher boost levels. Guess it's a crap shoot.
    Jun 23 2008
    In for more info on this Euro Dual FMIC
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by DownhillA4 View Post
    Clicky click
    Jun 23 2008
    Thanks, PM'd Boy412.
    Dec 25 2004
    Earth
    Quote Originally Posted by vtraudt View Post
    Zero trimming required.
    Doesnt look stock?
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by MikTip View Post
    Nice. B6?
    Size of heat exchange (wxhxl)?
    In/out diameter? tubing diameter?
    Source?
    Looks like stock is 200 cu in. 300 and up seems suitable for my 350 cHP power goal.
    $500 and up namebrand SMIC seem sure bet
    Could NOT find CXRacing or similar or GSP or Godspeed/ebay larger SMIC for 1.8T as a low cost alternative (I have 4 ebay FMIC running since several years, NO problems)
    Boost Factory: 8.1" x 8" x 6" = 389 cu in
    Tyrolsport: 10" x 8.1" x 4.5" = 365 cu in
    Eurojet: 8" x 8" x 5" = 320 cu in
    Taco cooler: 7" x 8.25" x 5.125" = 305 cu in
    Kraut-Burner: 8" x 8.4" x 4.5" = 302 cu in
    Godspeed: 8" x 7.5" x 5" = 300 cu in
    Forge: 8.3" x 8.3" x 3.9" = 269 cu in
    Stock: 7.25" x 8" x 3.5" = 203 cu in
    FMIC ebay: 22x7x2.5= 385 cu in
    FMIC ebay: 20x6x2.5= 300 cu in
    Dual Europe stock: 400 cu in
    05 Golf TDI
    Dec 28 2006
    Western Maryland
    Those dimensions look like the intercoolers for the VW GTI. I think the A4 1.8T OEM intercooler is 2.5"x7"x9.5" for a total of 166 cu in (although that could be the B5 dimensions).
    Edit: Just found the OEM B6 dimensions and it is even less: 214mm x 192mm x 65mm for a whopping total of 163 cu in. A single Tyrolsport would provide more density than two OEM SMIC's. The B6 Tyrolsport is 360 cu in.
    Jun 27 2011
    Fwiw, the b7 uses a dsmic system and I think it would be easier to adapt a passenger side SMIC from a b7 that it would trying to acquire a euro SMIC setup.
    I really like the IDEA of the factory look if the OEM DSMICs but in practice its a lot of expense for not that much better cooling capacity. I honestly think a single upgraded Apikol or tyrolsport SMIC would be a better use of money.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 20 2010
    Brighton, MI
    Could very well be; came across a post that had most of those numbers for comparison value.
    05 Golf TDI
    Senior Member Three Rings westie180's Avatar
    Mar 01 2011
    Indy
    Another concern of the DSMIC setup is additional pressure loss across the cores and fittings, meaning your turbo would have to work even harder to maintain ~20psi at the manifold.
    Suddenly, I find myself very concerned of how my 10 year old intercooler is doing with my stage 1 boost levels.
    Feb 20 2010
    Brighton, MI
    Doesnt look stock?
    Found it:
    http://www.racetec-us.com/b6a4.html
    $1,100 !!!!
    No core size mentioned either.
    05 Golf TDI
    Feb 17 2004
    Liberty Hill, TX
    edit: you found it while I was posting
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 27 2005
    The Cold North
    If you want stealth get a ER and have the core black anodized.
    You can't see my core behind the lower grill. With black powder coated pipes, black couplers and the black core the only visible component is the SS hose clamps.
    http://www.evolutionracewerks.com/node/59
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by EBG 18T View Post
    $1,400. Must include the car, or?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Always wondered why anodizing everything black, but leave the clamps as a shiny eye sore? $0.99 spray can Home Depot.
    05 Golf TDI
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    Go buy a Honda if you want cheap parts.
    Keep your eyes glued to the classifieds if you have a tight budget. I picked up 2 racetec Intercoolers on the cheap. One for 400 and one for 250.
    Brilliant Shwartz 2004 S4: Stock
    Jan 01 2012
    2004 A4 Avant
    CO
    Here's the route I went for a cheaper fmic setup. Works great!
    http://www.audizine.com/forum/showth...view-with-logs!
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by rocky.ca View Post
    I am running 4 cars with FMIC. Not one kit (including clamps, hoses, pipes) was more than $300 new. All working perfect.
    Only deviation (did not have the time or energy to guess) when I 'caved under pressure' was my the FMIC for my 2.7T Allroad and paid the $500 big buck for the JHM since they were the only ones confirming fit on my manual AR; so pretty rare application.
    A run of the mill B6 A4 1.8T kit over $350 needs serious questioning.
    And if someone is hinting at 'efficiency'. Well yes, there are differences. Say the best in world is 5% more efficient than the ebay cheapo: add 20% more core volume and physics hands you the win.
    05 Golf TDI
    Mar 27 2005
    The Cold North
    Unfortunately it chips off and looks worse. I had a set powder coated. But didn't want to send off another set to the coater when I replaced them.
    2020 Chevy AEV ZR2
    Feb 20 2010
    Brighton, MI
    Spray again?
    Caliper paint?
    That vinyl spray goop kids use to black out their trim?
    05 Golf TDI
    Feb 27 2011
    Winnipeg
    for a while you could buy a valeo bex passengerside intercooler from rock auto for 150ish, then its a matter of piecing together the rest of the stuff. it doesnt show now but in a week or so it will probably come back
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    here's a very nice ER Sport FMIC in the classifieds that was posted a few days ago. If I didn't just purchase my treadstone tr6 and piping kit just last week, i would get this. actually, i'm still considering it....haha. little trimming, good fit, and great reviews. you could probably still fit your grills and look stock.
    http://www.audizine.com/classifieds/...mic-kit&cat=21
    2003 A4 Sedan:
    * GTRS Eliminator - 550cc Injectors - 034 HFC - Techtonics Tuning Downpipe - Neuspeed Exhaust - 034 TIP - Treadstone TR6 FMIC - Reisu Motorsports Custom Tune - JHM Short Shifter - Fluidampr Pulley
    * H&R Sport Springs - Bilstein Sport Shocks - RS4 Rear Sway Bar - B7/B6 S4 Front & Rear Brakes
    * 18" VMR v710
    2004 A4 Avant:
    * APR 1+ - Vogtland Coilovers - B7/B6 S4 Front & Rear Brakes
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Have you ever logged any of these 4 cars? Better question, have you ever actually used a high-end FMIC on one of these cars, or are you just basing off the fact that the car runs with your 300$ FMIC, so it obviously must be a quality core....
    You're quick to say that any kit over 350 is basically a waste.... maybe to someone with a stage 1 tune. Put your 300$ kit on a GTRS or higher and see how well your car performs after a few hard pulls.
    You need to stop and think about what you are saying here.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    I did the same as jjvwg. Bought the treadstone tr18t and the crxracing piping. Great combo for 500. I plan on painting it black with a few thin coats of radiator paint to make it stealthy. That's for my wife's car. I picked up a used evoms intercooler with piping for my car for 300 shipped from an az member. Keep an eye on the classifieds
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Found it:
    $1,100 !!!!
    I have a Racetec core in my garage. I can post the dimensions later. I'd also be willing to get rid of it for $350
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by POPO View Post
    PM sent.
    05 Golf TDI
