Siemen 630cc injectors use Jetronic connectors, which the stock harness uses. So yes, they will work.
But from personal experience, those injectors are not that good. I mean they work, but the fuel distribution is not the best by a long shot. I ran Siemen 630cc injectors and swapped them out for Bosch EV14 630cc injectors, nothing changed in the tune besides injector constant iirc (I did not tune my car, but a forum member did). Only reason for the change was I wanted a smoother engine, and swapping out those injectors did the trick. Even the rough starts (subjective) went away and she fires up much more smoother. That was just on the engine start up. Drive-ability is night and day difference apart with the different spray patterns the Siemen injectors provide vs Bosch.
I originally butt-connected Jetronic EV1 pigtails when I ran the Siemen 630cc injectors. When I swapped in the Bosch EV14 630cc injectors, I used the (non-pigtailed) adapters and they would occasionally cause me misfires mid-travel where ever I was. Got annoying having to pull over, pop the hood, and wiggle the connection (just the adapter area) just to make the misfires stop. Got annoyed and ordered EV14 pigtails. Took off the EV1 pigtails I butt-connected to the stock harness and butt-connected EV14 ones in. Misfires went away and have been fine ever since. So now my harness is configured directly for EV14 connections.
Pics of my setup and an idea of what you can do to make it cleaner. I tucked that section of the harness under the intake manifold to give an illusion of a wire tuck. And if you ever have to do the ignition coil section, you can decide on what to do to route that section also to the cold side of the motor, which will prevent it from drying/burning out again.
