As title says, I'm getting the check engine light with that code. I've replaced the spark plugs and coil packs on my car once I saw the code. Worked alright, but the code returned, so I fueled up and added some Lucas injector cleaner. Again, no big change. I found this thread on a semi-related issue:
"I have a misfiring issue the fault code is p0301"
and he later states
"Turn out my PCV breather hose is leaking."
http://www.audiforums.com/forum/b7-m...-166720/page2/
So I look up PCV leak and..
"I read that the PCV valve can go bad and the way to tell is to pull the oil filler cap while the car is running. If it runs rough and/or has suction, then the PCV is going bad."
"Yes - my oil cap was stuck on tight when I had the PCV problem. Could also hear a hissing sound right after I shut the engine off and there was a DTC code (though no CEL). Replacement PCV, under warranty, removed all those symptoms."
http://forums.audiworld.com/showthread.php?t=2809353
I did the oil filler cap test and sure enough, cap is on tight, once i take it off, suction occurs and engine is idling very rough. Might these issues be related, or do I have two separate problems on my hand?
